Old 01-20-2011, 06:11 PM   #85
ponbigi
ponbigi's Avatar
Drives: 2011 CAMARO LS
part numbers as follow:
89058762 FORK (04303-CK)
89058794 RING SET (04416-CK)
92149634 Gear, 2nd (04395-C)
89058803 SLEEVE (04384-CK)
88862475 OIL (08800-BOPCK)
I have to get with the mechanic on this to see what's really going on. I am concerned i will be in the same spot soon after the repair.
ponbigi is offline   Reply With Quote
Old 01-20-2011, 06:27 PM   #86
ponbigi
ponbigi's Avatar
Originally Posted by denster View Post
I have an idea.... Since a lot of us are facing a similiar problem with GM telling us they never heard of this problem, and also when we take it to the dealer, they say they never heard of this problem.
How about we start posting the Contact Name and Contact information for the dealer and the service manager of the dealerships that have found AND DONE SOMETHING about this problem. then we can give it to our dealers when they get all stupid and say they have no idea what to do about this.
Pattie Vantine Service Advisor #7194*W*
Chapman Chevrolet
480-838-1234
Tempe, AZ
Old 01-21-2011, 01:33 AM   #87
sixty9fordkiller
bowtie junkie
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
man, it sucks to have that problem. Ive grinded shifting into second gear twice but that was because i didnt time it right when releasing the clutch pedal. 2 times ive grinded second and i drive my car hard and no problems ever. I change the brake/clutch fluid with every oil change and changed the gear oil on the tranny at 10k. no problems here. i can shift fast and hard. All i have to worry about it the rear end trying to run circles around my front end when i shift
Ill tell you this much, changing the tranny oil made it shift much, much smoother than stock.
sixty9fordkiller is offline   Reply With Quote
Old 01-21-2011, 07:58 AM   #88
jpizzle007
jpizzle007's Avatar
Drives: '10 LS3, '11 328i, '78 El Camino
I agree, changed out the fluid to RP and it helped quite a bit. I know for some this won't help.
What sucks is I want to get LTs and tune, but I won't do it in fear of tranny problems. If I thought the tranny was safe I would tune it.
Custom stainless steel catch-can, Halltech Yellow Jacket CAI, T-304 MBRP 3" CB, Solo HiFlow Cats, TSW Interlagos Matte Black, Nitto Invos 275/315, SkipShift Eliminator, MGW ShortThrow Shifter, Flux Capacitor - fully tweeked
jpizzle007 is offline   Reply With Quote
Old 01-21-2011, 08:49 AM   #89
Russell James
Russell James's Avatar
Drives: Camaros
The only bulletin I know of just lists a whole bunch of things they claim are either normal or blame on driver error.
If something is mucked up, their just going to replace parts with the same fragile synchros and blocking rings it came with. Tremec and GM need to get their shit together on these shifting problems that have been going on for years.
Tremec updated the guts of the TR6060 with larger gears to account for todays higher hp engines. While leaving the case exactly the same size, leave room only for mini sized synchros. Quite the half ass'd update. Next time, hopefully with a different trans supplier, the internals need to be designed and spec'd for the load, then design the trans case to meet the needs of those internals. Not the other way around. A case designed over a decade ago just doesn't fit the bill today. But I'm sure they saved some nice coin not redesigned a new case.
Old 01-26-2011, 04:10 PM   #90
mad@gm
Drives: was a 2010 2SS/RS
M/T - Operating Characteristics INFORMATION
Bulletin No.: 03-07-29-004F
Date: July 29, 2009
Subject: Manual Transmission Operating Characteristics
Models:
2010 and Prior Passenger Cars and Light Duty Trucks (Including Saturn)
2009 and Prior Chevrolet and GMC Medium Duty Trucks
2006-2010 HUMMER H3
with Manual Transmission Supercede:
This bulletin is being revised to add the 2010 model year and remove Isuzu from the models. Please discard Corporate Bulletin Number 03-07-29-004E (Section 07 - Transmission/Transaxle). Important
Even though this bulletin attempts to cover operating characteristics of manual transmissions, it cannot be all inclusive. Be sure to compare any questionable concerns to a similar vehicle and if possible, with similar mileage. Even though many of the conditions are described as characteristics and may not be durability issues, GM may attempt to improve specific issues for customer satisfaction. The purpose of this bulletin is to assist in identifying characteristics of manual transmissions that repair attempts will not change. The following are explanations and examples of conditions that will generally occur in all manual transmissions. All noises will vary between transmissions due to build variation, type of transmission (usually the more heavy duty, the more noise), type of flywheel and clutch, level of insulation, etc.
Basic Information
Many transmission noises are created by the firing pulses of the engine. Each firing pulse creates a sudden change in angular acceleration at the crankshaft. These changes in speed can be reduced with clutch damper springs and dual mass flywheels. However, some speed variation will make it through to the transmission. This can create noise as the various gears will accel and decel against each other because of required clearances.
