Old 11-10-2010, 06:57 PM   #1
Ironfall96
Ironfall96's Avatar
Drives: IBM 2 SS/RS
Unhappy CELs After Tune
Here's the story. After I installed my headers/exhaust my CEL came on. Since I have no cats, and I took out the rear o2 sensors, I just figured that was the CEL. I got a SCT tuner from Jannetty and uploaded his custom tune and wah-la, CELs are gone. But after a day my check engine light came on again so I went to AutoZone to get it checked out. Here are the codes.
P0036
P0056
P0140
P0141
P0160
P0161
The guy said they were all exhaust related, but if Jannetty got rid of the O2 senors where are these coming from?
If someone could show me where I could find out what these codes are it would be much appreciated. Would it be fine to just make the codes go away with the SCT tuner or should i worry about these codes?
Ironfall96 is offline   Reply With Quote
Old 11-10-2010, 07:36 PM   #2
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Go to google and enter the pxxxx trouble code and it should give you the cause and pernaps the cure on OBD II ECM's. You do have numerous exhaust codes. You might want to check again with Ted to see if he was aware of all exhaust parts you eliminated and wanted him to correct with regard to the tune and headers and new exhaust.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 11-10-2010, 07:54 PM   #3
1 BAD RS 2 SS
1 BAD RS 2 SS's Avatar
Drives: 2010 RS 2 SS
P0036 - HO2S Bank 1 sen 2 Heater Circuit
P0056 - HO2S Bank 2 sen 2 Heater Circuit
P0140 - O2 sensor ckt no activity ( bank 1 sensor 2 )
PO141 - 02 sensor heater circuit malfunction ( bank 1 sensor 2 )
PO160 - 02 sensor ckt no activity ( bank 2 sensor 2 )
PO161 - 02 sensor heater circuit malfunction ( bank 2 sensor 2 )
OBD code's
sounds o2 related , call your tuner and talk to then . thay will know how to help
1 BAD RS 2 SS is offline   Reply With Quote
Old 11-10-2010, 08:39 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Talk to Ted and see what he says.
Build Journal
Old 11-10-2010, 08:57 PM   #5
Infern0
Bring It
Infern0's Avatar
Drives: '17 Camaro ZL1 (M6)
Yeah that. Seems like a logical first start seeing how he's been selling these to very happy customers for a while now with good rep for helping resolve issues.
He hasn't got my money yet, but it's coming based on that alone. Now if only he sold Kooks.
Infern0 is offline   Reply With Quote
Old 11-10-2010, 11:46 PM   #6
caverman
caverman's Avatar
Call around and get prices....then call Maryland Speed and you'll see. Their's is the best prices I've found from an Authorized dealer.
Build Journal
Old 11-11-2010, 01:32 AM   #7
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
All of those are rear o2 sensor codes.
Ovenmitt is offline   Reply With Quote
Old 11-11-2010, 01:38 AM   #8
Ironfall96
Ironfall96's Avatar
Drives: IBM 2 SS/RS
Hey guys I googled the problem and found a post on C5 with the same codes I had. Ted commented saying when he turns off the rear senors, he expects the owner to keep the senor plugged in and zip tied somewhere I'm guessing. I on the other hand took both sensors off and stored them in the garage. I'll have to contact Ted so he can turn these off.
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 05-18-2013 11:01 PM
Dyno tune comparisons? vernal Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2010 11:43 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
SS A6 or M6 faster?????? MY2010SS 5th Gen Camaro SS LS LT General Discussions 275 05-20-2010 05:15 PM
Lets play a game 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 56 09-26-2009 10:08 AM
