Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection
Old 11-08-2010, 11:53 PM   #1
Gothedoublee's Avatar
Drives: '10 Glossy Dark Grey SS/RS
Cleaning Rims!?
What do you guys use to clean your rims? I have 22' Rennens Chrome Lip Painted Face and I'm thinking just soap and water?
Gothedoublee is offline   Reply With Quote
Old 11-09-2010, 05:31 AM   #2
garcmol's Avatar
soap and water. Just not the same wash pad you use on the car!! For stubborn brake dust buildup, I use Sonax and the Daytona speed brush. That stuff leaves nothing behind and safe on all wheels!
Old 11-09-2010, 07:24 AM   #3
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
Sometimes soap and water will usually not remove baked-on brake dust and road grime. Unfortunately, strong acid and alkaline cleaners can stain some wheel finishes. We do offer a range of cleaners from very safe, pH-balanced cleaners to stronger alkaline and acid-based cleaners. After cleaning, applying a quick coat of car wax will help protect the wheel's finish and make future cleaning easier.
One of the best and recommended by many automakers is P21S Wheel Cleaners. P21S is a safe, pH-controlled, non-acid, non-lye based detergent that provides terrific cleaning and guarantees not to damage any type of wheel: painted, clear-coated, polished or anodized.
P21S Wheel Cleaners are available in two formulas:
Regular Formula P21S - for normally soiled wheels that typically receive frequent cleaning. Spray on, lightly brush or sponge the surface and rinse off with a sharp stream of water.
Gel Formula P21S - for wheels that tend to soil heavily due to higher braking speeds, softer brake pads or infrequent cleaning. Spray on, allow to stand up to two hours, lightly brush or sponge the surface and rinse off with a sharp stream of water. Gel composition clings to vertical surfaces to provide increased cleaning effect.
On brushes with carry many and one of new type of brushes that many around the world want is the Eimann Fabrik Lambs Wool Wheel Woolies.
Eimann Fabrik Lambs Wool Wheel Woolies for Any Opening Size Wheel.
Eimann Fabrik Lambs Wool Wheel Woolies are the perfect tool for getting into those tight areas of your wheels, front grill, door jambs, and just about any other tight spot. Busting knuckles trying to clean your wheels is a thing of the past. Reach the far side of the deepest wheel around.
The lambs wool head on the Wheel Woolies will clean the toughest dirt and grime. Just add your cleaner, or dip it into your wash bucket.
Eimann Fabrik Lambs Wool Wheel Woolies come in three different sizes. The longest Large Wheel Woolie is 19" long and has a 3" diameter wool head. Use this long handled Wheel Woolie to reach deep in the wheels or clean the wheel wells of any vehicle, from cars to motor homes.
The Medium Wheel Woolie is over 12" long with a 2" diameter wool head. This one is great for smaller wheel gaps, air diffusers, door jams, engine areas, etc.
For smaller gaps like grills, the Small Wheel Woolie isn't just for wheels. This one is 8" long and 1" in diameter, but like the others, will shrink into a much smaller gap.
I can't begin to get a wash mitt or sponge into the gaps of my grill. This Small Wheel Woolie is the perfect size to get into the front grill opens to get the bugs and grime completely washed away.
Use Eimann Fabrik Wheel Woolies with any Eimann Fabrik cleaner, such as Eimann Fabrik Tire Cleaner, Eimann Fabrik Engine Degreaser, with just Eimann Fabrik Gentle Shampoo, or with your favorites like P21S Wheel Cleaner.
Wheel Woolies are available individually or in a package of all three.
Only from ProperAutoCare!...........
Which Drag Radials & Rims to use ??? 2010 Bumblebee Wheels and Tires Talk Sponsored by The Tire Rack 23 11-30-2011 06:38 PM
Cleaning my 20" 2SS rims Bone 5th Gen Camaro SS LS LT General Discussions 16 06-04-2010 01:22 PM
Good at finding rims and eyeing what it'll look like? HELP! DChan Wheels and Tires Talk Sponsored by The Tire Rack 8 05-11-2010 03:44 PM
Car coming with wrong rims, what to do? mwoodengr Camaro Price | Ordering | Tracking | Dealers Discussions 22 07-04-2009 02:19 PM
18" rims vs 20" rims...Why go smaller? edog Wheels and Tires Talk Sponsored by The Tire Rack 32 01-17-2009 02:42 PM
