JDP Motorsports
Old 10-31-2010, 07:27 PM   #1
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Is 500-550rwhp to much for BMR rear cradle INSERTS
Would it do the car any good or be worth the money to install street version inserts with street version diff bushings with 500-550rwhp? This would be used do to the fact that install is much simpler on the inserts but if the power requires pro then thats thats. Thanks
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 10-31-2010, 07:59 PM   #2
1camaro70
1camaro70's Avatar
Drives: 2010 2SS RS L99
from talking with Pedders, Pfadt and BMR the bushings for the rear subframe are most important, whether inserts or replacements, also Pfadt has solid ones. I am going with a full kit and then going to sway bars, all the manufacturers say the first step to a better handling car starts with bushings. With 500 to 550 HP the replacement or solid would probably be the best.
1camaro70 is offline   Reply With Quote
Old 10-31-2010, 08:02 PM   #3
Rob@WretchedMS
Drives: His Wife Crazy
with that much power i'd go with full bushings and not inserts.
Rob@WretchedMS is offline   Reply With Quote
Old 10-31-2010, 08:44 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
I would definitely recommend the Pfadt solid sub frame mounts for your application. The "solid" part scares a lot of people but it's not harsh or even uncomfortable. I would describe it as just more connected.
Old 11-01-2010, 11:14 AM   #5
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
We are pushing 620 to the rear wheels and drag race the hell out of the car. We've watched plenty of GoPro video of our suspension during these runs and there is no movement whatsoever from the cradle since we upgraded to the full bushings (BK024). You would easily be fine with the BK024 full cradle bushings with the horsepower numbers you provided.
As for the inserts, we typically recommend them for stock to slightly modified cars and the full bushings for everything else. The inserts (BK016) are still a huge upgrade over the OE bushing and will help a lot but with a lot of horsepower you are still subject to the limitations of the OE rubber in the factory bushing...
BMR guy is offline   Reply With Quote
Old 11-01-2010, 01:23 PM   #6
jsharp
jsharp's Avatar
thank you. Most of the instructions are good but at the bottome where you just start taking stuff off the cradle I get confused as alot of those parts I dont know what they are without pictures!
Old 11-01-2010, 01:23 PM   #7
jsharp
jsharp's Avatar
I would just have to call as I had questions. What exactly would I have to used to get the old ones out since I dont have a press!
Old 11-01-2010, 02:59 PM   #8
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
The simplest way is to use a sawzall and cut through the cradle bushing from the center hole outward. Do this in two spots per bushing then the rest of the bushing can be knocked out easily.
The diff bushings are actually more difficult. You can force the sawzall blade through the void in the rubber then saw outward. You have to be careful though because the key is to cut through the outer steel bushing shell without cutting the aluminum differential ear that it's mounted in. The G8's all had aluminum bushing shells and it was so much easier to remove them. Not sure why the Camaro has steel shells but it definitely makes the install more difficult...
Old 11-02-2010, 10:22 AM   #9
jsharp
jsharp's Avatar
I have decided to just go with street setup with inserts as I know I can do them on my own and they will be better than stock. Plenty of cars running just stock and doing ok but I want a little better. I go to drag 1-2 times per year and never track coarse it so I should be ok.
Old 11-02-2010, 10:33 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
No matter whether you use the inserts or the bushings it will be an improvement over stock so it will definitely benefit you. I can definitely understand wanting to do the inserts over the bushings due to the ease of install and since most of your time driving the car is spent putting around town you shouldn't have any issues using the inserts rather than the bushings.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
BMR Sales is online now   Reply With Quote
Old 11-02-2010, 12:01 PM   #11
jsharp
jsharp's Avatar
THANKS! Now if I can get my wife to order them for christmas!
Old 11-02-2010, 02:47 PM   #12
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Now that is something I won't be able to help you with!
T.C. Davis
813-986-9302
Old 11-02-2010, 03:26 PM   #13
jsharp
jsharp's Avatar
Old 11-02-2010, 03:36 PM   #14
jsharp
jsharp's Avatar
Do you guys offer the red g force axles>? If so shoot me a shipped price on those to 72417
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
Steering response.... CGM2SSRS Wheels and Tires Talk Sponsored by The Tire Rack 130 10-21-2009 06:04 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
