Emblempros
Old 11-14-2010, 02:04 PM   #1
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
Question Loose 02 sensor on long tubes
I was looking around under the car today and noticed that the front drivers side o2 sensor was loose (I have Stainless Works catted long tubes). I tightened it back up and all seems fine.
What sort of things would having a loose o2 sensor do to the car? Would it cause it to run more rich/lean or anything like that? Would I have seen a code if it was leaking enough air to really cause a problem (I do have a tune as well)?
It was loose enough that I could easily spin it with my fingers but it still had enough threads in that it wasn't about to fall out either.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 11-14-2010, 02:40 PM   #2
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Funny you bring this up. I don't know the answers but I did just get an engine light. I have Stainless works long tube headers and a tune also. Yesterday I threw some codes for running lean. I'm going to check the car out today and see if anything is loose on it.
Lnch Mny is offline   Reply With Quote
Old 11-14-2010, 03:35 PM   #3
Agent WD-40
I didn't see any CEL on mine... I just happened to notice it was loose.
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 11-14-2010, 11:32 PM   #4
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
IT would make it run slightly richer, due to air leaking in creating a (simulated) lean condition, the car would add fuel.
Ovenmitt is offline   Reply With Quote
Old 11-15-2010, 07:53 AM   #5
Cal 20112SS
Drives: 2011 2SS/RS
When I had my LT's installed the threads on my drivers side sensor were bad right from the factory. It was a PITA to get it to screw back in again. It's not the tightest seal and I swear I'm leaking air through that sensor. I have an SCT tune and had the codes removed but it did throw code P2272 which was 02 sensor signal stuck lean . Then I read page 68 of Camaro Now magazine which on #5 confirms how bad the threads are on the sensors.
Cal 20112SS is offline   Reply With Quote
Old 11-15-2010, 10:59 AM   #6
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I went thru the same thing on my 2001 Camaro. I had one O2 with bad threads.
I replaced it myself and put the same stuff as I put on my spark plugs, Anti-seize compound.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 11-15-2010, 12:13 PM   #7
Agent WD-40
I'll have to take a closer look at that now. Anybody have a price and part number for that o2 sensor?
I did sort of think I was running a bit rich, but I wasn't sure if it was the tune or the long tube headers and high flow cats or some combination of the two.
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 11-15-2010, 09:29 PM   #8
Ovenmitt
I've got two extras laying around if you want one, maybe 1000 miles on them. I dont think the rears are any different physically then the fronts.
Old 11-15-2010, 09:45 PM   #9
Agent WD-40
Doing a parts search online shows 2 different part numbers for the V8. One front the other rear.
I might take you up on that. I still need to get under my car a check though.
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
loose o2 sensor
2010 SS Long Tubes, Catback, CAI--Like New, AWESOME PACKAGE PRICE! Torchdvette V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 15 11-16-2010 08:07 PM
sound of v6 with the bbk long tubes nyycamarogirl Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 1 09-09-2010 06:56 PM
Has Anyone Bought the LG Motorsports Long Tubes? darwin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 08-15-2010 09:03 PM
L99 Nickey edition Long Tubes, Cats X-PIPE, Magnaflows, Halltech, tune NicKey V8 Bolt-Ons & Tunes 2 06-06-2010 11:35 AM
Doug Thorley Long Tubes Herron Performance V8 Bolt-Ons & Tunes 9 12-12-2009 12:31 PM
