ADM PERFORMANCE
Old 11-02-2010, 09:45 AM   #1
Huggerorange73
Banned
Drives: The REAL C5
Send a message via AIM to Huggerorange73
13.2 @ 116 mph...suspension wizards...HELP!
Okay...here's the mods and the numbers as the car currently stands :
Torque management eliminated via tune
Rotofab CAI
SLP Loudmouth II axle back
Barton shifter
Kooks 1 7/8" Jet Hot coated headers & Hi Flow Cats
Pfadt lowering springs
Spohn trailing arms
Comp Cams XR281HR13 .571/.590 228/240 113 LSA
Dyno tune by Straightline Performance in New Lenox, IL : 470 rwhp/423 rwtq
And the latest results from the track on the stock tires:
60'............. 2.452
330'........... 6.088
660'........... 8.908
660’ mph..... 87.62
1000'.......... 11.276
1320'.......... 13.227
1320’ mph… 116.28
Car had wicked evil wheel hop on launch as well as the 1-2 shift.....
MPH says this car should be going way the hell faster than 13.2....so I turn to the suspension gods for help
Huggerorange73 is offline   Reply With Quote
Old 11-02-2010, 09:54 AM   #2
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
There is a lot of movement in the subframe. I would do Pedders subframe inserts and while you have the subframe lowered replace the upper control arm bushings. If you're not concerned with drivetrain noise, you can replace the entire subframe bushing for even greater control.
Also, you may want to put some of the torque management back in.
Jaysin is offline   Reply With Quote
Old 11-02-2010, 10:17 AM   #3
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
I think working on your launch technique will help more than anything. No offense, but that 60' is terrible. Try rolling out of the clutch and rolling into the gas and perfecting that. Good luck. With that MPH you have a very low 12's run justing waiting for you.
Old 11-02-2010, 10:18 AM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Our BMR trailing arms (TCA026) and our BMR toe rods (TR002) would help make a huge difference, those two items would be the first items I would do since the are relatively inexpensive and are pretty easy to install. If those items didn't cure all the wheel hop I would recommend the BMR "street" rear cradle bushing kit (BK020). These couple items will help out immensely with the wheel hop and are not going to break the bake or change up the driveability of the car really at all.
Also you should look into getting some better tires, you will never be able to hook very good on the stock tire. I would atleast look into the Nitto drag radials.
Kyle
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 11-02-2010, 10:23 AM   #5
Huggerorange73
Banned
Drives: The REAL C5
No offense taken....I tried multiple launch styles...all of them failed. Before the cam was in I was at least able to get 2.1 60's.
Old 11-02-2010, 11:12 AM   #6
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
ummm the key to any good suspension is a sticky tire
if you are running stockers or something on the factory wheel (this i'm assuming you are), you lack this and is where you will see the biggest improvement on.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-02-2010, 11:15 AM   #7
BackinBlackSS/RS
Go Blue!!!!!
Yep, then sticky tires is your best opton.
Old 11-02-2010, 01:55 PM   #8
Huggerorange73
Banned
Drives: The REAL C5
So you suggest drag radials over any suspension mods then?
Old 11-02-2010, 02:07 PM   #9
danhr
BAMF SS
danhr's Avatar
YES!
tires should of been first
then suspension
Old 11-02-2010, 02:13 PM   #10
Huggerorange73
Banned
Drives: The REAL C5
YES!
then suspension
I'm just wondering how much bang for the buck/help I'm really going to get from a 20" drag radial...it's gotta be close to $600 for a pair.
Old 11-02-2010, 02:18 PM   #11
danhr
BAMF SS
danhr's Avatar
i would suggest getting 18" wheels/drag radials
it's worth the extra money
and the tire is the make it or break it on almost any setup.
with a sticky tire, you should be in the ~1.7 60' range.... that will take you down to a high 11 second pass.... so you are cutting AT LEAST 1.2 seconds off your ET, by spending ~1,000. That isn't a good "bang for your buck" mod?!?! I'd say it's pretty damn good!!
Old 11-02-2010, 06:30 PM   #12
Huggerorange73
Banned
Drives: The REAL C5
I think the smart way to do this is throw some suspension upgrades at the car...benifits both the street & strip aspects. Then, instead of throwing money away on 20" drag radials...going with what you suggested with 18" wheels with a sticky set of drag radials, then praying the OEM halfshafts don't grenade. I'll bet you're on the mark...with those 18s an 11 time slip can be had.
Old 11-02-2010, 09:51 PM   #13
BackinBlackSS/RS
Go Blue!!!!!
YES!
then suspension
Old 11-02-2010, 10:46 PM   #14
SLOWHITE
SLOWHITE's Avatar
Drives: 2007 Trailblazer SS
Like was said earlier, work on launching the thing. If your tires are spinning at the line, you may as well give that run up. Don't be afraid to heat those tires up either. What track are you running at...what was the weather/DA like.
07 Trailblazer SS awd. 13.08, Vector tune, SLOWHITE intake, ud pulley, 160* t-stat.
My all year 'round, daily driven, boat pullin' Mustang beater.
SLOWHITE is offline   Reply With Quote
Yellow Lexus Type Fog Lights? phenixdragon Cosmetics and Lighting Modification Discussions 37 05-21-2017 11:49 AM
SS A6 or M6 faster?????? MY2010SS 5th Gen Camaro SS LS LT General Discussions 275 05-20-2010 05:15 PM
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 01:58 AM
Camaro 2SSRS VS Challenger RT (time sensitive) seabbott Chevy Camaro vs... 195 03-11-2010 03:51 PM
Looks like there is finally proof, the Manual IS Quicker.... Mblock66 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 181 01-21-2010 01:10 PM
