Emblempros
Old 11-09-2010, 08:41 PM   #15
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Mustang dyno add different loads such as wind drag and other road frictions and is usually more accurate to real road conditions. However, dyno's are a tool for seeing improvements and benefits of mods. I use dynojet not because it has higher numbers but because that is my baseline choice and location. Also I prefer the large drum vs. twin rollers to avoid pinch. dyno numbers are for show, and track times are for the dough!
And I am always up for a good race.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 11-09-2010, 09:20 PM   #16
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
Originally Posted by mikeSS View Post
no i really want to know what i would run on a dyno jet.. no joke ...
look at tjbusa numbers.. with only a CAI and exhaust.. and a canned tune.. not even a dyno tune.. stock LS3 numbers are like 350-360 whp ... he gained over 60 WHP with that setup come on dude ..
The exhaust is a full system and the tune was adjusted and saved to my predator, Mike its not so much the numbers but getting the fuel trims for cruise and WOT just right and you will get the most power out of what mods you have. Please, guys.... just post your dynos
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 11-09-2010, 09:51 PM   #17
mikeSS
mikeSS's Avatar
Drives: 2015 c7
o my bad i didn't see the LT part. you cant blame me i have seen some people here with my really high numbers on dyno jets..
this one guy i remember said he got 400WHP with a muffler delete and CAI + tune on a dyno jet.. which is way to high
Old 11-10-2010, 01:04 AM   #18
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
i would love to run my car on a dyno jet like everyone else to get some high numbers..
You can never prove dyno results right or wrong, but for comparison and for piece of mind (yours and mine):
We ran both LS9s and LS3s on the very same dyno:
Diablo-Tune and a CAI -> 375rwhp (LS3) - 358rwhp (L99)
Stock L99 -> 340rwhp
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 11-10-2010, 01:36 AM   #19
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
C.A.I. intake
ARH L/T headers with high flow cats
Pypes 2.5" full exhaust
Custom tune
Baseline: 401 HP @ 5550 RPM / 408 TQ @ 4700 RPM (with CAI + Predator canned tune)
Full Exhaust: 426 HP @ 5550 RPM / 427 TQ @ 4700 RPM
Tune equipment: DynoPack
Name:  2010.08.12 resize dyno.jpg
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 11-10-2010, 03:00 AM   #20
GM4lyfe
A GM nut-swinger!
GM4lyfe's Avatar
Drives: A Car
Originally Posted by Camaro21 View Post
Thanks to Andy at ADM Performance:
Magnusun Magnacharger TVS 2300 package
ADM Performance Stage II Cam
ADM Performance Street Cold Air Intake
1 7/8 Kooks Headers with High-Flow Cats
Muffler Delete with MagnaFlow Tips
ADM Performance Custom Tune
MGW Short Throw Shifter
3.70 Rear End Gears
BMR Rear Trailing Arms
BMR Rear Toe Rods
Eibach 1" Drop Springs
Eibach Front and Rear Sway Bars
Nice numbers. Numbers like that make me want to sell my car
2004 GTO Quicksilver
2009 G8 Liquid Red
2005 CTS-V Black Raven
GM4lyfe is offline   Reply With Quote
Old 11-14-2010, 11:14 AM   #21
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
OK here are my results with K&N intake, OBX LT's, no cats, and no mufflers.
Warm up pull and then 2
Here are the vids....sorry the audio was terrible on my phone as it was soooo loud :(
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 11-14-2010, 11:58 AM   #22
steeleshark2
steeleshark2's Avatar
Nice!! What altitude are you at? If at Phoenix AZ just over 1000ft, then add in the correction and you numbers will be right with my numbers as I am at sea level.
Old 11-14-2010, 02:52 PM   #23
zcon
Drives: G35
339 WHP on a mustang dyno, full bolt ons.
zcon is offline   Reply With Quote
Old 11-14-2010, 02:58 PM   #24
Huggerorange73
Banned
Drives: The REAL C5
Send a message via AIM to Huggerorange73
Mods : Comp Cams XR281HR13 .571/.590 228/240 on a 113 LSA, Kooks 1 7/8" longtubes w cats, Roto - Fab CAI, SLP LM II Axle back, tuned by Straightline Performance on a Mustang Dyno 470 rwhp/423 rwtq
Car was baselined bone stock on the same dyno, this sheet shows the baseline pull with the post mod pull.
Huggerorange73 is offline   Reply With Quote
Old 11-14-2010, 08:40 PM   #25
bowtienick
bowtienick's Avatar
Drives: 2010 ss m6
I had my car dyno tuned by Gforce motorsports. mods are stainless works 2" long tubes and or pipe extensions, magnaflow 2.5 catback street series, airaid cai. rwhp came in at 434 and rwtq came in at 425. Needless to say I am pleased.
bowtienick is offline   Reply With Quote
Old 11-15-2010, 01:08 PM   #26
MillerTime
MillerTime's Avatar
Not bad for a G35!!
2G1FS1EWXD9163847
Old 11-15-2010, 01:09 PM   #27
MillerTime
MillerTime's Avatar
Yup Tempe AZ is where Loud Pedal Motorsports is located. I'm pretty happy with my #'s Realistic IMO...
2G1FS1EWXD9163847
Old 11-15-2010, 01:12 PM   #28
MillerTime
MillerTime's Avatar
Some good #'s there. I'm waiting a year or two at least to throw in a cam...can't wait though!!
Good #'s!
2G1FS1EWXD9163847
LS3 dyno results TinyToasta Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 05-14-2012 08:14 AM
LS3 and L99 engine dyno test ULTRAZLS1 5th Gen Camaro SS LS LT General Discussions 20 09-27-2010 11:52 AM
Texas Speed Engine Dyno L99 Baseline Vs. LS3 Baseline Jon@Texas-Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 07-21-2010 03:55 PM
What's the highest HP/TQ dyno #'s on the site for a STOCK LS3? topgun1 5th Gen Camaro SS LS LT General Discussions 38 03-24-2010 08:57 PM
My dyno #'s on a stock LS3 victoryred1ss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 03-18-2010 04:05 PM
