Old 11-10-2010, 07:52 PM   #1
john468
Drives: 1968 S.S. Big Block and 2010 SS
Headers
I have read that headers set a code because of the O2 location but can't we move the O2 ourselves to another spot, like weld a new bung on or something? there has to be a way to prevent it other then a tune? Also what would happen if you just drove with the light on and don't put a tune in so that the dealer can't say anything. What would the effects be?
john468 is offline   Reply With Quote
Old 11-10-2010, 08:00 PM   #2
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
You can't move the the cats to their stock location with long tubes, leaving the CEL on is annoying and then you won't know if there is another problem if it comes up.
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 11-10-2010, 08:05 PM   #3
steeleshark2
steeleshark2's Avatar
Get 2" bung extensions that screw into the o2 bung and you will have no problems. It will pull your sensor out of the exhaust stream and read fine.
Old 11-10-2010, 08:17 PM   #4
tjbusa
Serious Sleeper
tjbusa's Avatar
That does not address the aft sensors, they are further away from their stock locations and thats why they fault... Is that not right?
Drive-by
Fact of Life:
W T F
Old 11-10-2010, 09:54 PM   #5
john468
So will anything happen if you just leave the light on? Will it run ok? How about running a pipe and then a coupling to screw the o2 into so that its pretty close to where the factory o2's where? Just a idea
Old 11-10-2010, 10:02 PM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i heard the car runs weird without tuning it with headers
Old 11-10-2010, 10:12 PM   #7
barnesql
Drives: 95' Z28, 2010 2ss RS
TJBUSA is right, the 02 sensors are now in a different spot, and will throw a code with any LT headers. I suppose you could somehow drill in a threaded hole for an 02 sensor if you want....but most guys have them turned off when they get a tune. But it is not the cats I do not think that throws a code...just the 02 sensor.
I have had my headers and new catback on for about 3 weeks, but I needed a new camshaft and my tuner wants me to wait a tad longer before I get it tuned. It seems to run fine without a tune, but I am sure I am missing out on some power until I do.
2010 Camaro SS - LS3
Magnaflow 3" Competition Series Catback
Off road x-pipe
Kooks LT Headers
barnesql is offline   Reply With Quote
Old 11-10-2010, 10:19 PM   #8
tjbusa
Serious Sleeper
tjbusa's Avatar
Other than you not knowing if another engine code developed a more serious issue, no
The problem with the CEL and headers is the aft sensors are downstream of your cats are now a further distance away from the exhaust maniford and the factory sensors can't perform like they once did.
Drive-by
Fact of Life:
W T F
Old 11-11-2010, 12:37 AM   #9
steeleshark2
The o2 sensors throw a flag because of what it is sensing. With it pulled out of the exhaust stream, it does not sense it so the cel light does not trigger from what I have heard. I do not have this setup, but hear a few on here do have LT headers the the extensions and no Cel light and no tune.
Old 11-11-2010, 12:44 AM   #10
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Nope. Mine runs fine. I have a light. No issues. I want the light gone, but I just don't want to tune yet.
Old 11-11-2010, 02:23 AM   #11
sting808
Drives: 2010 SS RS
Tag,
I remember reading a thread where you reset the CEL and after a couple resets, the light didn't return. I jut installed ARH on my mbrp 3" and CEL came on quick. I cleared it 2 times. Worth clearing again?
This is temp since FI will be ordered within a month and it will be tuned.
sting808 is offline   Reply With Quote
Old 11-11-2010, 08:11 AM   #12
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Installing long tube headers without a tune is kinda like buying a new pair of running shoes, putting them on but not lacing and tying them. You'll not experience the full benefit of either.
2SSCAMARO is offline   Reply With Quote
Old 11-11-2010, 08:41 AM   #13
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Mine also runs fine with O2 extenders (rear) and no cats and no tune. Bunch of misinformation in this thread...
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 11-11-2010, 08:57 AM   #14
tjbusa
Serious Sleeper
tjbusa's Avatar
The extensions you speak of are needed because the aft sensors are too far away for the stock harness to reach. Its all about heat.
Drive-by
Fact of Life:
W T F
Review / Installation of OBX Long-Tube Headers! Hicompression Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 215 04-25-2011 12:09 AM
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 100 11-13-2010 04:51 PM
2010 Camaro American Racing Headers FREE Shipping MoranoRacing V8 Bolt-Ons & Tunes 2 02-10-2010 09:45 PM
Doug Thorley headers and axle-back ROCKS! SPANKT U Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 01-07-2010 11:36 AM
