11-02-2010, 10:36 AM | #1 |
rear deck/window = rattle
I have only one 10" sub. Right in the middle of the upper trunk where it lays on the window. It's not so bad once it warms up a little in the evenings but I suppose the foam strip along the window when cold sounds awful. I cannot stand it... I have lined the underside of the carpet with dynamat and the entire trunk.
More or less thinking some rubber sealer run a thin bead or using some sort of rubber with a sticky backing. My only concern would be it not sealing properly. Anyone else have this problem and have another outlook on what to do? Has anyone come up with a clean/easy solution to this problem?
11-02-2010, 12:03 PM | #2 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
This is the first I've heard of this issue. Good luck getting it fixed.
11-02-2010, 06:25 PM | #3 |
Drives: 2020 Camaro convertible RS Auto Join Date: Feb 2010
I have the exact same issue. I acttually had mine back to the dealership because of the rattle. The first time they tried to say it was because of the subs I have. I unhooked them, took it back, and showed them it still rattled with the stock speakers. There was a service bulliten put out about this, search the site for the number. Basicly they used double sided 3m tape to hold the outer edges of the rear deck to the edges of the trip along the sides of each side and problem was solved....but i noticed it is starting to come loose again.
11-02-2010, 08:53 PM | #4 |
Camaro Addict
Drives: 2010SS/1995 Z28/2005 CTSV/2007 TBSS Join Date: Jan 2007
11-03-2010, 09:14 AM | #5 | |
Awesome thanks for the replies guys.
11-03-2010, 09:55 AM | #6 |
It's that guy
It was funny I was about to start a long and drawn-out "WTF my trunk is rattling" thread but this was the first in the forum. What a coincidence, my trunk is rattling badly and i only have stock speakers! how am I supposed to be gangsta with a rattly trunk? haha
We mortals are but shadows and dust.
Thread Tools | |
Similar Threads | ||||
Pfadt Camaro Rear Toe Link Reinforcement Kit Install write-up | PfadtRacing | Suspension / Brakes / Chassis | 9 | 01-28-2014 07:15 PM |
Suspension Upgrade Advice for Rural (Crappy) Roads | RyanG | Suspension / Brakes / Chassis | 26 | 02-22-2011 10:04 PM |
Rear Rattle | Katalyzt | Suspension / Brakes / Chassis | 6 | 09-22-2010 06:21 PM |
Some Texas Lighting Laws | Mecha | USA - Texas | 5 | 10-20-2009 01:49 PM |
Suspension guys out there - lets talk wheel hop | Crowley | Suspension / Brakes / Chassis | 14 | 10-09-2009 12:06 AM |
