11-11-2010, 07:58 PM | #1 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Changing colors in you LED's for your ABL
So this is for info only, How to Changing colors in you ABL LED's, There are lots of LED out there in all kind of Size's and colors, The one's i will post pics of are the ones that come in your door or if you have done the dash ABL.
If you google you can find lots of 5 mm LED and there are many colors, so lets get to it. In one pic you see new LED's and then the next pic is the back of the led holder from gm there are 4 tabs that hold the housing on use a small pic and small flat tip screw driver to open it then there is a pic of the inside there is only a 1/4 watt resister and the led all you do is mach the resister to the led your using. Change out the OEM led and snap the housing back, and your done have fun. |
11-11-2010, 09:42 PM | #2 |
Drives: Red 2SS/RS M6 Join Date: Apr 2010
ur my hero. more power to the mod monsters.
lupe |
11-11-2010, 10:45 PM | #3 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
how do you get to the abl in the door panel?
Email: rdurso1@yahoo.com |
11-11-2010, 10:49 PM | #4 |
Drives: 2011 2SS/RS (M6) 427 Twin Turbo Join Date: May 2008
Thanks for the DIY man i will be doing this at some point.. i only know of 3 leds i can change, the door panels and one for the auto shifter bezel are there any other ones like behind the gauges?
2011 Camaro 2SS/RS ERL 427 M6 TT -AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler |
11-11-2010, 11:14 PM | #5 |
how do you change the auto shifter ones ?
11-11-2010, 11:18 PM | #6 |
i removed the whole trim piece and switched it with a boot for now but when i did there was one of those leds lighting up the PRNDM
11-11-2010, 11:57 PM | #7 |
interesting.............
11-12-2010, 06:07 AM | #8 | |
You need to remove the door panels of the car,
http://www.camaro5.com/forums/showpo...9&postcount=29 http://www.camaro5.com/forums/showpo...0&postcount=30 Quote:
11-12-2010, 07:29 AM | #9 |
okay thanks! I definitely don't want to mess with those
11-12-2010, 07:38 AM | #10 |
11-12-2010, 08:11 AM | #11 |
[Not-your-day]
Drives: 2005 Avalanche Join Date: Apr 2010
pretty cool, who would have thought it would be as simple as one 5mm led. i would put some heat shrink over those solder joints, just for good measure
11-12-2010, 08:33 AM | #12 |
knows 2 facts about ducks
So on a 1-PITA, getting these door panels off?
11-12-2010, 08:36 AM | #13 | |
First time you do it 3-PITA after that its a 1-PITA, You need to remember that all the parts on the car snap on and off so pull the panel off after you remove ALL the screws. |
11-12-2010, 09:05 AM | #14 |
"Camaro Joe"
for all those that dont want to mess with resistors and leds, aac sells pre wired leds so if you have aac lighting bulbs in your car already you can use these to match those colors as well, if you have any questions about it you can pm me and ill try to help you out with it too
Thread Tools | |
Similar Threads | ||||
How to Wire Footwell Lighting | TonyNo | Camaro DIY & HOW-TO instructions & discussions | 804 | 09-05-2021 08:13 AM |
Colors on Camaro you like...vs colors you hate...and a vote for ugliest color..hehe | chevydude26 | 5th Gen Camaro SS LS LT General Discussions | 15 | 05-26-2010 09:00 PM |
DIY: ABL Color Change | Tecca | Camaro DIY & HOW-TO instructions & discussions | 20 | 05-18-2010 06:50 PM |
hmm I think I am changing colors again | TaylorRyanSS | 5th Gen Camaro SS LS LT General Discussions | 19 | 05-21-2009 10:21 PM |
Coolest new car colors | KILLER74Z28 | General Automotive + Other Cars Discussion | 8 | 04-12-2007 08:24 AM |
