JDP Motorsports
Old 11-09-2010, 05:06 PM   #1
metallicide
metallicide's Avatar
Drives: 2010 Camaro 2SS
best budget headers?
Hey curious what would be the best budget headers for around 800-1000 with converters? And what is the benefit of a pricier header? I know the coated ones last longer and do they also put out less heat?
metallicide is offline   Reply With Quote
Old 11-09-2010, 05:37 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The 2 biggest reasons some headers cost more are:
1) Where they are made. USA versus God knows where.
2) What they are made of. The better headers are made of 304 stainless. They are corrosion resistant and lighter without coating. Cheaper headers will use cheaper material that will corrode and they have to be coated. Like most things, you will get what you pay for but that doesn't mean you have to over pay.
There is a really good article getting ready to be posted on TheHorsePowerJunkies.com sometime this week about selecting headers. If you have any questions feel free to hit me up.
Old 11-09-2010, 05:38 PM   #3
Shrek
Shrek's Avatar
Drives: 2013 Camaro ZL1
Don't go cheap. Go with KOOKS. Check out IPS motorsports. Give them a call and they can hook you up
2013 Camaro ZL1 Black M6
Roto-Fab Intake, Apex Catch Can, Stainless Works 2" long tube headers with cat delete, Stainless Works 3" retro chambered catback, ATI Super Damper with 10% overdrive lower pulley, tuned by JRE. Sitting on Black MRR 228's wrapped in MT's.
Shrek is offline   Reply With Quote
Old 11-09-2010, 05:52 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
http://www.camaro5.com/forums/showth...&highlight=bfe
or go with KOOKS from Maryland Speed.
Personally I would tell you to spend the extra money for the ceramic coating. Not for performance but for looks.
Build Journal
Old 11-09-2010, 05:57 PM   #5
steeleshark2
steeleshark2's Avatar
OBX!! Although they are Chinese made, they seem to be very good for the price and they are stainless. PMed.
Old 11-09-2010, 08:43 PM   #6
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
Originally Posted by Apex Chase View Post
There is a really good article ...
this one
Apex Paul is offline   Reply With Quote
Old 11-09-2010, 08:53 PM   #7
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
Turn off the lights and see if the OBX glow.......
I went with coated Kooks from Maryland Speed.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 11-09-2010, 08:55 PM   #8
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Here you go... Polished...
http://www.bigflowexhaust.com/camaro_2010_exhaust.shtml
Old 11-09-2010, 09:02 PM   #9
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
I got Doug Thorley tri Y long tubes for 508 and 35 shipping. Magnaflow high flow cats 75 ea. Ceramic coated inside and out. 1 3/4 inch but they way they scavenge exhause they are equal to a 4 1/4 collector. Plenty of exaust for my little 418 stroker with 700 plus rwhp. Fits into stock exhaust as well with no problems.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 11-09-2010, 10:04 PM   #10
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
It's been speculated that OBX headers are made overseas but that has never been proven. There were no "made in China" stickers anywhere on my OBX headers, original box or instructions.
Regardless, OBX are the best best priced long-tube stainless steel headers out there for the 2010-2011 Camaro.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 11-09-2010, 10:21 PM   #11
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
^I'm most likely going with these.
Not the cheapest of them all, but seem excellent for the money. Waiting for the mid-pipe to be available. I think they'll be coming with a 3" axleback later to finish it off.
My back up selection right now is BBK's that are coming out. You can use anythingauto.com 15% off coupon to get the silver ceramic coated version for $722 or full SS for $849. That's headers, cats, and x-pipe. My only reservation is they're 1.75", but I'm not sure it's a big difference for that 1/8".
There's also that XS Power system in the vendor classifieds. Full 3" header to tip for $850. I just prefer to have bolt in cats.
IMO, the only problem with these budget brands is they're all newer, so there is a bit of risk. I decided against OBX because by the time you add some Kooks cats, they're not really that inexpensive. (would pay a few hundred more for some Dynatech or Stainless Works).
xxlbeerz is offline   Reply With Quote
Old 11-10-2010, 01:58 AM   #12
Ivan @ Southwest Speed
Value per dollar....
Doug Thorley 1 3/4 Tri Y's.....Made in USA...Ceramic Coated....Lifetime Warranty. Nothing more, nothing less.
Lemme know if you need a set....we have em ready to ship out!
Old 11-10-2010, 06:10 AM   #13
metallicide
Thanks guys....ill go with kooks if I win this 200 dollars off, maybe even if I dont, but the doug thorelys sound pretty nice too.
Old 11-10-2010, 06:15 AM   #14
xxlbeerz
xxlbeerz's Avatar
Thorley doesn't have cats.
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 100 11-13-2010 03:51 PM
The truth about Shorty Headers JoshJ81 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 33 02-20-2010 01:44 AM
2010 Camaro American Racing Headers FREE Shipping MoranoRacing V8 Bolt-Ons & Tunes 2 02-10-2010 08:45 PM
Doug Thorley headers and axle-back ROCKS! SPANKT U Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 01-07-2010 10:36 AM
