sjm autoprod
Old 11-11-2010, 11:37 PM   #1
IPAINTBRIDGES31
2ss Black on Black M6
IPAINTBRIDGES31's Avatar
Drives: 2012 CTS V Sedan
Cam walk with 3 bolt conversions
Is anybody seeing any cam walk with the ls7 sprocket and a 3 bolt cam swap/conversion?
IPAINTBRIDGES31 is offline   Reply With Quote
Old 11-12-2010, 10:43 AM   #2
Jason 98 TA
Drives: Camaro
Not sure what you mean about cam walk, but the 3 bolt cams are every bit as dependable as the single bolt camshafts. Remember every LS engine for the last 13+ years have run 3 bolt cams with great results.
Jason 98 TA is offline   Reply With Quote
Old 11-12-2010, 11:13 AM   #3
IPAINTBRIDGES31
I had heard reports of the ls7 sprocket being overly soft metal in some cases, and allowing cam shafts to move up to 3/8". Then this "cam walk" was causing lifter to collapse. I was just looking for some more feedback from people who do the installs as to whether or not they had seen this issue in 3 bolt cam conversions with the ls7 sprocket.
Old 11-12-2010, 12:45 PM   #4
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Hey I see your from St. Louis any shops up that way that are good at 2010 camaro and LS engines?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 11-12-2010, 01:27 PM   #5
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
PBJ (Performance By Joe) on Hampton might be a good choice. He quite popular with the Vette and Viper guys. I know of one other guy here that is quite good with the LSx. He works out of his home, when not at his 8 - 5 job. But not sure how he likes to be contacted.
IndeedSS1 is offline   Reply With Quote
Old 11-12-2010, 02:59 PM   #6
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Apparently 3 bolt would be better according to this story.
http://www.camaro5.com/forums/showthread.php?t=114906
ackeight is offline   Reply With Quote
Old 11-12-2010, 03:21 PM   #7
Jason 98 TA
Drives: Camaro
That's news to me, I haven't had any come back for the gear wearing. 3/8" & the pistons would have hit the valves way way before that...
Old 11-12-2010, 03:25 PM   #8
Jon@Texas-Speed
Drives: 01 SS Camaro / 07 Silverado
There isn't any difference in metals that we have seen. We run more 3 bolt cams than anything and never had an issue with them. We have never had a problem with the single bolt cams that we have run as well. It is up to the installer to make sure it is installed correctly.
Jon
Jon@Texas-Speed is offline   Reply With Quote
Old 11-12-2010, 03:26 PM   #9
IPAINTBRIDGES31
Thanks guys
Old 11-12-2010, 03:28 PM   #10
Total_Perf_Eng
Total_Perf_Eng's Avatar
Drives: Corvette
Send a message via AIM to Total_Perf_Eng
Well, you cant actually use the "LS7" timing set with the Camaro, as the oil pump drive gear is to large. As for only using the upper gear, so that you can use the 4x reluctor, no there isnt an issue. Anyone who said their is, must have had an underlying issue. The timing gear, with the exception of the reluctor, is the exact same material as the other gears.
Secondly, the timing gear has nothing to do with "Cam Walk". Behind the timing gear, is a cam retaining plate. This plate is what locks the cam in place. The timing gear simply rides on the face of the cam itself. On some of the aftermarket timing sets, they use a torrington bearing that rides on the retaining plate, but even then, the retaining plate holds the cam in place.
HTH
Total_Perf_Eng is offline   Reply With Quote
Old 11-12-2010, 05:01 PM   #11
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
I thought of using the LS7 gear but ended up buying a set with the Torington bearing made by JP performance. No issues yet.
Cam 427 is offline   Reply With Quote
Old 11-12-2010, 07:11 PM   #12
Anthony @ LG Motorsports
Anthony @ LG Motorsports's Avatar
Drives: 1994 1LE / 2006 Z51 Corvette
I have not seen any issue with doing the conversion over to three bolt and we have been doing it for years as the Corvette's had the single bolt cam starting in 2007 so it isn't anything new to change them over.
Now what you may have heard, and I have seen a total of 2 cars here in the last 6 years do it, is the cam gear starts to wear and then lets the cam move. It can, if let go far enough eat a lifter. I have seen them eat into the cam retaining plate as well. From what I have seen there is no rhyme or reason on why it did it. One car had a cam, the other car was stock. Both were 3 bolt cam cars from the get go.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 11-12-2010, 09:34 PM   #13
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
HTH
Most correct. The 3 bolt gear has nothing to do with it. Red loctite and proper torque specs are your friend
Ovenmitt is offline   Reply With Quote
Old 11-12-2010, 09:44 PM   #14
tandtperformance
tandtperformance's Avatar
Drives: 2010 Camaro 2011 PACE CAR 2012 ZL1
Send a message via Yahoo to tandtperformance
cam gear
that is what happen he is talking about one of are camaros i will post pics to what he is talking about
tandtperformance is offline   Reply With Quote
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Review: 473 rwhp Mike Norris Motorsports cam ducatisl Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 10-26-2010 06:12 PM
VVT Cam Specials! yyz28 Engine Internals 17 10-19-2010 12:29 AM
New Cam!!! getarz4u15ster Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 04-27-2010 07:40 AM
