Old 01-06-2009, 11:35 PM   #1
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
royal purple tranny fluid?
can some one please explain to me why this fluid is better then others?
and where to get it?
jeffny09 is offline   Reply With Quote
Old 01-07-2009, 12:42 AM   #2
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Lubricates better.
This creates less internal resistance and thus less drivetrain loss.
It also creates less metal shavings in the fluid/oil, keeping it clean for longer.
- Xanthos
P.S. - I buy mine at O'Reilly's.
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 01-07-2009, 12:47 AM   #3
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
and if i put it in wont it void warrenty?
Old 01-07-2009, 12:59 AM   #4
Xanthos
PWA Relapse
Xanthos's Avatar
It should by no means void your warranty. Although I wouldn't (and neither would royal purple) suggest putting it in till after about 5,000-10,000 miles on the odo.
- Xanthos
Old 01-07-2009, 01:37 AM   #5
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Y is that?
Old 01-07-2009, 01:59 AM   #6
Xanthos
PWA Relapse
Xanthos's Avatar
The engine just breaks in better that way. You can technically do it at the first scheduled oil change, but whats the harm in waiting longer?
- Xanthos
Old 01-07-2009, 06:07 AM   #7
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
Royal Purple is not an Approved product for use on GM cars, If I were you I would use one of the Synthetic products approved by GM, If you were to have a failure they would be able to deny your warranty claim based on using unapproved fluids (both Oil and Transmission are not approved). GM has a list of approved Synthetics availible, I have pulled it up before but right now I can't access it from work.
GM has been using more synthetics in their transmissions and I would make sure before I changed it that the Camaro has synthetic already in it first.
The Bird is the word!
Old 01-08-2009, 11:36 AM   #8
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
- Xanthos
who's talking about the engine?
he's talking about trans fluid.
one thing to keep in mind is that GM has spent a lot of R&D on this new trans that we have and have even stated that there is no fluid change interval for the auto unless you are seriously thrashing on it daily.
i'd leave the stock trans fluid in there. but i'll be changing the motor oil to RP.
I piss excellence
and fart awesomeness
Old 01-08-2009, 06:52 PM   #9
blackedoutss
blackedoutss's Avatar
Drives: nothin
horsepower on powerblock changed out the engine oil, tranny fluid, and rear diff fluid all for royal purple on an LS1 camaro. they put it on a dyno and picked up 7hp at the wheels.
blackedoutss is offline   Reply With Quote
Old 01-08-2009, 07:21 PM   #10
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
Not "approved" for use in GM cars...shouldn't you mean Not "Endorsed" by GM..If it is SAE certified and passes all the Govt. required testing then how can the say they may void a warranty because of the name on the oil can I dunno I just don't get it. From everything I have read about Royal Purple on various forums and articles it is highly recommended. I was planning on using it but it seems like alot of guys on here are Mobil 1 fans...I guess I may stick with that..I dunno
Badger is offline   Reply With Quote
Old 01-08-2009, 08:00 PM   #11
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
im getting a manual tranny not a auto
Old 01-08-2009, 08:04 PM   #12
dbotsfordtat
dbotsfordtat's Avatar
Drives: 2010 Camaro & 2008 Corvette
I don't know if this applies, but I have a TKO 5 speed manual in one of my cars and it uses GM auto synthetic for lube so maybe the six speed will also?
D.R.
Ordered 11-04-08, NFHCTC
dbotsfordtat is offline   Reply With Quote
Old 01-09-2009, 01:08 AM   #13
Hesh
Hesh's Avatar
Drives: 2010 IOM Camaro Vin 34334
The reason it was stated not GM approved is because its not on GM's very short list of oils that they have tested. Its not that its not as good as the ones they list, just that it was not submitted for testing. Will they not honor warranty work if you use it....time will tell. Personally I love the Royal Purple products. I have seen first hand what they can do, but if i think they may be reason for causing problems then I wont use them. Ill just use the GM approved brands.
Hesh is offline   Reply With Quote
Old 01-09-2009, 10:58 AM   #14
CamaroSpike23
Truth Enforcer
and? do you not run gear oil in your transmission?
werd. its not sponsored by GM, they put mobil 1 in nearly everything from the factory. but they also have a contract with mobil1 as well.
I piss excellence
Can't Decide - Auto or Manual attymf Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 209 01-04-2010 10:14 PM
Keep My 2SS Going Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 39 02-19-2009 10:50 AM
Challys 6-Speed Tranny only capable of 450 ft. lbs torque, what about the Camaro? Muscle Master General Automotive + Other Cars Discussion 9 10-18-2008 01:28 AM
Mystery fluid 96CAMaro 4th Generation Camaros 6 07-30-2008 06:03 AM
Camaro V6 tranny 2001ragtop 5th Gen Camaro SS LS LT General Discussions 14 02-03-2008 03:21 AM
