Old 11-10-2010, 06:54 AM   #15
Gramps
Gramps's Avatar
Drives: 2011 1LT/RJT/Auto/
They make the BEST 6" DA polisher on the market....more power than the PC (for those pesky 6.5" pads), less cost (seem then for $129.00 and they come with a backing plate)...and if that's not enough, they carry a LIFE TIME warranty.
Gramps is offline   Reply With Quote
Old 11-10-2010, 07:15 AM   #16
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
For real? griots uses a black & decker orbital I believe, and it's better than the PC?
h2oplay is offline   Reply With Quote
Old 11-10-2010, 07:31 AM   #17
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
The pc is a great machine but in order to keep the " spider web" look out its pretty much gonna have to be polished several times. I have 6500 miles on my car and use adams double bucket and grit guard setup with all of their mits drying cloth and new white towels. I also now have a foam gun and I was the car with foam 3 times before laying my mit on it. I make one pass over each part of the car and use 2 different pads for top half and lower half. I have clayed polished and got most of the scrathes out with orange pad and hit some with yellow pad and the applied americana wax and 2 months after washing I am back to scratched paint. You cant win with black unless you are a pro and not a joe of the street or if you want to polish your paint away within a couple of years lol. I think both would be good products but for the money I would deff buy the pc again as its my only way to get scratches out. I would buy the soap for sure and wax but other than that. Im over the whole spending 500 bucks on cleaning products when I still get scracthes!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 11-10-2010, 08:26 AM   #18
Junkman2008
"Detailing Devil Dog"
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
I would have to totally disagree with you Gramps and here's why. The difference in power and performance between the Griot's, Meguiar's and Porter-Cable are so small that it doesn't matter which one you buy, they all perform equally. I had a Meguair's representative try and get me to try the Meguiar's machine out but when I got down to the nitty grutty and started asking the hard questions about the performance, he disappeared. As I looked at the numbers, it didn't appear to be more powerful than any other polisher in its class. I have even went as far as to compare the newer PC-7424XP to the older PC-7424 (with 800OPM's less power), and I saw absolutely no difference in the performance. This is why I tell guys with the older PC's to keep them and not upgrade to the newer PC's. You will not see any difference in performance.
Thus, I tell guys to buy the cheaper of the machines if you see a deal on one and you don't have one. They will all work if you use a proper technique. I have found that the PC is always cheaper than the rebadged models. As a matter of fact, Tools-Plus has always had the lowest prices on PC's at anywhere from $109 to $119. The price fluctuates weekly.
Then answer me this. How come I don't have the same exact problem on my car if I am doing everything correctly?
If you are experiencing scratches, then there is something wrong with your process. If I sat down and watched your process (be it washing and drying the car to removing dust from the finish), I bet I could pin point the error in your process. I for one am not going to spend time constantly polishing scratches out of my paint. Once I have removed every scratch in the paint, I am going to do everything possible to not reintroduce any new scratches to my finish. What you have to do is look at your process, especially the parts of your process that involve touching the paint. There is where the flaw lies.
I will say this. You are not going to polish all the clear coat off your car using a PC, unless you use the most aggressive compound known to man and use it every day. The PC is just not powerful enough when you use a product as safe as Adam's Swirl & Haze Remover. You would need to use that product on a Flex or rotary in order to do some damage.
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Old 11-10-2010, 08:42 AM   #19
jsharp
jsharp's Avatar
Because you are a pro with lots of practice. It takes more than just videos to keep scrathes out of a black car when your a beginner. I explained my process above. The only thing I can figure out to keep scrathes out is to not wash it at all lol. I live on a chat road so I get dust as soon as I back out of driveway I never remove it unless I wash it. I am sure you could pin point things yes but I can not think of anything else that I could be doing when washing. I was saying I would have to polishe my car every month and I think after a while that would do something to the finish as far as thinning it but if not then I guess I can start polishing monthly
Old 11-10-2010, 08:55 AM   #20
Junkman2008
Why not make a video of you washing the car and send it to me. It doesn't matter how long it is, I'll watch it. I'm doing a wash video so you will get to see me as I do my car. It really has nothing to do with being a "pro" as it does with having a good process. Anyone can experience the same results that I obtain simply by following my lead. It really is that simple, regardless of how much dirt your car sees. If I can wash this dirt away and not scratch the paint, anyone can.
There is 3 months of dust and dirt sitting on my car in this picture:
Old 11-10-2010, 09:01 AM   #21
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
Great job on the vette junkman and thanks for your input. Its always welcome!
Sent from my DROIDX using Tapatalk
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 11-10-2010, 09:05 AM   #22
Junkman2008
Old 11-10-2010, 09:46 AM   #23
GB EB
GB EB's Avatar
Drives: 2014 Stingray 2LT/Z51
Check this thread for coupon codes to a few different cleaning supply vendors... including adams-
http://www.camaro5.com/forums/showth...63#post2397563
*CAMARO5 CAMARO OF THE WEEK 3/21/11*
*1ST PLACE - NAVAL STATION SAN DIEGO CAR SHOW 4/17/11*
*PEOPLE'S CHOICE AWARD - SAN DIEGO FREEDOM FESTIVAL CAR SHOW 7/4/11*
*TROPHY RECIPIENT - GREATEST SHOW ON TURF 9/11/11*
*1ST PLACE MODERN MUSCLE - CORONADO SPEED FESTIVAL 9/23/11*
*AWARD OF EXCELLENCE - GOOD GUYS DEL MAR FALL NATIONALS 11/27/11*
*1ST PLACE / '82&UP CAMARO/FIREBIRD- FORT WALTON BEACH FF SHOW 2/16/13*
BUILD THREAD: http://www.camaro5.com/forums/showthread.php?t=120353
GB EB is offline   Reply With Quote
Old 11-10-2010, 10:08 AM   #24
jsharp
jsharp's Avatar
I may do that. I just dont know what else to do. Could it be when I dry the car?
Old 11-10-2010, 09:27 PM   #25
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Not a fan of Griot's microfiber products, they have tags sewn into them. Other products I have tried have been ok, but not amazing.
ChadG is offline   Reply With Quote
Old 11-11-2010, 04:32 AM   #26
Junkman2008
It very well could be, however, anytime you touch the paint is an opportunity to damage the paint. Thus, the less you touch the paint, the better it is for the paint. That's why I use a leaf blower to dry my car. That's one opportunity that I have to NOT touch the paint.
Ooh... tags are NOT good. That's surprising to hear.
Old 11-11-2010, 07:15 AM   #27
h2oplay
Winners find a way
h2oplay's Avatar
while we're on the griots subject, I haven't picked up an orbital yet,
should I get the PC or the griots?
Old 11-11-2010, 11:05 AM   #28
Junkman2008
See post #18.
SEMA Show 2010 - New Camaro Products Showcase - pictures & descriptions! Sean@Phastek Camaro Photos | Spyshots | Video | Media Gallery 59 06-23-2011 12:56 PM
DSV Leather & Carbon Products For Serious Customizing!!! (Lots Of Pictures Inside) dsvcustoms Interior Parts & Accessories 31 09-04-2010 01:55 PM
After weekend with Adam's products Wileytrigger21 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 11 07-02-2010 04:23 PM
Griots Garage Grand Opening this weekend in Tacoma SSmoothie USA - Northwest / Pacific Northwest 1 06-02-2010 10:32 PM
garage? Mrbobcat Off-topic Discussions 5 05-07-2008 07:46 PM
