ADM PERFORMANCE
Old 11-12-2010, 09:26 PM   #1
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
What happens when..
You punch it with traction control on and it looses traction and kicks in, exactly what does the car do?
I downshifted into 2nd and had it at about 4k RPM's and I floored it the car took off and momentarily stopped like if the fuel supply was cut off, I let off the gas when it happened, tried to reproduce with TCS off and couldnt, didnt try to reproduce with it on again cuz I dont know WTF it was...
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 11-12-2010, 10:17 PM   #2
Huck1974
Drives: 2011 2SS
Wow and wow.
You answered your own question....and wow
Huck1974 is offline   Reply With Quote
Old 11-12-2010, 10:30 PM   #3
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Pretty much... First time I got the TC lurch in the 02 I freaked out, thought somethin was wrong with the car. With that much torque, the car has to take drastic measures to keep the tires hooked up.
Old 11-12-2010, 11:52 PM   #4
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
The car can cut fuel, spark, or throttle position at its own discretion. You can tune any of the three out, mine is currently set to only pull spark.
Ovenmitt is offline   Reply With Quote
Old 11-13-2010, 12:00 AM   #5
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Originally Posted by Huck1974 View Post
Wow and wow.
CamaroFTW is offline   Reply With Quote
Old 11-13-2010, 12:06 AM   #6
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
My guess would be you hit the rev-limiter without noticing.
The rev-limiter on these isn't like rev-limiters of previous LS engines that would "bounce" around red line as long as you kept your foot down. On the 5th Gen, when you hit the rev-limiter and leave your foot on the gas, the engine will fall on it's face until you let off the gas pedal.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 11-13-2010, 12:17 AM   #7
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
Hey Jeanus, I have the same thing. If I downshift to a a gear and get on the gas my car will hiccup for a sec or 2 then then go. I can reproduce this pretty much 100% of the time, so I stopped punching it with traction control on. The traction control just gets to wacky especially when you start pushing some good power. If i turn off traction control then the car is much more stronger and happy. I whipped the rearend around one day on a u turn and the car nearly died from the traction control coming in.
*Powered by Maggie**553rwhp 541rwtq*
ddavis is offline   Reply With Quote
Old 11-13-2010, 03:01 AM   #8
Jeanius
Jeanius's Avatar
to the "wow and wow" guys, no reason to be dicks, if I knew what it did I wouldn't have asked the question.
To the rest Thanks for the replys guys, hard to believe I hit the rev limiter that fast, well see if it happens again
TRADED: 2016 2SS M6
Old 11-13-2010, 03:16 AM   #9
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
this is true with tc on and it will also do this when the car tries to go sideways with stabilitrac on, turn off both and hang on and drift.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 11-13-2010, 03:23 AM   #10
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Its probly the rev limiter.
That happend to me too. and after alot of couple of times lol I noticed that I was hitting the rev limiter.
The Camaro takes over your mind when your driving it. that you don't know how fast your going all you know is that you have a big grin in your face. like this
Old 11-13-2010, 10:47 AM   #11
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
They weren't being dicks..they were pointing out the fact that you answered your own question when describing what happened. You didn't hit the rev limiter...your TC kicked in.
When it senses that the wheels are slipping, it will reduce power (by pulling timing, fuel, or spark) and then add the maximum amount of power that will allow the car to move forward without losing traction.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 11-13-2010, 05:21 PM   #12
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
When it senses that the wheels are slipping, it will reduce power (by pulling timing, fuel, or spark) and then add the maximum amount of power that will allow the car to move forward without losing traction. [/QUOTE]
So, if you are out there "hot doggin it" be sure to turn off BOTH, Traction Control AND Stabilitrack. You will have two small amber lights illuminated acknowledging they are deactivated. If you only turned off TC and the car goes a little sideways then Stabilitrack will kick in and try to maintain car control by doing what TC does and it will apply differential brakes, front and or rear, to keep the car under control. STAB uses the antilock wheel sensors on all four wheels and can apply brakes as needed to affected wheels. If you are driving in rain both TC and STAB are your friends.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
