JDP Motorsports
Old 11-14-2010, 07:08 PM   #1
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Thumbs up Just Installed ******** 12" Box, Plug and Play Harness and Amp Rack
I just finished installing my 12" ******** box with ********'s plug and play harness and amplifier mounting board. The system sounds great! I'm running a Precision Power A300 "Art Series" amplifier in bridged mode (300 watts). The amp is powering an Alpine 12" SWS-1222D dual voice coil subwoofer.
I also decided to run a bass knob. I velcroed it to the side of the console. I'm not big on drilling into my dash or console. As you can see from the pic I have attached, it turned out pretty nice.
I decided not to run any sound deadener during the install. I don't have any major rattles. The fitment of ********'s box was great!
I only have one minor issue after the install...when I shut off the stereo, the subwoofer pops. It doesn't do it during power on. Any ideas?
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 11-14-2010, 07:16 PM   #2
ChvyBoss
THAT BOOST TURNS HEADS
ChvyBoss's Avatar
Drives: Camaro 2SS/RS
speaker looks good, but amp looks a lil sloppy with the wires showing tho
SoCal HT5 ENOUGH SAID
ChvyBoss is offline   Reply With Quote
Old 11-14-2010, 07:54 PM   #3
Hicompression
Rumbly Bumble Bee
Yep, I hadn't finished completely tucking the wires away when I took the pics. I have updated the first amp pic.
-OBX Longtubes FTW!
Old 11-14-2010, 08:03 PM   #4
SwedeandBlondie
SwedeandBlondie's Avatar
Drives: 2011 Black 2SS/RS L99 on order
What are you using for your "on" signal for the amp to turn on? In past systems I've installed, if you wire that to a switch vice the amp lead from a head unit, you'll occasionally get a bump when you power on or off. You can get filters for that if you're stuck using a switched power source. Not sure what the wiring harness uses for that function.
Frank and Kim
2011 SS/RS Black on Black (Born 11/18/2010)
2011 Hemi Ram Crew Cab 1500 4X4 Black on Black
2009 HD Street Glide
2005 HD Fatboy
SwedeandBlondie is offline   Reply With Quote
Old 11-14-2010, 08:24 PM   #5
mcotton
mcotton's Avatar
Drives: 2010 Camaro
looks nice
mcotton is offline   Reply With Quote
Old 11-14-2010, 09:10 PM   #6
Hicompression
Rumbly Bumble Bee
I'm using ********'s harness connector. The white wire is for power on/off. This harness plugs directly into the amplifier. I guess I don't know exactly what the white wire is tapped into either...
-OBX Longtubes FTW!
Old 11-14-2010, 09:20 PM   #7
oachalon
Drives: 2010 Camaro 1SS
Wow a precision power art series amp, that brings back memories. I used to have one of those, but mine was the all black version. An awesome amp, and worth money. I sold mine a couple years ago for more than i paid. It was probably 10 years old atleast when i sold it.
oachalon is offline   Reply With Quote
Old 11-14-2010, 09:36 PM   #8
Steve@Subthump
Drives: 2011 2SS IOM Vert
The white wire is the amp enable wire on the stock audio harness. This is the same wire that turns on the stock amp and the only switched power source located in the rear of the car. Thus it was an easy choice for using it--rather than saying here's a nice plug n play signal harness, except you'll have to locate a switched source up front and run a wire all the way to the back to turn your amp on. Nobody knows where to look for that and the radio doesn't exactly come out real easy either.
A little turn off thump is pretty common actually, but every amp seems to act differently to it. Some don't do it at all, while others are more pronounced. I noticed mine did this at first, but once I backed the gain off, it reduced it significantly. So that would be my first recommendation.
Steve@Subthump is offline   Reply With Quote
Old 11-14-2010, 10:00 PM   #9
Hicompression
Rumbly Bumble Bee
Hah! I was wondering when someone was going to say something about the PPI amp. Definitely old skool!
Thanks Steve, I'll try that!
-OBX Longtubes FTW!
Old 11-14-2010, 10:17 PM   #10
oachalon
Yeah definitely old skool. Mine was an A600, no internal crossover and ran a pair of kicker comp 12s.
Old 11-14-2010, 10:57 PM   #11
Hicompression
Rumbly Bumble Bee
My brother gave me this amp about 8 years ago for Christmas. He had almost every "art series" amp PPI ever made including the large A1200 series. Alas...he has sold them all. They do command top dollar though.
This amp had been sitting since he gave it to me. I finally decided it was time to put it to use.
-OBX Longtubes FTW!
Old 11-14-2010, 11:11 PM   #12
midnighter
Drives: nothing
Wow, how old is your amp? I had a PP amp in 1993 that looks identical to that amp. Just curious.
Old 11-15-2010, 08:21 AM   #13
Hicompression
Rumbly Bumble Bee
1992.
-OBX Longtubes FTW!
Old 11-15-2010, 11:01 AM   #14
tfannon
Drives: Dark Grey SS
i was thinking same thing. i had one of those a long time ago. its amazing that tech in audio hasnt really changed all that much.
tfannon is offline   Reply With Quote
Official Release Thread of the ******** 2010 Camaro Plug N Play RCA T-Harness Steve@Subthump Audio / Visual / Electronics/ Gauges / Nav 201 06-07-2011 09:06 PM
Plug & Play Add Amp RCA output Harness Success/Updates Steve@Subthump Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 10-26-2010 11:11 AM
