Cold Air Inductions
Old 11-09-2010, 08:03 PM   #1
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Best Oil to quiet engine?
From what I understand, our cars are loud engines to begin with... And with the afm lifters it's a slight annoyance...
What my question is, is there another brand of oil that quiets the engine, while still performing as well as mobil 1? I hear alot of people recommending royal purple or amsoil... But will those oils make a difference in sound?
Thanks
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 11-09-2010, 08:06 PM   #2
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
I would like to say yes... but I'd be doubtful. Im sure to some degree it would quiet it down a hair but you'd still hear the noise i'd bet on it.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 11-09-2010, 08:18 PM   #3
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
I live in Texas... So could I switch to a different weight?
Old 11-10-2010, 12:10 AM   #4
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
I've already done a search, and couldn't find anything... Does anyone have any insight into this question?
Old 11-10-2010, 12:13 AM   #5
sspaul
sspaul's Avatar
Drives: 2010 ss camaro, imperial blue
Send a message via AIM to sspaul Send a message via Yahoo to sspaul
i don't think changing oil will quiet your motor down
my youtube
my facebook
www.myspace.com/1djchampagne
www.twitter.com/1djchampagne
mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune
750/641 rwhp/rwtq
sspaul is offline   Reply With Quote
Old 11-10-2010, 02:29 AM   #7
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Not sure about the engine but I know for a fact RP in the trans and diff will definitely quiet down the gear and drivetrain noise inside the car. I have RP in everything so I can't say how much an effect it has in the engine since I don't really hear it much over the exhaust.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 11-10-2010, 02:30 AM   #8
Entaille
Drives: 2011 Camaro 2SS/RS
Originally Posted by sterlingnotes View Post
You just need to make the exhaust louder!
this is your answer. you wont listen to the slight noises your engine makes if your exhaust tone is a little louder : )
Entaille is offline   Reply With Quote
Old 11-10-2010, 07:15 AM   #9
destroyerofu2
xbox360 tag
destroyerofu2's Avatar
Drives: 2010 inferno orange 2SS
i find that lifter noise to be annoying also
but about 3 months ago i found a salution
onlycost me about $100
i took it to a shop and had them remove my mufflers and now i still hear the noises at idle if the hoods open but at wot (wide open throtle) or ftf (foot to floor) all i hear is the awsomeness of every thing i have ever dreamed of in a car comming to life and how sick (good sick not bad sick) it is
yea you could probly get a thicker oil and it would quiet it down a small bit but i wouldn't recomend useing any other oil than what the dealer recomends (void waranty and such
Originally Posted by babytiger
And like destoryerofu2 said, WOT should be a moment of silence...
It's mine, like it or not. http://www.camaro5.com/forums/showthread.php?t=108079
destroyerofu2 is offline   Reply With Quote
Old 11-10-2010, 11:12 AM   #10
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
German Castrol has been a great LSx oil for years,, only certain stores still have it in stock,, read the back of the bottle and make sure where it is made
Old 11-10-2010, 02:06 PM   #11
westexas
Drives: 2010 CAMARO SS L99
Somebody on here was saying GM came up with some new lifters for our L-99's and that they are much quieter.
westexas is offline   Reply With Quote
Old 11-10-2010, 05:40 PM   #12
Ject
aka Patrick
Ject's Avatar
That is correct, if anyone has excessive lifter chatter on a L99, GM recommends replacing with an upgraded AFM lifters.
OP can always check with dealership and let them know. There is a TSB somewhere on it.
Old 11-10-2010, 05:44 PM   #13
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Just popping in to say that a heavier weight oil would not be a good idea on an AFM car.
Robert91RS is offline   Reply With Quote
Old 11-10-2010, 06:43 PM   #14
JS
JS's Avatar
Drives: 2010 Camaro SS
KENDALL ULTIMATE 5/30
VERY GOOD OIL
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned
JS is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 05:15 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 08:37 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
