JDP Motorsports
Old 11-14-2010, 07:54 PM   #1
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
Removing radiatot
Im half way into my cam swap. Cant figure out how to get the two lines at the bottom of the radiator off. I tried my fuel line tools but it doesnt slide in there. What is the trick?
I also see its going to be a pita to linr my crank pulley up since i gave it pinned for the SC.
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Old 11-14-2010, 08:09 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
just slide the black plastic shield back and remove the clip with a small pick if you dont have the correct tool to release these clips
Old 11-14-2010, 08:31 PM   #3
lock
lock's Avatar
Well damn. Spun the hose aroubd and see the bottom of the clips. Easy now. I didnt even look on bottom. Thanks
Old 11-14-2010, 08:55 PM   #4
agkelly73
agkelly73's Avatar
Drives: 2010 2SS/RS
Lock, you might want to hit up StikSS. He just did a cam swap on his LS3 this weekend and he may be able to help out when it comes to some recommendations if you need any.
agkelly73 is offline   Reply With Quote
Old 11-14-2010, 10:01 PM   #5
jamesc1123
jamesc1123's Avatar
Drives: CGM 2SS RS w/ white stripes
Hope it goes well for you. I'm getting close on my swap. Springs and reassembly and I'll be done. Managed to send a valve lock flying into oblivion so I'm at a standstill til I order some. If I finish before you I'll mail you some spares. Apparently you don't have to cut the ac belt. Wish I hadn't followed the manual on that one. If you change out your timing chain and or oil pump, STUFF RAGS IN THE OIL PAN TO STOP A DROPPED PICKUP TUBE BOLT.
jamesc1123 is offline   Reply With Quote
Old 11-14-2010, 10:10 PM   #6
lock
lock's Avatar
I got the crank pulley off with the belt still on. Gotta figure out a way to fet it back on. Crazy there is no tensioner!
Old 11-14-2010, 10:47 PM   #7
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
Post 666!
xxlbeerz is offline   Reply With Quote
Old 11-14-2010, 11:28 PM   #8
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
There's a special tool for it that comes in the GM belt kit. If you were local, I'd let you borrow mine.
Ovenmitt is offline   Reply With Quote
Old 11-15-2010, 12:55 AM   #9
LAYN2LOW
Drives: 2010 CAMARO 1SS M6
Just have one guy pulling off while the other turns the motor over with a ratchet.
LAYN2LOW is offline   Reply With Quote
Old 11-15-2010, 01:22 PM   #10
camaro1
camaro1's Avatar
a/c belt goes on and off easily if you put a ratchet on the crank bolt and just use a long screwdriver or prybar, pry it to the side while turning the ratchet to get it off ,, to get it on just get it started as far as you can then hold it while turing the engine with the ratchet again and it will go right on
this works easiest with the spark plugs removed
you will probly end up re-drilling your crank for the pin,, or have the crank pulley machined/drilled all the way through(like a keyed pulley) then you can start it in the correct location and pull it right on with your install tool
Old 11-15-2010, 01:43 PM   #11
stikSS
9691 & 97586
stikSS's Avatar
Drives: '10 Camaro SS and 2LT
That AC belt just sucks.... no other way to put it!! Be careful with those powersteering hose clips. if you loose em, you have to buy the whole kit, not just the clips.
stikSS is offline   Reply With Quote
Old 11-16-2010, 01:37 PM   #12
lock
lock's Avatar
Just stretching and admiring my bump stick.
Old 11-17-2010, 04:25 PM   #13
lock
lock's Avatar
Getting the ac belt back on was pretty easy as you described. Wrappwd up my install and fired it up. Got out for a leak check and holy cow my car was pissing gas. Knocked my fuel line loose. I have the JRE line kit for the eforce. Pretty scary. No more action till this is all cleaned up.
Old 11-17-2010, 08:37 PM   #14
BLACK10
BLACK10's Avatar
nice job
Removing the French side mirror sticker Avalnch Canada 4 09-22-2010 02:03 AM
Removing Rear Bowtie and SS Emblem....Any Tutorials? blahzay Camaro DIY & HOW-TO instructions & discussions 5 06-28-2010 07:24 PM
Removing Swirl Marks using a Flex and Meguiars M105/M205 Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 05-22-2010 11:36 PM
Another "noob" question: removing resonators Pumpkin1LT USA - Texas 7 05-13-2010 01:41 PM
Removing Badges Shurenuff 5th Gen Camaro SS LS LT General Discussions 29 02-09-2009 01:42 PM
