SDPC
Old 12-14-2010, 09:47 AM   #43
denster
denster's Avatar
Drives: 2011 Camaro 2-SS
The only problem with that suggestion 2010 ss rs, is that you don't get to tell the dealership what to put in when the work is being done under the factory warranty.
I'll be picking my car up today in about an hour or so. I did talk to the mechanic, and he said before he replaced my transmission, he was able to get it to grind when shifting quickly from 1st to 2nd, at about 2500 rpm. He said now that he put a new tranny in, he can shift at any rpm and it does not grind any longer.
I'll comment back here after i get to try it myself.
denster is offline   Reply With Quote
Old 12-14-2010, 09:56 AM   #44
6bloodychunks
6bloodychunks's Avatar
Drives: 2011 2SS/RS SGM
same exact thing has been happening to me from day 1.
its going to be hard to get a local dealer to treat me good because i got my car from scotty in WI
there are 4 chevy dealers in my area looks like ill be calling them all today.
---2011 synergy green 2SS/RS---
09/27/2010 - (3800)
10/01/2010 - (4200)
10/09/2010 - (4800) Vehicle on final destination route
10/19/2010 - (5000) delivered to dealer
11/19/2010 - (6000) delivered to customer
6bloodychunks is offline   Reply With Quote
Old 12-14-2010, 09:59 AM   #45
denster
denster's Avatar
Exactly the problem I had 6bloodychuncks. Read my post above from '12-03-2010, 12:49 PM'. I have also been working with GM on this one and I reported that dealer as well. If you're getting resistance from that dealership then I would recommend contacting GM for sure. It's probably not a bad idea for anyone having this problem to report it to GM. They need to be made more aware of this problem.
Old 12-15-2010, 07:24 AM   #46
awforeman
Drives: 2011 SIM 2SS/RS M6
denster, any word on how the fix went for you?
10/01/2010 - 1102 Order Entered via Web
10/26/2010 - 2000 Order Accepted by GM
10/26/2010 - 2500 Order Preferenced
10/26/2010 - 3000 Order accepted by production control.
10/27/2010 - 3100 Order available to sequence.
10/27/2010 - 3300 Order Scheduled for Production
10/28/2010 - 3400 Order Broadcast
11/12/2010 - 3800 Order produced
11/12/2010 - 4000 Vehicle available to ship
11/12/2010 - 4150 Invoiced
11/12/2010 - 4B00 Your car is bayed and is waiting for transportation by Truck, Rail or transfer to vendor
11/15/2010 - 4200 Shipped
awforeman is offline   Reply With Quote
Old 12-15-2010, 07:43 AM   #47
denster
denster's Avatar
Well the problem seems to have gone away, however there are a few strange observations I made. First off, the new transmission seems a little less smooth going through the gears as opposed to the one that was in the car when it was brand new. The second strange observance is that the clutch pedal is so much easier to press down than it used to be. I have a call in to the mechanic that worked on it to ask his opinion why this could be. I'm wondering if they changed the pressure plate or maybe even forgot a return spring on the pedal or something. Not sure, but it doesn't seem to be a problem, just an observance.
I haven't really got on it yet at high rpm, because I was giving it a chance to break in a bit, but the grinding I used to get shifting at 2500 or 3500 appears to have gone away.
So the question is, was it the transmission that was bad, or something in the setup. What if everyone's problems are caused becuase the clutch slave cylinder isn't disengaging the clutch completly? You know, this would cause the same effect. Maybe just messing with it and re-installing it was the key?
Old 12-15-2010, 06:14 PM   #48
awforeman
just took my car out. was able to get it to grind anywhere from 3k-4k, didn't go over that. The clutch was definitely all the way in....urgh. Can't get to the dealership until this weekend or next week at best, I will post updates as I go through the process.
Old 12-22-2010, 01:13 PM   #49
mad@gm
Drives: was a 2010 2SS/RS
And who are you contacting at gm for dealer problems? I have been on the phone with gm since april over car/dealership problems and customer care does not care, they love to side with dealerships. It took a personal favor for me to get any help and now Im dealing with the executive offices to get my p.o.s. fixed.
mad@gm is offline   Reply With Quote
Old 12-23-2010, 04:50 PM   #50
Luckymex_dallas
Drag Racer
Drives: 2010 2SS/Rs
nope^^^only if its ****ed already ,,,loook for your clutch to get stuck very soon..and drop the fluid SALVE CYNLINDER ACTUATOR about to go out on yours...trust
Luckymex_dallas is offline   Reply With Quote
Old 01-06-2011, 12:48 PM   #51
Rick@RKT56
Rick@RKT56's Avatar
Drives: Corvette
Originally Posted by RipperFox View Post
I have been having the same issues as all of you.
