Cold Air Inductions
Old 01-07-2009, 08:02 AM   #1
mega
Drives: 2007 mini cooper S
Which transmission will the L99 have?
anyone know which transmission the L99 will have?
I'm interested in the lockup %, I normally dont like auto's, but the latest offerings I've tested are brilliant
BMW uses a ZF 6 speed in the 135i and 335i, and it's like driving a manual, it stays locked up all the time, completely different than the transmission in the 128i/328i which is a GM transmission and does not lock up like the ZF does.
On the ZF when you let off the gas at speed, it behaves just like a manual, it does not drop the rpm, it stays where it's at, so there's none of that lurching when you get back on the gas, the RPM is locked to the speed, it operates at 99% locked up bypassing the torque converter, I'm not sure what the exact percent is, but it's very high, it's almost as good as the new dual clutch aka DCT in the M3
it also does double gear downshifts, and rev matching downshifts, it's really a joy to drive
so anyone know what transmission the L99 will have, and if it will have nearly 100 % lockup like the newest ZF's have?
mega is offline   Reply With Quote
Old 01-07-2009, 08:05 AM   #2
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
GM Hydra-Matic 6L80
UCF w00t is offline   Reply With Quote
Old 01-07-2009, 10:52 AM   #3
mega
looks like that's in a few GM products already
does the G8 use that one too? I cant remember how it shifted when I drove it, it was unremarkable though, I don't think it had the double gear drop down
Old 01-07-2009, 11:49 AM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
It's rev-matching, and fully-controllable. This transmission is the automatic used in the Corvette. But I don't believe it's locked up 99% of the time...
Old 01-07-2009, 12:07 PM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Here's a list of cars that I've found that it's used in.
* 2006 Cadillac XLR-V
* 2006 Chevrolet Corvette
* 2006 Holden VE Commodore
* 2006 Holden WM Statesman
* 2006 Holden WM Caprice
* 2007 Cadillac STS
* 2007 Cadillac Escalade
* 2007 GMC Yukon Denali
* 2008 Hummer H2
* 2008 Pontiac G8
* 2009 Cadillac CTS V-Series
Old 01-07-2009, 12:11 PM   #6
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
some people are saying the 6l80 will never live long behind 500+hp engines,, i say b.s., the cadillac cts-v is over 500hp and comes stock with the 6l80 trans and has 100,000 mile powertrain warranty
Old 01-07-2009, 12:19 PM   #7
JJ#48Racing
Drives: 1998 Camaro SS
Are you sure it's rev-matching? I remember reading an article about the Corvette and they said it was not rev-matching.
JJ#48Racing is offline   Reply With Quote
Old 01-07-2009, 12:27 PM   #8
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
What the heck is rev matching??
Old 01-07-2009, 12:28 PM   #9
Mr. Wyndham
http://www.autobuyguide.com/2008/12-...ews/index.html
http://www.edmunds.com/insideline/do...ticleId=129446
On the G8, and going to be employed on the Camaro...
I could have sworn GM had their own literature talking about it too, but I couldn't find it.:(
When you downshift, the computer blips the throttle revving up the engine so it's speed is matched to the gear your shifting into.
Old 01-07-2009, 12:42 PM   #10
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
Oh cool! Thanks.
Old 01-07-2009, 05:22 PM   #11
BeermanSS
BeermanSS's Avatar
Drives: 2005 Cobalt SS/SC
heres a page you can check out and get the gm literature on engines and tranny.
http://media.gm.com/us/powertrain/en...2009/09car.htm
BeermanSS is offline   Reply With Quote
Old 01-07-2009, 09:03 PM   #12
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
If it is like the G8GT, when you are in manual mode, the convertor is locked. And, the stock convertor has a twin lock up disc which will support quite a bit of power locked.
mike@newera is offline   Reply With Quote
Old 01-08-2009, 02:22 AM   #13
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
I still don't understand where the rev matching comes into play or how to do it on the automatic when you switch it to tap-shift mode. Is it down-shifting around a corner to gain speed? Can you explain certain situations where this is used and how to use the feature and what it would be like without it. Thanks
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 01-08-2009, 03:25 AM   #14
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Have you ever done heel-toe downshifting on a manual? Its a lot like that and serves the exact same purpose.
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Tuning LS3 vs L99 Evilangel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 10-30-2008 10:22 AM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
Manual Transmission For the l99 Kelton00912 5th Gen Camaro SS LS LT General Discussions 17 07-30-2008 04:54 PM
L99 discussion The_Blur Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 85 07-25-2008 02:07 PM
