| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#26 | |
![]() ![]() Drives: 2010 camaro Join Date: Jun 2009
Thanks Steve Vararam Industries! |
#27 |
![]() Drives: 2011 Black 2SS/RS L99 on order Join Date: Oct 2010
That's an awesome intake.
Frank and Kim
2011 SS/RS Black on Black (Born 11/18/2010) 2011 Hemi Ram Crew Cab 1500 4X4 Black on Black 2009 HD Street Glide 2005 HD Fatboy |
#28 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Just curious....is this still a 25-30 rwhp intake? What kind of power are they making now?
Build Journal ![]() |
#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
One more, and the last, question. Does this allow some give for engine movement without stressing the intake hard parts?
#30 | |
Drives: 1968 S.S. Big Block and 2010 SS Join Date: Aug 2010
Makes me wish I would have waited. Bought the CAI and I am not impressed at all. To bad Vararam had problems with the first batch might have been different for sales. I feel like some of the tests are to quick to jump whats good or bad or maybe it boilsdown to which product gives a better commission. Have to really do a lot of research. I wish they all had a guarantee like Vararam which stands behind the product and the customers complete satisfaction after the sale. Then we would have no doubt as to owns a piece of a company or commissions. There would a lot more piece of mind in spending our hard earned dollars. Don't get me wrong I'm not calling anyone a crook or dishonest but it has been my own experience that when it comes to money and commission,buyer beware. With the web it is so easy to assassinate a companies product that we need better guaranttees. Lets face it if you make something whatever and you know its the best in everything you say about it you'll guarantee it because that will in the long run bring you more sales. |
#31 |
#32 |
#33 |
#34 |
Bye Bye GD
Drives: 2010 2SS Join Date: Oct 2010
With the original VR you had to move the radiator or something... with the new version, do you have to do any modifications?
2010 CGM 2SS RS. Atomic Orange Metallic Stripes. Corsa Cat-Back. MGW Short-Throw. H&R Springs. AAC Halo/Fogs. 20" Havoc Wheels. SRP Pedals. RX Catch Can. Kicker L7 & Amp in Subthump Stealth. Garys Custom Fenders. Roto-Fab CAI. Pfadt Trailing Arms. |
#35 |
#36 |
So what's the price on them now?
#37 |
#38 |
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
Still the same way, my vararam unit has been on the car for 34K mi that way.
#39 | |
Bye Bye GD
#40 |
So the price of the Tune vs No Tune is the same?
I've already got a tune with my headers so if I were to switch I would go the tuned route. About how much more HP does the tuned unit give you. Also, can you give a quick explanation as to why it would need to be tuned? Is it because it flows more are and so the A/F needs to be adjusted properly?
#41 | ||
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
It would be worth a try to see if it works. |
#42 |
Go Blue!!!!!
#43 |
Go Blue!!!!!
A little update
Put some miles on the new intake today. I was monitoring fuel trims and IAT.
It was about a 30 mile cruise. Still don't have enough miles put in to report accurately on fuel trims but the LTFT are coming in at about -3.9% in all kinds of driving as of now. What impressed me the most is the IAT's. It's 48 here today. When driving IAT's were at 50 degrees. Went up a little at a stand still, but quickly and I mean quickly got back to 50 when I started going again. Stock box was not even close to that. When I got home the intake was cold to the touch and I don't mean not warm or hot, it was COLD. Never have I had an intake not feel at least pretty warm. If you look through the front of the grille you can see the wide mouth of the intake having full access to outside air. It is BADASS!!! On another note, I originally did not use the long bolts to secure the radiator. I was thinking about it and so what I did was use the stock bolts only and put them back in. Not all the way though. What it does is keep the keep intake in place, but also helps stablilize the radiator. I think it is perfect AND you don't have to use those nasty looking stock brackets. Here is a couple of pics. |
#44 |
Cool. Thanks for the updates. It's a little hard to tell from the pictures, but are the stock bolts just biting on to a small portion of the intake material. What made you decide you should add something? Too much movement?
#45 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
I have an older version of the Vararam intake. The Intake itself is very stable. The issue from the beginning has always been the radiator moving back and forth. That was delt with by using long bolts that go from the radiator over the Intake back to the original radiator bolt holes. That does a pretty good job of securing the radiator. Without those bolts, the radiator will move back and forth very easily.
#46 | |
Go Blue!!!!!
#47 |
Go Blue!!!!!
#48 | ||
It is definitely a better look. Quote:
#49 |
I'm planning on getting a Vararam intake very soon, a few questions though. Currently there are no mods on my Camaro but I am planning on getting headers/exhaust and possibly a cam in the future. Should I get the tune or no tune model? If I get the tune model can it be tuned to my stock vehcle then retuned as I modify the engine? If I get the no tune model can it be changed to a tune model? Thanks for the help!
#50 |
Go Blue!!!!!
Tinkered somemore with stock radiator support screws
Ok, I guess I can't leave well enough alone. However, I was thinking about the stock bolts and using them as the support guides. Since they were not screwed all the way in, at some point could they fall out? I did not want to find out. So, I added some L brackets. Had to modify them slightly, but I think it came out great. Here are some pics.
| Thread Tools | |
| Camaro Dove Tail Spoilers Compilation | daphatgrant | Cosmetics and Lighting Modification Discussions | 409 | 06-13-2013 07:04 PM |
| Racing Brake 2 pc Rotors Installed | mtcwby | Suspension / Brakes / Chassis | 36 | 11-13-2010 05:07 PM |
| Got A Vararam for $10! (Warning long read) | shadow09 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 04-26-2010 10:44 PM |
| Check Engine light on after ARH and Pipeline CAI installed | se7en | Tuning / Diagnostics -- engine and transmission | 17 | 03-10-2010 08:06 AM |
| Another Dealer Installed Stripe Problem | 69er | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 07-13-2009 03:32 PM |
