sjm autoprod
Old 11-14-2010, 07:23 PM   #1
ericedelman
ericedelman's Avatar
Drives: 2017 ZL1 (on order)
Are rebuild kits available for the Brembo calipers?
I take my car to the track and just installed my 3rd set of front pads and rotors.
The rubber boots around the pistons are starting to look a little worn, probably from heat.
Is there a rebuild kit available for the calipers? My last track event is this coming weekend, and then the car will sit in the garage for a few months during winter, so it'd be a good time to rebuild the calipers.
2017 ZL1 (on order)
ericedelman is offline   Reply With Quote
Old 11-18-2010, 10:40 PM   #2
Byron
Drives: 2010 Camaro 2SS/RS LS3 .
Arrow Brembo Calipers Rebuild Kits
http://brakeperformance.com/brake-bo...e-Boosters.php Front- 45.96 Back- 23.37 Free Shipping .
Byron is offline   Reply With Quote
Old 08-12-2014, 07:27 AM   #3
mbellomo19
mbellomo19's Avatar
Drives: 2011 camaro 2SSRSS
are you sure that website provides the correct rebuild kit for the brembo brakes
mbellomo19 is offline   Reply With Quote
Old 08-12-2014, 09:31 PM   #4
intensifi
Drives: '12 2LT Convertible
racing brake has a nice kit.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 08-13-2014, 08:10 AM   #5
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Brembo Front Caliper Dust Shield Rebuild Kit part # is: 89047722
Brembo Front Caliper Piston/Seal Rebuild Kit part # is: 92244294
Brembo Rear Caliper Dust Shield Rebuild Kit part # is: 89047739
Brembo Rear Caliper Piston/Seal Rebuild Kit part # is: 89047731
I believe these are the GM part numbers I used to rebuild mine. You can verify them online before you buy.
bannonm is offline   Reply With Quote
Old 02-12-2015, 03:51 PM   #6
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Are you not sure these are the parts you used? I may just go to the dealer and have them print out the correct part numbers to be safe.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 02-12-2015, 03:56 PM   #7
bannonm
bannonm's Avatar
I checked the order I placed for them. Those are the correct part numbers for what I ordered December 2012. GM likes to change part numbers as time goes on, so check them with your dealer.
Why do my front Brembo Calipers have stick on wheel weights on them? 55Designs Suspension / Brakes / Chassis 10 04-14-2014 01:07 AM
Optional Brembo Calipers Rallyman6 Wheels and Tires Talk Sponsored by The Tire Rack 35 12-31-2011 06:41 PM
SS Brembo front and rear calipers for sale Kwik Suspension / Brakes / Chassis 7 10-15-2010 10:18 AM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 12:08 PM
Torque setting for Brembo Calipers? markmass Suspension / Brakes / Chassis 0 06-15-2010 12:22 PM
