Old 11-07-2010, 06:08 PM   #1
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
Best way to reduce wheelhop
best way to reduce wheelhop, ie rear subframe bushings or toe links or trailing arms?
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 11-07-2010, 06:22 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
All of the above are good options. A good set of rear trailing arms are sufficient for most applications but a set of solid sub frame bushings, while costing more, has benefits beyond just killing wheel hop. There are always trade offs. What mods do you currently have and what are you planning in the future? How do you use your car?
Old 11-07-2010, 06:44 PM   #3
Stealth 2010 2SS/RS
Looking to start at the weak points of the rear end first. axels will come soon but not in the budget at this point in time, trying to put off axels as long as possible. I have a cold air intake but LT headers are soon to come along with cam and all that good stuff. The car is weekend car would like it be able to take pounding and ask for more without fears of anything breaking.
Old 11-07-2010, 09:08 PM   #4
Apex Motorsports
You have a long way to go before you have to worry about breaking stuff. There are plenty of supercharged cars running stock axles with no issues.
You will definitely benefit from some suspension upgrades. People often focus too much on just adding horsepower and never give any consideration to the fact that horsepower means nothing if you can't transfer it to the pavement. I would recommend both rear trailing arms and solid sub frame bushings but I know that isn't in everyone's budget. The Pfadt rear trailing arms will allow the rear suspension to respond more quickly and will increase traction and reduce wheel hop. The Pfadt solid sub frame mounts will lock in the rear sub frame which will improve handling in several ways while improving traction and eliminating wheel hop as well.
This video gives a good visual demonstration of the change.
Old 11-07-2010, 11:04 PM   #5
Stealth 2010 2SS/RS
i have been leaning towards the soild subframe mounts ever since i talked with aaron from pfadt when he was in brainerd raceway in minnesota this summer, this is going to be a winter project. Just trying to find out all things needed to reduce wheelhop as much as possible. are toe links a necessary item in this
Old 11-07-2010, 11:25 PM   #6
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Jekyll-N-Hyde is offline   Reply With Quote
Old 11-08-2010, 12:01 PM   #7
Apex Motorsports
The Pfadt guys spend a lot of time at the track., and it shows in their products. The solid sub frame mounts and rear trailing arms will kill the wheel hop. The toe links are more for reducing deflection in cars that are used more aggressively. For a daily driver or weekend street car they probably aren't needed.
Old 11-08-2010, 01:20 PM   #8
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Awesome video. Really shows the difference. I have a V6 and my only mods are Intake and Exhaust atm, but I plan to take this baby Autocrossing, so in early 2011 I will start the suspension mods.
jagan323 is offline   Reply With Quote
Old 11-08-2010, 03:31 PM   #9
Apex Motorsports
That video lays it all out there. Hit me up when you get ready and we will put something together for you.
Old 11-08-2010, 03:34 PM   #10
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
the best way to reduce wheelhop?
don't push the gas pedal down as far.
and it's free!
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-08-2010, 03:36 PM   #11
Apex Motorsports
and it's free!
Yeah but its not as much fun!
Old 11-09-2010, 12:21 PM   #12
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
If you want a staged recipe, this is what works best for correcting wheelhop, in this order:
1 - Trailing Arms w/rear bushing upgrade
2 - Cradle Bushing Inserts or full Cradle Bushings
3 - Differential Bushings
Most cars can cure wheelhop with option #1 but higher horsepower cars sometimes need all 3. Additionally, if you drag race a lot and have sticky track tires, the launch can shock the suspension enough that the toe bushings will deflect. This can actually contribute to wheel hop as well and may require a Toe Rod upgrade to correct.
If interested, you can click on any of the above links to get more information.
BMR guy is offline   Reply With Quote
What's the best way to reduce CO2 from gasoline engines? Captain Awesome 5th Gen Camaro SS LS LT General Discussions 160 12-13-2009 12:18 PM
Experiencing wheelhop Germann Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 14 09-23-2009 04:30 AM
Driving like a jerk reportedly helps to reduce traffic jams The Dark Knight General Automotive + Other Cars Discussion 3 08-03-2009 04:12 PM
G8 GXP review - wheelhop? rayhawk General Automotive + Other Cars Discussion 45 11-24-2008 05:48 PM
