Emblempros
Old 11-12-2010, 04:38 PM   #1
crabapple
crabapple's Avatar
Drives: '12 ZR1
CTS-V Caliper Fitment?
Will the front calipers from a 2010 Cadillac CTS-V fit on a 2010 Camaro SS and if so can the Camaro rotors be used? Thanks in advance for your time.
crabapple is offline   Reply With Quote
Old 11-12-2010, 05:18 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Basically they'll fit but you have to trim the dust shield. You have to have the CTS-V rotors as well. They are physically bigger than the OEM ones.
http://www.camaro5.com/forums/showth...ght=CTS+brakes
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-12-2010, 05:25 PM   #3
2010_5thgen
2010_5thgen's Avatar
Drives: 2012 Porsche Panamera 4
i think you have t use the cts front rotors. the rear rotors can stay stock ss.
http://www.gofundme.com/n7ne44
2010_5thgen is offline   Reply With Quote
Old 11-12-2010, 05:37 PM   #4
crabapple
crabapple's Avatar
Drives: '12 ZR1
Thank you for the info.
Old 11-12-2010, 09:48 PM   #5
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
yes the front rotors and calipers are the gain in the scanario as the stock ss and the stock cts-v are the same only cosmetic difference. there is a lenghty post on here that details that swap justice pete and pedders has worked with one of there dealers to get brake lines made to properly fit the application, all the info is in the posting
camaro4mybday is offline   Reply With Quote
2008 Cadillac CTS KILLER74Z28 General Automotive + Other Cars Discussion 12 05-08-2016 08:35 PM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 01:08 PM
GM Reveals 2011 Cadillac CTS Coupe! FenwickHockey65 General Automotive + Other Cars Discussion 47 05-21-2010 12:18 AM
Is the V6 in the new Camaro the same engine in the CTS? V6 quality issues? johnxyz 5th Gen Camaro SS LS LT General Discussions 50 05-10-2010 07:55 AM
CTS Wagon revealed Scotsman General Automotive + Other Cars Discussion 22 08-16-2008 05:20 PM
