JDP Motorsports
Old 11-13-2010, 12:39 PM   #1
bigmike10camaro
Drives: 2010 camaro 2ss
Need help with the cats delete ?
Im planing to buy kooks 1 7/8 headers and mid pipes for my 2010 camaro , ive been seening a bunch of mix reviews with this question , just trying to get the right answer, i had talk to some guy from slp performance , and he told me deleting cats will make me lose hp, he said something about the new camaros needed back presures to run good. I have 3" THR cat back with X Pipe , cats or no cats ????
bigmike10camaro is offline   Reply With Quote
Old 11-13-2010, 01:07 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Not true. Ted at Jenetty Racing did a Header test which included not only the different sizes of headers but also with and without cats. From what I remember he found that there was basically no loss or gain between the two.
Do a search and I'm sure you'll find the thread.
Build Journal
Old 11-13-2010, 05:50 PM   #3
bigmike10camaro
Thanks for the info guess I'm going with the mid pipes and a tune
Old 11-13-2010, 06:11 PM   #4
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
A friend of mine added midpipes with hi-flow cats, and did report feeling a loss of low-end grunt via butt-dyno. A tune might take care of that, but back-pressure is a factor. Definitely consider a tune if you're not too attached to your warranty.
Old 11-13-2010, 09:50 PM   #5
bigmike10camaro
Yeah not to worried about the warranty I have buddy that works at the dealer , just wanted to know what would be better cats or no cats , I'm a fan of deleting cats ,had it done to my gto and it sounded great , but like on my first post I read a bunch of mix reviews on this category
Old 11-14-2010, 12:49 PM   #6
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
A friend just had his cats removed and he gained about 25 rwhp. FYI, he has a supercharger on his car.
I use the same shop (IPS Motorsports) and IPS Brandon thought I could pick up similar hp if I deleted the cats on my car. I haven't decided what to do about that yet. I do have a Borla Touring exhaust with high flow cats, Kooks 1 7/8" headers, a Roto-fab intake, and a Magnacharger TVS 2300.
Old 11-14-2010, 12:56 PM   #7
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
the factory cats are a different story. they add quite a bit of back pressure...High flow cats will help alot. I removed mine completely...
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 11-14-2010, 01:08 PM   #8
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
Originally Posted by Revo1 View Post
............but back-pressure is a factor.
Yes, less is better - unless you have too much cam.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 11-14-2010, 04:53 PM   #9
bigmike10camaro
Well I'm playing to put Texas speed cam later on , but for now I just have k&n Cai , tom Henry racing cat back 3" , and soon to order 1 7/8 kooks headers and mid pipes.
Old 11-14-2010, 06:13 PM   #10
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Guys at Kooks Headers told me there's only a few RWHP difference between their high flow cats and going catless (race pipe) with their long tube headers. But you'll definatly not loose power by going catless.
The biggest difference between going catless vs high flow cats is the noise level. Going catless is louder (not significantly but noticeable).
There's a good 15-20 rwhp (18 rwhp reported by several Camro5 members) to be gained by removing the stock cats from an otherwise stock Camaro (ADM race pipe for example). It seems the stock cats are the main bottle neck in the Camaro's exhaust.
Old 11-14-2010, 06:21 PM   #11
bigmike10camaro
Thanks for the info on kooks headers
Old 05-06-2011, 12:07 PM   #12
edugarcia
EDU GARCIA
Drives: 2011 2SS A/T SGM E-FORCE SYSTEM
Send a message via Skype™ to edugarcia
And the resonators e sensors? If I remove the resonators, cats and the mufflers, I´ll put the sensors on the race pipes? Check engine will turn on?
My car is a 2ss V8 e-force supercharged.
edugarcia is offline   Reply With Quote
Delete the CATs? Ravirn Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 06-05-2010 06:48 PM
Rear Cats Delete ducq Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 06-02-2010 05:03 PM
Cats or Cat delete??? ratlover Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 03-14-2010 03:42 PM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 07:46 PM
