Rick@Livernois
Old 11-03-2010, 06:56 AM   #15
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
Originally Posted by Huggerorange73 View Post
I think the smart way to do this is throw some suspension upgrades at the car...benifits both the street & strip aspects. Then, instead of throwing money away on 20" drag radials...going with what you suggested with 18" wheels with a sticky set of drag radials, then praying the OEM halfshafts don't grenade. I'll bet you're on the mark...with those 18s an 11 time slip can be had.
you can break stock halfshafts on regular tires, you can blow apart the differential with stickies, and you can break the outputshaft on the transmission with stickies or regular tires.
Here's a newsflash. You are racing a car... racing your car puts a lot of strain on EVERYTHING! There will always be a weakness somewhere in your setup. If you don't have confidence in your car nor are you willing to put some risk into it, i'm sorry but you just picked the wrong hobby.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-03-2010, 07:51 AM   #16
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Like everyone else said there is always a chance of breaking your car when you are racing it and putting down some decent power no matter what tire you are on. We have broken a halfshaft, transmission output shaft, and driveshaft on on our 2010 Camaro. Stickier tires will definitely help with you track times and help launching the car. You also need to remember that wheel hop will do as much if not more damage then hooking hard on a sticky tire. You can't go wrong whether you decide to put tires or suspension parts on the car but in the end both are really needed to get the most out of the car.
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 11-03-2010, 08:10 AM   #17
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Okay...here's the mods and the numbers as the car currently stands :
Torque management eliminated via tune
Rotofab CAI
SLP Loudmouth II axle back
Barton shifter
Kooks 1 7/8" Jet Hot coated headers & Hi Flow Cats
Pfadt lowering springs
Spohn trailing arms
Comp Cams XR281HR13 .571/.590 228/240 113 LSA
Dyno tune by Straightline Performance in New Lenox, IL : 470 rwhp/423 rwtq
And the latest results from the track on the stock tires:
60'............. 2.452
330'........... 6.088
660'........... 8.908
660’ mph..... 87.62
1000'.......... 11.276
1320'.......... 13.227
1320’ mph… 116.28
Car had wicked evil wheel hop on launch as well as the 1-2 shift.....
MPH says this car should be going way the hell faster than 13.2....so I turn to the suspension gods for help
do the suspension mods first to eliminate the wheel hop. wheel hop will break things.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 11-03-2010, 08:40 AM   #18
danhr
BAMF SS
danhr's Avatar
ok I am going to go out on a limb here and make the assumption that you are being sarcastic in this post?
I did not see the sarcasm smiley, and I don't want the OP to be confused.
Old 11-03-2010, 08:53 AM   #19
Huggerorange73
Banned
Drives: The REAL C5
Send a message via AIM to Huggerorange73
Okay...here's a tenative plan of attack :
BMR :
BK020 - Rear cradle bushing kit
BK021 - Rear suspension bushing kit
Spohn :
C10-601 - Toe links
Set of 1000HP axles
Set of 18" wheels with sticky tires
Your thoughts?
Huggerorange73 is offline   Reply With Quote
Old 11-03-2010, 09:01 AM   #20
danhr
BAMF SS
danhr's Avatar
I am not a fan of just throwing parts at a car, and hoping it fixes your problem. Each car is different. Which means your car could benefit (for instance) more from shocks than from subframe bushings. You can't really tell that until you get a clean launch and see what exactly is going on with your car (too much/not enough weight transfer, too much squatting, too much flex, blahb labhlahblahblahblba).
I would say take it one step at a time and not waste money and start throwing random parts at it.
Put a set of sticky tires on it (because right now that's what it needs the most), and see how it reacts. Maybe get a friend to video it and post up the video and ask what people think on how the car is launching.
Old 11-03-2010, 10:24 AM   #21
RedRyder
RedRyder's Avatar
Drives: 2010 VR 2SS/RS M6
What seemed sarcastic about that statement? I agree that eliminating the wheel hop as much as possible will help prevent damage that would have been caused by the wheel hop while helping put more power down.
RedRyder is offline   Reply With Quote
Old 11-03-2010, 11:02 AM   #22
danhr
BAMF SS
danhr's Avatar
sigh...
to try to eliminate wheel hop, you have to first understand it.
I will try to give a short lesson
Wheel hop is caused when you compress the rear shocks and they come up in a fast rate that when they over power your springs, the springs in return put force back (this is normal) but they over power the shocks and when they uncompress it unloads the rear suspension, so to say. the two fight back and forth sticking/slipping/sticking/slipping. When the tires loose traction, the initial weight transfer you got when you launched your car, reverses itself, as you are not giving that forward momentum anymore, which even further helps unload the rear suspension. then when they hook again, the weight transfer comes back and you go into a vicious cycle until you hit that happy median to where you aren't making the weight transfer go back and forth and the tires can hook. This is why if you do get wheel hop, you should get out of the throttle, because it will keep going and it can take a long time to reach that median.
