Old 11-10-2010, 09:20 PM   #1
GATORSS
Drives: 2011 IBM 2SS/RS
HELP PLEASE!!
Just installed the Air Raid cold air kit on my car and went to take it for a test drive. Nailed the gas and the car revved up like the transmission was slipping. I didn't disconnect the negative battery cable when installing. Could this cause it. (Wife's car with 900 miles.....she's gonna whoop me if I don't figure it out)
GATORSS is offline   Reply With Quote
Old 11-10-2010, 09:26 PM   #2
Supercharged SS
Drives: 2010 Camaro
Make sure everything is good with the maf!!! Is it plugged in, in the right location, that kind of stuff. Any maf issue will play havoc, even with the trans. I've had it happen to me. My guess is that what's up. Gd luck!!
Old 11-10-2010, 09:28 PM   #3
midnighter
Drives: nothing
Sounds serious.....the woop by the wife part.
Old 11-10-2010, 10:08 PM   #4
GATORSS
All is good(won't be sleeping on the couch...at least not tonight)! I have no idea what the deal was. I had left the key in the ignition as well as turned the TC off as I was backing out of the garage. Came home and checked all the hoses as well as MAF and it was all okay. Removed the key. Let it sit for about 5 minutes and went back out in it. Stopped, turned the TC off again and proceeded to blow the tires off it. Cold air kit and 50 degree temps means good power! Now for the headers and a tune
Old 11-10-2010, 10:13 PM   #5
oldfriend
Drives: Fiat 500 E
2ss
YOU ASKED FOR ,DIDN'T YOU :mad0 259:: mad0259:
Old 11-10-2010, 11:49 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
Build Journal
Old 11-10-2010, 11:52 PM   #7
caverman
caverman's Avatar
I know you said all is good now but for those adding a CAI....after install you should drive the car around normally for 5-10 min. Give the car time to learn and adjust for the new air flow. Then give it HELL!
Just for grins you might do either a fuse pull or disconnect the battery over night. Then again, drive it normally for a little bit to let the car learn and make adjustments.
Build Journal
