JDP Motorsports
Old 11-13-2010, 11:26 PM   #1
Express96
Express96's Avatar
Drives: 2010 Camaro 2SS/RS
Aftermarket tunnel brace
This is for all the people that were having trouble with the exhaust hitting the stock tunnel brace, and bought an aftermarket one. Have you had any more problems with the exhaust hitting after you replaced the brace? I just want to make sure this will solve the problem before I go and fork over money for one. Also which one did you go with?
Express96 is offline   Reply With Quote
Old 11-14-2010, 12:38 AM   #2
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
I have the LSR aluminum brace with 3 inch exhaust. No problems with it.
Cam 427 is offline   Reply With Quote
Old 11-14-2010, 11:12 PM   #3
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
My 3 inch exhaust clears mine.
g-townmach is offline   Reply With Quote
Old 11-15-2010, 02:31 PM   #4
Slowhawk
Drives: 1999 Trans Am
Guess it would depend on how much your exhaust is sagging there. My 3" fit's over the stock no problem but I've seen some exhausts that it is just better to remove the brace because they hang so low.
Slowhawk is offline   Reply With Quote
Old 11-15-2010, 03:07 PM   #5
Entaille
Drives: 2011 Camaro 2SS/RS
my mbrp came with one : )
Entaille is offline   Reply With Quote
Old 11-15-2010, 03:28 PM   #6
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
I was wondering about this also. I can here a definate rattle when I am getting on the throddle. I can only hear it then so i figure it has to be something with the exhaust but no sure. I have stock exhaust from extender tubes back and muffler delete. Would the brace help in that situation?
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 11-15-2010, 04:21 PM   #7
RX SS RACERX
RX SS RACERX's Avatar
Drives: 2010 2SS/RS RJT
I don't consider myself 'cheap' but since I don't show car I got some good plated bolts at hardware store and used some 'INDUSTRIAL STENGHTH RUBBERLIKE STUFF' my dad got at a paper mill. Several washers stacked would also worked. I run a 3" all the way and this worked for about 10 bucks by just spacing the OEM brace down. Just my experience/.02
RX SS RACERX is offline   Reply With Quote
Old 11-28-2010, 11:12 AM   #8
swansor
swansor's Avatar
Drives: 2010 2SS ABM
Send a message via ICQ to swansor Send a message via Yahoo to swansor
Here was my solution for the MBRP exhaust
http://www.camaro5.com/forums/showthread.php?t=117599
swansor is offline   Reply With Quote
Old 11-28-2010, 11:25 AM   #9
tarheel34
Go Heels!!!
tarheel34's Avatar
Anyone know if the BMR tunnel brace gives more clearance? Or is it the a beefier version of the stock brace?
Team L99
2010 Summit White 2SS/RS L99: TSP 1 7/8 LTs - Off-Road Pipes | Tuned By BLUECAT | CAI Cold Air Intake | ADM Race Scoop | SLP UD Pulley | VMAX Throttle Body | Magnaflow X-Pipe | Muffler Delete | SLP 160* T-Stat | MSD Wires
tarheel34 is offline   Reply With Quote
Old 11-28-2010, 04:21 PM   #10
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
I removed mine. No aftermarket brace would clear my exhaust.
Ovenmitt is offline   Reply With Quote
Old 11-28-2010, 04:40 PM   #11
The Stig
knows 2 facts about ducks
The Stig's Avatar
Not to thread jack but I sent you a PM.
My current stock tunnel brace is OK even with my 3" JBA exhaust. But I'm still looking to replace it.
Click to view my build thread
Old 11-28-2010, 06:25 PM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
This isn't a good thing. That brace isn't there just to keep the exhaust from falling down. It's there to aid in stiffening up the chasis of the car across the tunnel.
I tackled it from a different perspective. I welded a exhaust hangar on the driverside, near the rear diff. Pushed up the pipes and welded it on. No more banging over bumps and using the OEM brace.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-28-2010, 08:19 PM   #13
Ovenmitt
Blah blah, whatev. It doesn't make an appreciable difference.
Old 11-28-2010, 08:25 PM   #14
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Pretty sure you are wrong about that.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Keeping the exhaust from hitting the cross brace. jtzako Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 10-04-2010 04:33 AM
Tunnel Brace naga Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-25-2010 02:40 PM
BMR DRIVE SHAFT TUNNEL BRACE Robert@LateModelSpeed Exterior Parts & Accessories 3 04-20-2010 04:01 PM
Spohn Extreme Duty Tunnel Brace Released SpohnPerformance Wheels and Tires Talk Sponsored by The Tire Rack 1 10-18-2009 08:43 PM