Putting a sticky tire will allow you to launch higher. then when you launch, the weight is transferred to the back, but then since the tires don't slip, you won't have any wheel hop, as the weight isn't being transferred back to the front at an accelerated rate, and you are keeping the rear suspension loaded.
This past weekend I helped a buddy out with launching his car, and it might help you see what I'm talking about. His only suspension mod is a set of trailing arms (as opposed to the OP who also has a set of lowering springs) but has a stickier set of tires. The car in the video has 200+ more rwhp than the original poster, and has less suspension mods. So according to your theory, he should get massive amounts of wheel hop (well at least more than the original poster)
Notice how the rear suspension stays loaded through the launch, resulting in no wheel hop.
Do not mis-read this and think that the only contributing factor to wheel hop is tires, because it is by far not. But the first step in getting any sort of traction, let alone addressing wheel hop, should always be a set of sticky tires.
Old 11-03-2010, 01:59 PM   #23
Huggerorange73
Banned
Drives: The REAL C5
That's pretty damn impressive right there!
I wonder how much, if any help could be gained with a 20" drag radial on the OEM wheel?
Old 11-03-2010, 02:26 PM   #24
Dan@showstopper
Dan@showstopper's Avatar
I have to agree with danhr, everytime I have had wheel hop it was while spinning the tires down the track. I have the exact same suspension set-up as HO73 and have eliminated all my wheel hop. Granted he makes about 80 rwhp more than me. Putting the power to the ground with elminate wheel hop, the only thing to worry about is halfshafts but that's the case when you make power and hook with most cars.
Mike, I'm trying to get a set of spacers for my wheels. If they work we can get that 11 sec. slip before it goes away for the winter.
Dan@showstopper is offline   Reply With Quote
Old 11-03-2010, 02:33 PM   #25
GotMeSOM
GotMeSOM's Avatar
Drives: Blown 02 SOM SS (630 hp old ride)
Get a set of Mickey Thompson drag radials in 18's. That is all you need.
http://www.mickeythompsontires.com/s...StreetRadialII
1/4 mile is all about the 60 ft.
Do one change at a time, not multiple.
2.4 60 ft is dismal lol.
That tire should get you a 1.6 which put you at a 12.0-12.2 where your car should be.
GotMeSOM is offline   Reply With Quote
Old 11-03-2010, 02:38 PM   #26
danhr
BAMF SS
danhr's Avatar
Get a different set wheels for racing use only.
Trust me.
drag rad'ials for a 20" wheel are roughly $100 more than a set of drag radials for a 18" wheel.......EACH!
And that's not just a one time thing.... THAT'S EVERY TIME YOU BUY TIRES!
so think of that initial $200 to go towards the purchase of a set of 18" z06 wheels......
Getting a separate set of wheels for the track also let's you pick the stickiest tire possible, you don't have to worry about tread life, because they are strictly for the track. Even fastest wearing drag radials should last you two years or so (Im going to go with the assumption that you do not visit the dragstrip every week, like some people).
getting a 18" wheel also GREATLY widens the choices for tires (dozens compared to the handful)
and you will run faster with a 18" wheel because you will have a lighter wheel (metal weighs more than rubber) so you are cutting down on rotational unsprung weight
I can go on and on and on about this btw......
Old 11-03-2010, 04:03 PM   #27
Huggerorange73
Banned
Drives: The REAL C5
Halfshafts be damned.....11 sec time slip is the goal.
Without question my 60 foot times were pathetic.....I agree with one change at a time, although going with a sticky tire should more than likely be handcuffed to an axle swap no?
Trust me.
Don't stop.....I enjoy the reading!
Old 11-03-2010, 04:14 PM   #28
HumanWiki
Drives: Car
Which wheels would those be?
What year Z06? -- I've been trying to get someone to outright tell me about 18s on this car and I get crickets chirping.
HumanWiki is offline   Reply With Quote
Yellow Lexus Type Fog Lights? phenixdragon Cosmetics and Lighting Modification Discussions 37 05-21-2017 10:49 AM
SS A6 or M6 faster?????? MY2010SS 5th Gen Camaro SS LS LT General Discussions 275 05-20-2010 04:15 PM
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 12:58 AM
Camaro 2SSRS VS Challenger RT (time sensitive) seabbott Chevy Camaro vs... 195 03-11-2010 02:51 PM
Looks like there is finally proof, the Manual IS Quicker.... Mblock66 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 181 01-21-2010 12:10 PM
