Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V8 Bolt-Ons & Tunes
Old 11-12-2010, 06:18 PM   #1
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
Elite Engineering PCV Oil Catch Cans | Instock | Best Prices with Free Shipping!
Hey Everyone!
JDP Motorsports is a huge supporter of utilizing a PCV Oil Catch Can on any late-model performance vehicle. We're offering the Elite Engineering PCV Oil Catch Cans as we feel they are the highest quality piece offered on the market. We install these on 90% of the cars we work on here at JDP, they work that well!!
Purpose of your Stock PCV System:
The PCV (Positive Crankcase Ventilation) system is designed to regulate and remove fumes from the engine crankcase, and to alleviate crankcase pressure which could cause oil leaks or seal damage. The PCV system routes crankcase fumes into the intake manifold where they can be burned to eliminate harmful emissions into the atmosphere. The PCV valve controls the amount of crankcase flow volume depending on the engine's load. With large throttle openings (high engine loads), the more blow-by gases are produced, and the more the PCV system flows oil vapor in to the intake manifold. The PCV valve also functions as a check valve to prevent intake manifold flow from reversing back into the crankcase when there is a backfire, or during periods of high manifold pressure (boost) during forced induction by turbocharger or supercharger.
Negative Effects of your Stock PCV System:
Many Camaro owners with LSX and LLT/LFX engines can testify to the amount of oil residue that can accumulate inside the intake manifold, throttle body, intake track and even the air filter during aggressive driving conditions.
There are various negative effects when excess oil vapor contaminates the intake system from the stock PCV system - such as:
*Throttle body and/or MAFS (Mass Air Flow Sensor) malfunction or failure.
*Air filter, intercooler (if equipped) and intake ducting contamination if oil pools and run back out the intake system after engine shutdown.
*Reduced octane of the air/fuel mixture, which can cause detonation and the ECM (Engine Control Module) to retard timing, thereby reducing engine power.
*Excessive carbon build-up on valves, piston crowns, combustion chambers and spark plugs. This also increases the chance of detonation and power loss.
*Increased emissions & possible contamination of catalytic converters and oxygen sensors.
Bottom line: Excessive amounts of oil vapor in the intake manifold is detrimental to your engine!
Solution: Install the E2 Elite Engineering PCV Oil Catch Can!
Ultimate Function:
The E2 Elite Engineering PCV Oil Catch Can is designed to effectively separate oil from the crankcase vapors, thereby eliminating all negative effects of excessive intake system oil contamination. The E2 Catch Can has been engineered to remove the oil vapor before it has a chance to contaminate your intake system.
Not all Catch Cans are created equally! Often Imitated, never duplicated. Most Catch Cans on the market are just comprised of an empty container with 2 ports. While that simple design may trap a few oil droplets, our Catch Can is designed to condense the oil vapor and trap the oil inside the container.
E2's tested proven design incorporates a stainless steel mesh and screening mechanism that acts like a maze to collect and condense the oil vapor. Once the oil vapors condense into liquid droplets, it falls to the bottom of the can. In addition, the top assembly is specially designed to keep any liquid from climbing out the exit hole during aggressive driving conditions. Stored oil volume is approximately 8 ounces. You will be amazed by how much oil our Catch Can will catch! Don't settle for an inferior competitor's product. Insist on Elite Engineering's Catch Can!
Premium Construction:
The Elite Engineering PCV Oil Catch Can is constructed of the finest materials inside and out. High performance car owners insist on the best products that offer unsurpassed function as well as impressive visual enhancement. The E2 Catch Can does both! Our exclusive design incorporates optimum function and the finest materials, construction and finish for maximum dependability.
The 2.6" diameter by 6.0" long body is machined from billet 6061-T6 aluminum alloy, and then anodized in a variety of colors for a striking look. The internal condensing screen is stainless steel encased inside an aluminum alloy housing designed for low flow restriction. The housing can be disassembled for screen inspection, cleaning or replacement if needed. The inlet and outlet hose fittings are brass, and threaded into the body and sealed with Teflon tape. Supplied hoses are fuel and oil vapor compatible (SAE 30R7 rated). The bottom catch can reservoir screws onto the top of the unit, and is sealed with a built in O-ring. Inspection and cleaning is easy by simply removing the bottom of the unit without disturbing the mounting system or hoses.
In keeping with E2's high quality standards, all supplied mounting hardware and screws are stainless steel. The supplied custom machined bracket is aluminum, and is attached to the passenger side engine head. Click the links below, and take a look at E2's instructions page to see how simple the installation is.
LS3 Installation instructions
V6 Installation instructions
L99 or Supercharged Installation instructions
Each Catch Can kit includes everything you need to install the system. Basic mechanical skills and common hand tools are the only things required.
Kit Includes:
*Catch Can assembly beautifully anodized in choice of available colors, complete with 3/8" barbed inlet/outlet hose fittings.
