Frankenstein Engine Dynamics
Old 11-14-2010, 08:27 AM   #1
maxpower5
maxpower5's Avatar
Drives: 2010 Shelby GT500
ticking noise from engine???
started my camaro up this morning and heard a ticking noise coming from the engine. popped the hood and got close to hear where it was coming from. seems to be coming from drivers side near the headers. it ticks about 2-3 ticks per sec. was louder when i started it, faded a little but remained for the next 2 minutes i let it run.
anyone any ideas?????
maxpower5 is offline   Reply With Quote
Old 11-14-2010, 08:32 AM   #2
010 Camaro SS
010 Camaro SS's Avatar
Drives: 2010 Camaro SS 2SS
Same thing here...Got mine in April...I think there is a thread
on this on the forum...Same here on start up you really here
it and after 10 - 15 seconds it goes away...Someone will chime
in with answers for you bud...Don't think we should worry
about it...
010 Camaro SS is offline   Reply With Quote
Old 11-14-2010, 08:34 AM   #3
Hall of Fame
Hall of Fame's Avatar
Drives: Hall of Fame
Could indicate a hydralic lifter pumping up slowly. Is you oil correct and clean?
Hall of Fame is offline   Reply With Quote
Old 11-14-2010, 08:34 AM   #4
maxpower5
maxpower5's Avatar
yeah, freaks me out a little - only had the car 15 months. hopefully nothing, but you have to be careful.
Old 11-14-2010, 08:35 AM   #5
maxpower5
maxpower5's Avatar
have an l99 - have 8 quarts of rp 5/30 in there - with about 2500 miles on the oil. will be replacing it soon.
Old 11-14-2010, 08:36 AM   #6
flyby
Drives: 2010 Silver SS
most likely injectors. When they are cold they are sometimes more noticable, but they always make a little noise, usually not loud enough to get youor attention.
flyby is offline   Reply With Quote
Old 11-14-2010, 08:42 AM   #7
maxpower5
maxpower5's Avatar
went out to double check oil level and how clean - level was good and it was surprisingly clean (love rp oil). started it up again - same ticking noise but a little softer - gave the engine a good hard rev - noise went away after that - what's up??
if it is injectors, do i need to see the dealer about this - hell the car is only 15 months old and its not that cold here - about 40 degrees and my car is garaged. problem???
Old 11-14-2010, 08:51 AM   #8
flyby
Nope, normal injector noise, usually becomes less noticable with warmth. I used ZMAX fuel treatment which took almost all noise away, acts as a lubricant. But no matter what you do, injectors will always make a little clicking/tapping noise.
Old 11-14-2010, 08:54 AM   #9
hotrodhoodrat
hotrodhoodratz
hotrodhoodrat's Avatar
Drives: 68' & 70' Pontiac's /2004 D. Dakota
Is yo garage heated (?), if not, it might just be the oil, it's thick when cold, as the motor worms up & goes away, it might not be a bad thing, but if its worm or hot and still does it, you might have it checked.
Hope that helps.
The all new Convertible !, Welcome to the Fleet !
hotrodhoodrat is offline   Reply With Quote
Old 11-14-2010, 09:06 AM   #10
bluetooth-ss
bluetooth-ss's Avatar
Drives: 2010 ABM 2SS/RS A6 and 2005 TITAN
There is a tsb out on the afm lifters making noise.You can do a search and find it and also check with your dealer.
BLUETOOTH-SS
Old 11-14-2010, 09:23 AM   #11
KeepItGreasey
So It'll Go Down Easy
KeepItGreasey's Avatar
Drives: Camaro SS/RS
Everyone at the dealers is deaf. They have a very hard time "duplicating issues" that involve listening to anything. And if they DO hear something, then it's "normal".
KeepItGreasey is offline   Reply With Quote
Old 11-14-2010, 09:54 AM   #12
Howzit
Howzit's Avatar
Drives: 77 RS, 10 SS
Check the spark plug wires.
Its probably not the issue cause I believe it would turn on your T/C light, but it couldn't hurt. I know when I put on my headers I began hearing a ticking sound, which turned out to be a loose spark plug wire.
Howzit is offline   Reply With Quote
Old 11-14-2010, 10:25 AM   #13
2010BumbleBee
2010BumbleBee's Avatar
Drives: 2010 2SS RS A6
+1 on that
I've been in 2x so far for lifters and they insist it's normal injector noise.
2010BumbleBee is offline   Reply With Quote
Old 11-14-2010, 02:13 PM   #14
Mike-D
HTFU
Mike-D's Avatar
Drives: 2SS/RS
Anybody have an update on this? I just bought a V6 Camaro a week and didn't notice when I bought it. It does it all the time, no matter if its cold or warm, but only does it at idle. Im gonna see about taking it in, it only has 17000 on it. Thanks
Mike-D is offline   Reply With Quote
2012 Camaro SS vs. 2012 Mustang Boss 302 Laguna Seca? Moreno Motorsports Chevy Camaro vs... 199 11-23-2010 04:48 PM
Just lost faith in this car DarkneSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 70 10-08-2010 02:13 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
LLT engine specifications Tran Wiki 2 03-29-2010 10:06 AM
STS Twin Turbos SupremacyCustoms Forced Induction - V8 0 02-16-2010 01:35 PM
