Flowmaster Exhaust
Old 11-10-2010, 03:29 PM   #1
x7productions
x7productions.com
x7productions's Avatar
Drives: 2010 BMW E92 3-Series Coupe
Send a message via Skype™ to x7productions
AAC Afterburners + Parking Sensors - Problems?
Hey I want to know if anyone out there has a combination of AAC Afterburners + Parking Sensors.
If so, are you having any issues with your parking sensors?
The day after I wired in my Afterburners (they installed the Halos in the taillights), my parking sensors started malfunctioning when the afterburners (parking lights) were on. Basically, if they were on, when put in R, the DIC will display "Park Assist Off!" and won't work at all. When the lights are off they function properly.
Took the car to the dealer. Back and forth for two weeks and they have no idea what maybe causing the issue, after AAC told me they had one other person with this issue and they took it to the dealer and got it fixed. AAC suggested I go to the dealer to see whats up. But no luck. They even did updates on the software/firmware.
So this is making me think its the Afterburners (which are powered by a 1000 watt/volt or something inverter box for each pair). They are wired following the AAC pdf, which says to connect to the ground and parking wire on each tail light harness.
BUT, I just want to know if anyone else here has these AAC Afterburners along with Parking Sensors, if you are or are not having any issues, and if you are, did you ever get them resolved.
I'm not bashing AAC, I'm just doing research to see if this problem or setup has happened before. And if there are any solutions since no one I've spoken with has given me a direct answer or viable solution.
Watch Camaro : Heritage - Featuring over ten Camaro5 Members' 2010/2011 Camaros!
http://www.camaro5.com/forums/showthread.php?t=158574
Go like our Facebook Fan Page!
http://facebook.com/x7productions/
x7productions is offline   Reply With Quote
Old 11-17-2010, 01:44 PM   #2
x7productions
x7productions.com
Bump
Old 11-17-2010, 05:31 PM   #3
Eric Baker
Drives: Black/Black 2SS/RS 6M
It sounds like they're not wired in correctly and are back feeding into something, or causing some kind of unwanted noise in the cars wiring.
Eric Baker is offline   Reply With Quote
Old 11-18-2010, 12:35 PM   #4
x7productions
x7productions.com
Yeah thats what I thought... I checked and rechecked and its wired correctly per their instructions. They suggested I add a diode, so I have to call them up for more details on that. Hopefully that solves it. Idk.
Old 12-30-2010, 08:59 PM   #5
agkelly73
agkelly73's Avatar
Drives: 2010 2SS/RS
Did anyone ever figure this out? I just installed my AAC Afterburners today, the CCFL type and I'm having the same issue now.
agkelly73 is offline   Reply With Quote
Old 01-03-2011, 11:12 AM   #6
x7productions
x7productions.com
Interesting. They told me I must have wired it wrong. But I checked and rechecked and my wiring was correct. I ended up selling the afterburners and going back to stock because I'm looking to sell the car soon. But yeah, now that I see someone else has the same issue, I'm assuming this is a serious problem... UNLESS WE BOTH WIRED IT WRONG!!!
Old 09-04-2011, 03:18 AM   #7
Andys562
Andys562's Avatar
Drives: Black 2011 2LT RS
anyone still having this issue? any solutions?
Andys562 is offline   Reply With Quote
Old 05-11-2013, 11:19 AM   #8
camarohwk23
Camaro5line
camarohwk23's Avatar
Drives: 2012 Synergy Series 2SS/RS
Was there ever a solution to this because I am having the same problem??
camarohwk23 is offline   Reply With Quote
Problems with AAC? KowalskiCamaro Vendor and Seller review / feedback / experiences 5 06-15-2010 02:40 PM
Camaro Accessories from AAC, problems anyone? chrislhardin Vendor and Seller review / feedback / experiences 1 04-14-2010 06:54 PM
AAC P13W Problems?? chrisgalles Cosmetics and Lighting Modification Discussions 10 03-09-2010 01:42 PM
Front parking sensors Oneday 5th Gen Camaro SS LS LT General Discussions 50 09-17-2009 08:50 PM
Thought about rear parking sensors? Scotsman 5th Gen Camaro SS LS LT General Discussions 30 08-31-2008 12:44 AM
