SDTW Custom Wheels & Tires
Old 11-05-2010, 02:33 PM   #1
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
Do Your Good Deed For The Day: Help A Suspension Noob
Car is my daily driver and will probably never see a track. The fiance' doesn't want to lower it (but is wavering in this..oh yes, he is) so my question is...what suspension mods do you recommend that won't sacrifice too much ride quality?
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 11-05-2010, 02:37 PM   #2
VEESIKS
formerly 2011Camaro
Drives: 2011 Camaro LS IBM M6
From what I understand by reading some posts on here is that lowering doesn't take too much effect on ride quality on the 5th gens. The general feel seems to be that it's a LITTLE firmer but nothing too bad to complain about.
Born on the Island and raised in the sand.
Semper Fidelis
VEESIKS is offline   Reply With Quote
Old 11-05-2010, 02:47 PM   #3
CamaroFemme
Well, the main reason is that I live in the countryside, and the roads aren't the best here, so I was looking into what I could do WITHOUT lowering (but again, that isn't set in stone. Feel free to talk up the benefits of lowering.)
Old 11-05-2010, 02:48 PM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
trailing arms would be a good starting point
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-05-2010, 02:51 PM   #5
Chrisrp454
Chrisrp454's Avatar
Drives: 2010 ABM 2SS/RS M6, 98Z28 M6
Go here all the info you need, also see post 19 and 20 its where I ask about mine and daily driving.
And no I have not gotten around to it yet. :(
http://www.camaro5.com/forums/showthread.php?t=90270
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve!
Ordered 5/23/2009
3400 with TPW of 08/03/09
3800 8/11/2009
Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior
Chrisrp454 is offline   Reply With Quote
Old 11-05-2010, 03:00 PM   #6
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Ride quality will suffer when a spring is shortened to do the job or the spring rate is increased during the "winding" of some "lowering" springs.
Of course all of this could be avoided by using coilovers. Most co's use a threaded shock body for raising/lowering adjustments and don't affect spring rate with these changes. But they are pricey compared to lowering springs....
If you can find a set that only lowers up to 1.00in, the inherent spring rate increase should be very minimal/livable. You will do more for the handling of the car by doing sway bars than springs until you really start pushing things.
Just my .02 worth. I have Pfadt bars & CO's and them btw
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 11-05-2010, 03:03 PM   #7
CamaroFemme
Speaking of pushing things, I suppose I should add that the car is currently stock, with plans to get a CAI and custom tune, and perhaps exhaust. That will probably be it.
Probably.
Thanks to all, and keep the good advice coming.
Old 11-05-2010, 03:13 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
A good lowering spring will improve the looks of the ride height but ALL will make your car ride stiffer. If someone says it's the same as stock, they're lying. Ride stiffness is VERY subjective and can only be assessed by YOU. What may feel nice to one person might feel like riding in a wagon to another. My advise is to find someone close to you that has springs and take a ride. If they're nice, they'll let you drive it to see how you like them. I did that very thing for a local C5 member. You will get a dozen different answers as to which is best.
I chose Pfadts for a few different reasons. The main one being that they are a top notch company that has lots of experince with suspension parts for Corvettes and now Camaro's. They also lowered the car just a tad more than most others while staying within the range to get the alignment good without any extra parts. They advertise a drop of ~1.25in which, IMO, is absolutely perfect for the Camaro. Once you drop below the 1.25in range, you run the risk of needing alignment add-ons parts. The ride is definitely stiffer but IMO not bad at all. In stock form the car floats and does't give you a good feel for the road. Adding springs increases the feel of the road and gives you more control. Adding sways, especially the rear, really tightens things up. That's the feeling I had when I added the rear bar. I drove it for two days before I added the front. The front didn't make as much difference after the rear but it was noticeably better.
Seeing that Pfadt chose to only offer the one size spring, if I wanted the standard 1in drop, I would have chosen Pedders or possibly BMR or Hotchkis. All four are within ~$20 of eachother when not on sale. Pfadt has a SEMA special going on right now that has their springs and both sways on sale for $600 with free shipping. That's $170 off their regular price. I'm sure others have sales going on but i'm not aware of them. Eibachs and Vogtlands are the known cheaper brands. If you want the cheapest price on springs, those are probably your best bet.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-05-2010, 03:25 PM   #9
roccky08
roccky08's Avatar
Drives: 2SS/RS Summit White/Beige Interior
I would say start with upgraded sway bars, and trailing arms. If adjustable coilovers are within your budget, go for it. I recently upgraded my Suspension with Pfadt coilovers, sway bars, BMR trailing arm and Toe rods and the car handles incredibly well. I couldn't be happier
- Bola ATAK Exhaust - Installed
- Pfadt Adjustable Coil-overs - Installed
- Pfadt Sport Sway Bars - Installed
- Pfadt End-links - Installed
- Pfadt Strut Tower Brace - Pending
- BMR Trailing Arm - Installed
- BMR Toe Rod - Installed
Thank you Vengeance Racing for install and recommendation
Thank you Borla for the ATAK Exhaust
roccky08 is offline   Reply With Quote
Old 11-05-2010, 03:31 PM   #10
hypurone
hypurone's Avatar
Probably.
Yeah sure! Keep tellin' your self that. It doesn't work. Resistance is futile!
Old 11-05-2010, 03:41 PM   #11
axis
Search Ninja
axis's Avatar
+1 BILLION.
Modding is like a drug. Once you start, it's hard to stop.
Halltech CF 102 fed
Old 11-05-2010, 03:53 PM   #12
toehead93
Drives: 2014 2SS/1LE
I personally went with coilovers because they retain the full range of spring compression. As mentioned earlier lowering springs reduce the overall travel. I lost very little ride quality and the best thing is the ride quality is adjustable to 30 settings so I can adjust to stock anytime. Of course coilovers are a lot more expensive than springs but I also have complete adjustibilty on ride height. I lowered mine over 2.25" all the way around and I can raise it up anytime. My alignment is ideal too for an aggressive street setup.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 11-05-2010, 04:13 PM   #13
hypurone
hypurone's Avatar
Originally Posted by axis View Post
+1 BILLION.
Wait, wut? You can stop?
Old 11-05-2010, 04:19 PM   #14
CamaroFemme
Since no one I know has a vehicle w/ suspension mods, I like the idea of being able to change something back to stock if I don't like it. How much are coilovers?
*braces self*
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 11:00 AM
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 09:38 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Good day in Oshawa detroit iron rules 5th Gen Camaro SS LS LT General Discussions 18 04-14-2009 01:02 AM
Today was a good day. Haloman1346 Camaro Price | Ordering | Tracking | Dealers Discussions 27 02-27-2009 09:13 PM
