Old 11-06-2010, 10:38 PM   #1
ga0358
ga0358's Avatar
Drives: 2010 ABM LS
Fog Light Install on my LS!
Finished my fog light install on my LS today...A bit of a pain,but well worth it, my night time field of vision is almost doubled!
ANYWAY, here's a few lessons learned:
1). Yep, the front bumper/fascia HAS to be removed, but you don't HAVE to take off the tires, although it makes things MUCH easier
2). Make sure to order the bezels ($15.00) unless you want to cut the existing bezels.
2). Be CAREFUL with the side panel lights. There's a gray clip that you have to unlock before the light panel slides out. I snapped a piece on the mount, but re-secured it with the screw
3). Since the LS comes without a fog light switch, the harness from GM parts will not work as is, I had to splice the fog light wires into the side panel marker lights, which is fine, just match up the hot and ground wires to the corresponding wires on the harness.
SO when the DRLs are on, the fogs are OFF, when the sun sets, the fogs and sides light up-Also you can manually activate them via the parking light position, which is what I wanted to do anyway..
All in all, not a bad Saturday project,it took me about 3 hours, most of that locating screws and fender snaps. Special THANKS to GM Parts direct and Jay Griffin for getting everything to me so fast and answering my questions!! IT LOOKS GREAT!!!!!
ga0358 is offline   Reply With Quote
Old 11-06-2010, 11:32 PM   #2
Bonanza7
Drives: 2010, Rally Yellow, Black stripes
You are better than my dealer. He said it was not possible to put fogs in an LS.
Bonanza7 is offline   Reply With Quote
Old 11-06-2010, 11:37 PM   #3
camaroitalia
Go Harder Than Baltimore!
camaroitalia's Avatar
Drives: 2010 CGM
wow lol
Old 11-07-2010, 01:45 PM   #4
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
this might be a stupid question. but what the hell do you cut the black bezel with. because that some hard plastic! lol any help would be appreciated lol
zkdreads is offline   Reply With Quote
Old 11-08-2010, 11:05 AM   #5
ga0358
ga0358's Avatar
Drives: 2010 ABM LS
Well, Jay at GM parts direct suggested I order the bezels too, that way there's no cutting and everything sort of snaps into place. Only $15.00 a piece...
Old 11-13-2010, 07:25 AM   #6
blcoonrod
blcoonrod's Avatar
Drives: 2011 White LS
Did you get factory fogs? If so do you have a p/n and how much were they? Also do you still have the p/n on the bezels?
blcoonrod is offline   Reply With Quote
Old 12-03-2010, 02:39 PM   #7
highline
highline's Avatar
Drives: LS
wow...They don't simply make a kit from gmpp or something huh? My dealer also told me I cannot put fogs on a ls...I can put 1000w MH/HPS HID grow lights in there if I want, just wanted something plug&play...New cars without factory or aftermarket support yet, I guess?
Stock For Now
highline is offline   Reply With Quote
Old 12-03-2010, 04:52 PM   #8
martinezj454545
Drives: 2011 Camaro LS V6
TOO SKDREADS.... The hard plastic can be cut with a dremel. I didit and it took like 5 min to cut each one and i just bought a 30 dollar dremel. The fog light i installed where the Hella Low Beam Projectors that AAC sells and they fit just fine when you cut around the bezel.
martinezj454545 is offline   Reply With Quote
Old 12-03-2010, 04:58 PM   #9
xpanda305x
Banned
Drives: Dark Knight
I am gonna have to ask you questions on a pm later when I get on my pc.
xpanda305x is offline   Reply With Quote
Old 12-05-2010, 12:21 PM   #10
meschwenk
meschwenk's Avatar
I was thinking of doing the same thing to my LS, but I'm new at this kind of stuff. Sorry for the dumb questions.
I have not seen the wiring harness from GM, so is it just two wires with plugs on both ends and you just cut off the one plug and splice that into the side marker lights?
Did you have to order two harness?
Are the Hot and Ground wires different colors on the side marker lights?
Thanks!
meschwenk is offline   Reply With Quote
Old 02-01-2011, 09:15 PM   #11
xpanda305x
Banned
Drives: Dark Knight
BUMP
Old 02-05-2011, 11:53 AM   #12
atlang3lo
atlang3lo's Avatar
Drives: 2010 Chevy Camaro LS All Black
I sent you a PM please read.
atlang3lo is offline   Reply With Quote
Old 02-05-2011, 12:21 PM   #13
midnighter
Drives: nothing
Old 07-11-2011, 10:23 AM   #14
DeputyBreaux
Drives: 2011 camaro
my dealer said the same thing..i want to install fog lights but have no clue how and everyone i ask seems to not know eithor..you know one dealer even told me to trade my ls in for one with fog light ..smh..what was the total cost?
DeputyBreaux is offline   Reply With Quote
DIY Raptor Dual Stage Shift Light. ThunderSS Camaro DIY & HOW-TO instructions & discussions 46 03-10-2014 04:53 PM
To fog light, or not to fog light. Xanthos Cosmetics and Lighting Modification Discussions 6 02-07-2013 05:35 PM
4300K HID Fog Light Conversion for RS RedJewel2SS Cosmetics and Lighting Modification Discussions 24 08-14-2010 04:09 AM
factory fog light switch scottcolem Cosmetics and Lighting Modification Discussions 5 12-21-2009 10:48 AM
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! HID_Guy Exterior Parts & Accessories 19 09-08-2009 02:07 AM
