Old 11-14-2010, 11:49 PM   #1
Gbusy06
Tap Out
Drives: 2011 Camaro SS A6 SGM
Smile WEIGHT OF KOOKS LT VS. STOCK MANFLDS?
Just installed Kooks catted 17/8 LTs and noticed the shipping weight was 53lbs. Anyone knows the weight of the stock manifolds? I know they are heavier, but just wanted to know by how much.
Gbusy06 is offline   Reply With Quote
Old 11-15-2010, 12:31 AM   #2
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Well if you just installed the Kooks, shouldn't you still have the original manifolds you took off? Just weigh them! I'd be interested to know this myself.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 11-15-2010, 12:53 AM   #3
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
the stock manifold is thick cast metal, has a heatshield, two cats and some pipe on each side i would say they weigh more than headers, and headers make an extreme difference in power over stock manifolds. = win
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 11-15-2010, 07:21 PM   #4
Gbusy06
Tap Out
If I had a scale, I would have weighted them and provided the information. As such, I thought that one of the other members may have done so. Again, if anyone has weighted the manifolds, please chime in. If I am correct, the headers and connection pipes weight 53lbs. Thanks again for any accurate input.
Old 11-16-2010, 04:10 PM   #5
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
i have switched them and the stock manifolds feel like 53lbs for one
woodside783 is offline   Reply With Quote
Old 11-16-2010, 04:51 PM   #6
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
Hooks headers and midpipes are between 40 and 50lbs installed. I have not weighed the stock system.
443-730-9428 - www.marylandspeed.com - Great Prices and Free Shipping!
* CURRENT SALES * ORDER TERMS * DISCOUNT POLICY
MarylandSpeed is offline   Reply With Quote
Old 11-23-2010, 01:06 AM   #7
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
Here is the weight of the following two assemblies:
Stock assembly
Header with cat
Jaysin is offline   Reply With Quote
Old 11-23-2010, 02:01 AM   #8
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
So you save 12lbs. Not bad. Now you can have bacon on your cheeseburger!
9/26/09 Took delivery!
Old 11-24-2010, 10:17 PM   #9
Gbusy06
Tap Out
Thanks Jaysin for the information. 12 less lbs and 30 plus more hps are all positive gains.
Old 11-25-2010, 07:41 AM   #10
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
In addition, for the guys that go catless (Kooks race pipe vs high flow cats) you'll shave a few more pounds.
Where you can shave a good bit of weight is by getting rid of the stock mufflers. (they're heavy).
Old 11-25-2010, 01:01 PM   #11
Gbusy06
Tap Out
SGO, I would like to add a deeper sound to my car, but I do not want the drone and additional noise. My car has the Vararam and headers-the noise level is not that noticable inside the car until I get on it. Outside, you can tell the exhaust note is diff. I might consider replacing just the mufflers. Thanks for the info. again.
Standard vs Automatic Racing HarrisraTx Dragstrip and Launch Techniques Discussion 74 10-29-2010 10:26 PM
kooks n stock cats?????? AntzV Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 05-20-2010 12:13 PM
Kooks LT + noweeds.net = possible? AdamCzap Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 03-06-2010 01:45 AM
Exhaust system to go with Kooks LT meltyface Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 02-15-2010 10:30 PM
Kooks 1 3/4 headers - Full 3" exhaust in stock HRC V8 Bolt-Ons & Tunes 8 12-27-2009 02:19 AM
