Grabiak Performance Center
Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions.
Old 11-09-2010, 07:56 PM   #1
tcarro2001
Drives: 2010 Black 2LT/RS
Problem with GM MTX subs
I have the GM MTX subs mounted in the trunk. They were installed by the dealer. Well everything was fine for about 2 weeks (warm everyday) now I am having an issue. In the morning when it is below 45 degrees outside the subs do not work. After work when the temp is well above 60 degrees the subs work perfectly.
The cold weather is the only thing that I can think of that is a possible variable.
One evening I turned the car to on where it is parked at night and it worked great, the next morning (cold outside) it turned the car on, without cranking it both times and the subs did not work.
Any suggestions. According to the installation instructions there is no soldering or anything involved only plugging connections, so I am stumped.
PLEASE HELP
tcarro2001 is offline   Reply With Quote
Old 11-09-2010, 10:13 PM   #2
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Sounds like the wiring at one of the circuits/connections is contracting as the weather cools overnight leading to an "open" circuit. When the weather warms throughout the day, the metal at the open circuit expands and closes the circuit and power flows once again to the subs. You're going to have to check for continuity and find where the circuit is "open" when the subs aren't working.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
USB Port problem w/ Ipod touch Arsenal11 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 06-03-2011 06:42 PM
Found a problem with my camaro Agostino13 5th Gen Camaro SS LS LT General Discussions 19 04-27-2010 11:59 AM
pm problem drivingincamaro Site Related Announcements / Suggestions / Feedback / Questions 4 06-23-2009 10:20 PM
Somewhat Annoying Back Seat Problem! ZNOLMT 5th Gen Camaro SS LS LT General Discussions 5 06-21-2009 09:22 AM
Problem with my v6 TonytheTiger 4th Generation Camaros 12 08-22-2008 02:34 PM