*Custom machined mounting
*Stainless steel mounting hardware.
*24 inches of 3/8" ID fuel and oil vapor compatible hose.
*Black zinc plated hose clamps.
*Nickel plated fittings standard (Chrome fittings available)
We are offering E2 Catch Cans in the (5) five most requested colors: Red, Silver, Black, Blue and now Chrome!
Regular SS Price $175
C5 Forum Special $160 Shipped ($165 L99)
*Chrome add $50 *Allow up to 2 weeks for this option*
Regular LLT V6 Price $185
C5 Forum Price $155 Shipped
*Chrome $205 shipped *Allow up to 2 weeks for this option*
To order click HERE, or call toll-free at 888-308-6007
We are always happy to answer questions, So please feel free to call, PM or email me anytime!
Kind regards,
Jordan Priestley
888-308-6007
sales@jdpmotorsports.com
JDP Motorsports is offline   Reply With Quote
Old 11-16-2010, 01:03 PM   #2
JDP Motorsports
All PMs and emails have been replied to! We're offering the Elite Engineering PCV catch-can including free shipping at a great price! If you don't already have one of these you need one and we have them in stock! Please feel free to call, email or PM me anytime with questions. We appreciate everyone's support and have a great day!
Kind regards,
Jordan Priestley
888.308.6007
Old 11-22-2010, 11:54 AM   #3
JDP Motorsports
All PMs and emails have been replied to!!! We have the E2 PCV Catch-Cans in stock ready to ship at great prices! Please call, email or PM us for pricing as well as order info! We truly APPRECIATE everyone's support and have a great Thanksgiving!!!!
PS - We're offering HUGE discounts on all of the Performance products we offer this week through next Monday!!! Please call, email or PM us for ANY of your performance parts needs!
THANKS again!
Kind regards,
Jordan Priestley
888.308.6007
Old 11-26-2010, 12:43 PM   #4
JDP Motorsports
I hope everyone had a great Thanksgiving!!! Please call, email or PM us for more information on this great product including pricing and order info! We appreciate everyone's support and have a great weekend!
Kind regards,
Jordan Priestley
888.308.6007
Old 11-28-2010, 12:40 AM   #5
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
PM sent, how do I order??
xxlbeerz is offline   Reply With Quote
Old 11-28-2010, 08:43 PM   #6
JDP Motorsports
PM replied. I apologize for the delay. Please feel free to call, email or PM me anytime with questions. We appreciate your interest in our products and have a great evening!
Kind regards,
Jordan Priestley
888.308.6007
Old 12-08-2010, 01:03 PM   #7
JDP Motorsports
This is a MUST HAVE for any Late Model performance vehicle!!!
Old 12-10-2010, 12:44 PM   #8
JDP Motorsports
We appreciate the orders! Have a great weekend!
Kind regards,
Jordan Priestley
888.308.6007
Old 12-13-2010, 06:09 PM   #9
camaro2lt
camaro2lt's Avatar
Pm me a price for a chrome one for a v6 shipped to 17003
Old 12-16-2010, 12:36 PM   #10
JDP Motorsports
PM sent! Please feel free to call, email or PM me anytime with questions. We appreciate your interest in our products and have a great day.
Kind regards,
Jordan
Old 12-22-2010, 03:04 PM   #11
JDP Motorsports
Happy Holidays and Merry Christmas to everyone!!! We have the E2 PCV Catch-Cans in stock ready to ship and you can still have them by Christmas!!! Please call, email or PM us with questions or for pricing! We appreciate everyone's support and have a good one!
Kind regards,
Jordan Priestley
888.308.6007
Old 12-29-2010, 12:23 PM   #12
JDP Motorsports
All PMs and emails have been replied too! Please call, email or PM me anytime with questions or for order info! We appreciate everyone's support and have a Happy New Year!
Kind regards,
Jordan Priestley
888.308.6007
Old 02-08-2011, 11:41 AM   #13
JDP Motorsports
In Stock ready to go!!! Please call, email or PM me for order info!! We will have the E2 catch-cans loaded on www.jdpmotorsports.com shortly! We appreciate everyone's support and have a great day!
Kind regards,
Jordan Priestley
888.308.6007
Old 02-26-2011, 02:16 AM   #14
JDP Motorsports
All PMs and emails have been replied to! Please feel free to call, email or PM us anytime with questions! We appreciate everyone's support and have a great weekend!
Kind regards,
Jordan Priestley
888.308.6007
K&N AirCharger and Typhoon System | Best Prices | Free Shipping! JDP Motorsports V8 Bolt-Ons & Tunes 175 09-04-2012 03:40 PM
Pfadt Sways | In Stock | Best Prices | Free Shipping! JDP Motorsports Suspension / Chassis / Brakes 121 08-30-2012 06:07 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
