Solo Performance
Old 11-11-2010, 07:51 PM   #1
fitzi7
Drives: Camaro
What's up with tap shifter users
I keep reading post after post about the problem people are having with the tap buttons and where they are located. There is a solution and it his right here in front of you. I purchased the shifter from CFD (found on this website) and you can not believe the difference in my ability to be able to shift under all circumstances no problems. Read the feedback from others not a negative feedback. They may not be fancy but they are effective.
fitzi7 is offline   Reply With Quote
Old 11-11-2010, 08:01 PM   #2
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
its a syn is offline   Reply With Quote
Old 11-12-2010, 07:17 PM   #3
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 11-13-2010, 12:14 AM   #4
I have no problem at all with my tapshift, I love it and use it every time I drive my Camaro.
Old 11-13-2010, 12:17 AM   #5
midnighter
Drives: nothing
LS3 here so , but interesting thread topic nonetheless.
Old 11-29-2010, 02:30 PM   #6
highline
highline's Avatar
Drives: LS
subscribed
highline is offline   Reply With Quote
Old 11-29-2010, 02:40 PM   #7
CFD
Drives: 2SS/RS L99 BLACK
The op has experienced shifting without chasing buttons.
CFD is offline   Reply With Quote
Old 01-06-2011, 10:56 PM   #8
Warhorse
Warhorse's Avatar
Drives: 2011 Syn Green Camaro
Where can I find or who can share info about the shifter with tap shift functions on the main shifter? I have been unable to locate info with the search feature. Very interested
Warhorse is offline   Reply With Quote
Old 01-06-2011, 11:02 PM   #9
CFD
Here ya go, if you follow various links in the thread you will find install instructions and the original version as well
NEW PISTOL GRIP SHIFTER WITH TAP SHIFT
Old 01-07-2011, 04:57 AM   #10
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
You just have to downshift before turn and shift after out of turn. Can't shift during turn. They should of put shifter paddle on the steering column in a stationary position. But I got used to it.
Scott@Bjorn3D is offline   Reply With Quote
Old 01-07-2011, 10:11 AM   #11
CFD
Here are my thoughts for what it's worth. You can get "used" to the tapshift the way it is and in fact you can get quite good at using them in their current form. You are also correct in that in order to use them to their maximum capabilites you would down shift in and up shift out BUT generally speaking, the computers in your car are quite sophisticated and shift at optimal shift points for all around performance, fuel economy. Now if you pay attention to your car shifting automatically IT DOES NOT WAIT TO SHIFT BECAUSE OF CORNERS. When it is time to shift you shift unless you can't find your buttons so in fact you are not shifting at optimal shift points. When using tap shift on the wheel there are many times you will hold a gear longer than you should or short shift to make up for this design short fall. If they were stationary on the column it would be much better but because of the column's design it is not realistic to attempt to modify them to fit there. I have been in this debate before and some insist they can shift under any circumstances but I beg to differ. Even when using my shifter I find times when I do not shift when I would like to, usually in panic situations where very quick manuvering is critical like when someone cuts you off, at that point to hell with shifting although these situations are far and few between.
Old 01-07-2011, 10:21 AM   #12
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
TAG's 2010 THRSS #2 TAG UR IT Member Car Journals 3129 08-14-2014 10:29 AM
My Shifter Review – Factory vs Hurst vs MGW caverman V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 46 02-02-2013 05:03 PM
Pic's of Aftermarket Shift Knob on Stock shifter stalk jammer174 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 12-04-2010 09:49 PM
MTI Racing 5th Gen Camaro Shifter SALE MTI Racing Kevin Transmission / Driveline 0 05-24-2010 09:30 AM
