Solo Performance
Old 11-08-2010, 07:51 PM   #1
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
amf lifters?
what do you guys with the l99 about these lifters? Going to take them out when i do a cam swap but there is a cam made for the amf lifters just wanted some feed back
woodside783 is offline   Reply With Quote
Old 11-08-2010, 08:03 PM   #2
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
everyone but a couple of shops will advise deleting dod/vvt and afm. Even if you change they afm lifters out and use vvt cam most shops will still say scrap it its no good. LS3 conversion is your best bet to get good lifters and all new valvtrain components minus rockers
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 11-08-2010, 09:16 PM   #3
tvwilkes
tvwilkes's Avatar
TSP has a line of cams for the AFM cams.
tvwilkes is offline   Reply With Quote
Old 11-08-2010, 09:25 PM   #4
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2018 Silverado
Respectfully disagree... DOD is a definite delete BUT many shops are keeping VVT...
only if you don't change out the lifters are you iimited in cam selections... Put in the LS7 lifters and keep VVT and you have the best of both worlds...
Old 11-08-2010, 10:50 PM   #5
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
ADM performance removed mine when I had my conversion done. I am honestly glad mine are gone that Dam Lifter tick isnt there anymore like it was before when those AFM lifters were there.
Jekyll-N-Hyde is offline   Reply With Quote
Old 11-09-2010, 01:15 AM   #6
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Take those POS AFM lifters out for sure. It will be up to you if you want to keep VVT for more power than the traditional cam but either way remove the AFM all together and make it VVT only or leave some power on the table and just convert to tradition LS3.
Old 11-09-2010, 05:59 AM   #7
jsharp
jsharp's Avatar
vvt is coming around but still most of the shops on here will say get rid of it minua a few. Just saying. I wasnt saying its not good but alot of shops dont know how to use it yet.
Old 11-09-2010, 06:57 AM   #8
woodside783
Casey Woodside
i am keeping the vvt. I want the tsp vvt cam and just wanted to know if it would be worth the money to have the head pulled of and put in the new lifters. Thanks for the feed back
Old 11-09-2010, 07:30 AM   #9
mlee
www.CamaroFest.org
mlee's Avatar
If they say that... then I wouldn't trust them to work on my car period...
Keeping VVT and replacing the lifters are two different things...
If you leave the stock lifters in then you will want to go with a TSP or Mast VVT cam which will be on the mild side and lifter friendly.
Keep VVT and replace the lifters and you can go much more aggressive.
Check out the Torque Convertor threads while you are at it. Best bang for the buck... but you'll need some sticky tires...
Old 11-09-2010, 08:16 AM   #10
jsharp
jsharp's Avatar
So you wouldnt trust adm,lgmotorsports,livernois, or jannetty racing. I didnt say they wouldnt do it but they all have preference for no vvt. I have talked with all of them personally and that is what they told me about a cam.
Old 11-09-2010, 08:36 AM   #11
toehead93
Drives: 2014 2SS/1LE
If I'm not mistaken adm,lgmotorsports, and ivernois all make their own camshafts so of course they are going to say their cam is better and tell you take VVT out. I've seen at least two different engine dyno comparisons of VVT vs non-VVT cams and VVT cams made more power across the board. The reason these shops you spoke to recommend to take out VVT is because they have not invested R&D into developing a VVT cam and they want to sell you their stuff. It is not because non-VVT is better...that much I can guarantee.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 11-09-2010, 08:43 AM   #12
jsharp
jsharp's Avatar
and that is what I said in my first post I never said vvt was good better or the best I said most of those shops will tell you otherwise. I agree they have their own things they do which I also stated in another thread. Actually for power the vvt cam is better price and you can opt for afm delete lifters and have the best of both worlds. So that being said I was just stating what most of the bigger shops on the site would prob say so that way they wouldnt make op feel like its not a good thing.
Old 11-09-2010, 09:41 AM   #13
mlee
www.CamaroFest.org
mlee's Avatar
Pretty sure I'd have to hear this directly from the shops you listed as they are all top notch. Bottom line is the choice is yours and you got my opinion...
BTW we have one or two big shops here in Houston that I have discussed this with. One of which says they always recommend keeping VVT.
Old 11-09-2010, 09:51 AM   #14
jsharp
jsharp's Avatar
whos the shop? I would like to call them as well. I like the idea of vvt. You can look their numbers up and call them and they will tell you like they did me they can do whatever you want but prefer DOD/vvt delete. Trust me I have spoken with all of them several times on the phone. If they would have been ok and in favor of vvt then I would have jumped on it as it is cheaper for the same power. I would liek to call the shop you spoke with and get a qoute.
L99 lifters tapping 2010BumbleBee Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 159 04-08-2015 02:05 AM
LS7 Lifters Styffydawg Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 01-25-2011 11:41 AM
warranty on noisy lifters with a tune? ambjocky Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 09-07-2010 08:51 PM
New Lifters at 30k? azvren Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 09-01-2010 04:01 PM
5 of your biggest complaints with the Camaro Audioi 5th Gen Camaro SS LS LT General Discussions 180 01-16-2010 12:35 PM
