R1 Concepts
Old 11-10-2010, 08:21 PM   #1
JProberts
Drives: 2SS RJT RS/Sunroof
Impressions of Pedders lowering springs?
For everyone here that have the Pedders lowering springs what are your overall impressions, good and bad?
What drop did you go with and what noticeable difference do you feel in the cars ride and handling with the lowering springs?
Thanks
JProberts is offline   Reply With Quote
Old 11-10-2010, 09:35 PM   #2
formare
Suspension by Pedders
formare's Avatar
Drives: Synergy Edition 13.71@102 1.95 60'
I have them. Lowered about an inch. Makes a big effect on the looks. Rides a bit harsher but not too noticeable after a month or two it is softness up.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 11-10-2010, 10:19 PM   #3
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Formare, I have a v6 also and am on the fence on the springs,will go Hotchkis if I do. My question, and this may help the OP, except he has an ss, is how are they reacting with the v6 shocks as I'm not sure if they are the same as the ss shocks as far as the control they will have over the stiffer lower springs? I have been on a lowered 98 for 11 years and with konis adjusted on soft ride is like stock untill you hit a bump or bad road then the reaction is firm and abrupt, how does the 2010 react to the bad roads we have? And how do springs soften up? Never had that happen before.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Pedders Supercar coilovers and Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 11-11-2010, 02:40 AM   #4
DMSDesign
Suspension Specialist
Drives: 2011 Camaro
I do not think they soften up. I would bet you become accustom to the sportier ride
mike
dms
DMSDesign is offline   Reply With Quote
Old 11-11-2010, 09:23 AM   #5
JProberts
Thanks for the information. You mentioned ride feels a bit harsher but did the handling of the car change at all? Does it feel more planted to the road since it is lower now?
Thanks formare
Old 11-11-2010, 11:43 AM   #6
YOOG
Drives: 2013 1SS LS3
The difference in handling is amazing. The ride only seems harsh if you hit a really bad bump or pothole. Highly recommended!
Dual Mode Exhaust | 6 Speed Manual | CAI Intake| BMR 1" Springs| Factory Reproductions 9" wheels
YOOG is offline   Reply With Quote
Old 11-11-2010, 10:22 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I've been on them for about 2mo now. Loved them since the day they went on. The ride is definitely stiffer but like someone else mentioned, it's only when you're on very rough roads. Driving on the intersate is smooth as a babies bottom. IMO the OEM setup was very soft and had little feel for the road. Now the car is better planted yet still rides very well. I've since added the front and rear sways for an AMAZING feel when cornering. The car feels like it knows what it's suppose to do and does it. I look down the hood line and it doesn't change in the corners. Stays flat as a pancake. I didn't measure the drop but it's right where I like it. I let a local C5 member (Captain Mcfunk) ride and drive mine and he ordered his Pfadts that week. I highly recommend the springs and sways combo.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-11-2010, 10:36 PM   #8
GJG
GJG's Avatar
Drives: 2SS
Sleep well America.....my MARINE has your back......
GJG is offline   Reply With Quote
Old 11-11-2010, 10:55 PM   #9
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
I've installed most of the springs out there including the Pedders springs. They dropped the cars we've done about 1" and the ride is firm but not harsh. Most of the tier 1 companies have the rate dialed into the factory damping, no Honda on drop springs effect!
Please feel free to call, email or PM me anytime with questions. Have a good one and good luck!
Kind regards,
Jordan Priestley
888.308.6007
Click HERE to send me a PM | jordan@jdpmotorsports.com | www.jdpmotorsports.com | 801-545-4215
JDP Motorsports is offline   Reply With Quote
Old 11-12-2010, 08:28 AM   #10
JProberts
Originally Posted by GJG View Post
love mine.....i believe the ride actually improved.....put on the sway bars as well......handles incredible!!!
Kind regards,
Jordan Priestley
888.308.6007
Thanks for the informative feedback guys, this was exactly the type on information I wanted and hoped to hear.
The feedback and input I get from everyone on this forum is great! Don't know what I would do without C5 member feedback.
Thanks
Old 11-12-2010, 08:47 AM   #11
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Look at BMR and MTI products.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 11-12-2010, 10:14 AM   #12
JProberts
Ed M.
Too late but thanks Ed M.
Old 11-12-2010, 10:28 AM   #13
JDP Motorsports
I believe the OP was looking for feedback on the Pedders springs but yes, the Pfadt product is top notch!
Thanks
No worries! Please feel free to call, email or PM us anytime with questions. Have a good one and you'll enjoy the new stance and ride!!!
Kind regards,
Jordan Priestley
888.308.6007
Old 11-12-2010, 12:04 PM   #14
axis
Search Ninja
axis's Avatar
Sorry, my bad. For some reason I thought it said Pfadt. Guess I need those glasses sooner than later.
Halltech CF 102 fed
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Where are Pedders coilovers made? g-townmach Suspension / Brakes / Chassis 69 05-03-2010 12:44 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