1. Grinds 1st to 2nd at higher RPM's
2. Tried a new shifter (Hurst), got no better, maybe worse. Probably cause it shifts even faster.
3. Change the fluild to Mobile Syn. No improvement.
4. Noticed that is happens alot more when tranny temp is colder. Above 75-80F, nearly goes away.
5. I can get it to do in the garage too.
In the garage, I notice that if I go from neutral ALMOST into 1st. (just to the point of resistance) and hold it there. Then pull back into second really quick it will grind. No clutch involved at all. Pedal to the floor, car at idle.
Now, let me say that again. I get the exact same grind, from 1st to 2nd, if I push the clutch tothe floor, just nearly push it into 1st, hold or a couple of seconds, and pull back into 2nd (as if speed shifting), and it will grind. Car is at 500-700 RPM the whole time, clutch is on the floor, the whole time. Give it a little gas (say 2-3K RPM) and it will grind like speed shifting at 6K.
Someone else try this and see what results you get. PM me or post here.
This is why I know it is the syncro's: RPM, clutch are not involved in this test. Syncro's are not match gear speeds quick enough for these gears. That is why slowing down your shift fixes the situation. I do believe that the tappered syncro's could be the cure for this.
I think what is happening in the garage is: The syncro's are matching speed to first gear (just at the edge of the entry gate), and when you are pulling into 2nd really quick, there is not enough time for the 2nd gear syncro to make gear speed.
The temperature thing: The viscosity of the tranny fluild is lower thus allowing the bearings and thus the gears to react faster.
Are you saying you have the engine running, clutch pedal to the floor and shifting from 1st to 2nd WHILE you have the clutch pedal to the floor and it grinds? While the vehicle is stationary? If this is what you're stating, then it's your clutch and not the transmission. When you have the clutch pedal to the floor, the input shaft of the transmission should be stopped (unless the clutch is dragging) so all the internal parts of the transmission should NOT be turning. If you hear it grinding that mean the internal parts are STILL moving.
Rick@RKT56 is offline   Reply With Quote
Old 01-09-2011, 07:33 AM   #52
togtaker
togtaker
Drives: 2011 2ss/rs
I have the 1st-2nd shift problem. I took to the dealer, they said shift slower. I called customer service, they told me to shift slower. I called Tremec they said that was GM blowing smoke. I sent a letter. They ordered my parts this week. They have a redesigned synchro, also replacing the blocker ring. Not easy to get them to do it, but you have to start with your dealer and keep moving up the chain until you get high enough for them to fix the problem.
togtaker is offline   Reply With Quote
Old 01-09-2011, 10:18 AM   #53
Rick@RKT56
Rick@RKT56's Avatar
Drives: Corvette
IMHO, when the dealership you take your vehicle to doesn't acknowledge the issue with your transmission, it's best to call GM directly and make a formal complaint. I can tell you this works MUCH better than arguing with the manager or advisor. GM will get the regional rep involved and his/her words work wonders.
Old 01-12-2011, 09:19 AM   #54
mad@gm
Sometimes maby! It depends on how much the rep is in bed with the dealer, and who you get at gm, in my experience with repairs and difficult dealerships, if its an outsourced employee the chances are slim to none getting them to really care.
Old 01-12-2011, 06:37 PM   #55
blufin
blufin's Avatar
Drives: Fire Engine
Mine has been doing it alot when at the dragstrip. Almost everytime I run. I will probably try to co tact the dealer and get this snowball rolling. I hope they take care of me or this car will be of no use to me.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 01-14-2011, 12:02 PM   #56
adc174
Drives: 2010
upate on my trans : the local dealership i took car in oct after dissmantleing entire trans told me it was shifter and not the trans, they refused to re assemble trans unless i paid for it, i called gm 1000x and argued with them, they told me im on my own and the dealer flagged car in computer so no warranty anymore. they had car for 8 weeks or so, charged me 600 for storage, gave me all the pieces in a box and it cost me 175 for a tow and then 500 to ship car across the state to have trans put back together. the found 2 bad gears and syncros ground over. i bought car used w/ 3100 miles from a dealer that way.... nobody wanted to cover anything after i spent 5500 just for rockland to put everything back together and new clutch ect... all and all im almost 7500 out of pocket and wont get car till next week, i think its bs for gm to screw over customers like this, im submitting all the recipts to my lawyer and we will see.....the kicker is it was in the dealer for other warranty issues that they didnt even bother doing, i simply told them about the grinding, they removed trans on there own, never gave permission to and also....what is the first thing you do to pull trans out of this car???? 1st thing is the shifter, so if you saw an aftermarket shifter that you woulnt warranty ( if it was the prob which it wasnt) doesnt that warrent a phone call explaining that it may not be covered befor you dissassemble the whole thing??????????? this is how i got car back plus a shit ton of dings/dents and scratches. all the gears and everything thrown in a bin and everything else tossed inside the car..... someone please tell me how to post a pic and ill show ya
adc174 is offline   Reply With Quote
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