Gear Rattle
Rattling or grinding (not to be confused with a missed shift type of grinding, also described as a combustion knock type of noise) type noises usually occur while operating the engine at low RPMs (lugging the engine). This can occur while accelerating from a stop (for example, a Corvette) or while operating at low RPMs while under a load (for example, Kodiak in a lower gear and at low engine speed). Vehicles equipped with a dual-mass flywheel (for example, a 3500 HD Sierra with the 6-speed manual and Duramax(R)) will have reduced noise levels as compared to vehicles without (for example, a 4500 Kodiak with the 6-speed manual and Duramax(R)). However, dual-mass flywheels do not eliminate all noise.
Neutral Rattle
There are often concerns of rattle while idling in neutral with the clutch engaged. This is related to the changes in angular acceleration described earlier. This is a light rattle, and once again, vehicles with dual mass flywheels will have reduced noise. If the engine is shut off while idling in neutral with the clutch engaged, the sudden stop of the engine will create a rapid change in angular acceleration that even dual mass flywheels cannot compensate. Because of the mass of all the components, this will create a noise. This type of noise should not be heard if the clutch is released (pedal pushed to the floor).
Backlash
Backlash noise is created when changing engine or driveline loading. This can occur when accelerating from a stop, coming to a stop, or applying and releasing the throttle (loading and unloading the driveline). This will vary based on vehicle type, build variations, driver input, vehicle loading, etc. and is created from the necessary clearance between all of the mating gears in the transmission, axle(s) and transfer case (if equipped).
Shift Effort
Shift effort will vary among different style transmissions and synchronizer designs. Usually the more heavy duty the transmission, the higher the shift effort because of the increased mass of the components. Shift effort can also be higher in cold weather because the fluid will be thicker. Medium duty transmissions will not shift as quickly as a Corvette transmission. To reduce shift effort, do not attempt to rush the shift - allow the synchronizers to work as designed. Shifting harder will only increase the chance of rushing past the synchronizer leading to grinding while shifting.
Non-Synchronized Gears
Some light duty truck transmissions in 1st gear (creeper-gear) and reverse gears in various transmissions, along with all gears in some medium duty transmissions, may be non-synchronized. This means there is not a mechanism to match input and output shaft speeds to allow for a smooth shift. This function is left up to the driver. This can be noticed if a shift into 1st or reverse is attempted while the vehicle is rolling or before the input shaft stops rotating leading to a gear grind. The grinding can be reduced by coming to a complete stop and pausing for a moment before shifting into the 1st or reverse gear. Some slight grinding can be expected. In medium duty non-synchronized transmissions, the driver must match input shaft (engine) speed to output shaft (driveshaft) speed with every shift. This can be accomplished by double clutching, or by using other methods. If the driver is not able to perform this function properly, there will be gear grinding with each improperly completed shift. Driver training may be required to correct this condition. Clutch brakes are used in medium duty non-synchronized transmissions to allow a shift into gear at a stop. The clutch brake is used to stop the input shaft from spinning, allowing a shift into gear at a stop without grinding. The clutch brake is activated by pressing the clutch pedal all the way to the floor. When the clutch brake is used, it is possible to have a blocked shift with the vehicle stationary. If this occurs, engage the clutch slightly to rotate the input gear to allow the shift. The clutch brake is intended to only be used while at a stop. Care must be taken to not activate the clutch brake while shifting between gears. This could lead to excessive grinding or a blocked or missed shift.
Skip Shift
Currently, the Cadillac CTS-V, Pontiac GTO, Chevrolet Corvette and Camaro SS (other models may follow) equipped with the 6-speed manual transmission have a feature referred to as a "skip-shift". This feature only allows a shift from 1st to 4th gear when the indicator lamp is illuminated on the dash. Dealers cannot disable this feature as it was established to help meet fuel economy standards. The conditions for this feature are: engine coolant at normal operating temperature, vehicle speed of 24-31 km/h (15-19 mph), 21% or less throttle being used (refer to Service Information or the Owner Manual for more details.)
mad@gm is offline   Reply With Quote
Old 01-26-2011, 04:13 PM   #91
mad@gm
Originally Posted by dcoates View Post
I sure would like to see what is in that TSB for the shift problem!
As seen in the tsb, the problem is the "driver" not the product, don't forget that its operating as designed!
Old 02-04-2011, 09:49 AM   #92
dcoates
dcoates's Avatar
Drives: 2010 CAMARO 2SS/RS
Got my car back last week, replaced transmission for the 2nd-gear grind thing, better than ever with the shifting.
still notchy, but we live with that don't we?!
2010 CAMARO 2SS/RS, M6, Yellow with Rally stripes, Borla factory exhaust....426HP YEE HAAHH...
dcoates is offline   Reply With Quote
Old 02-04-2011, 11:18 AM   #93
eckerj
Drives: 2010 Camaro 2LT
Does the "Non-Synchronized Gears" section apply to V6 Manuals? Lately, when I've
been at a stoplight (i.e. car not moving at all), with the clutch fully pressed, I'll try
shifting from 1st to 2nd. The transmission won't let me get fully into 2nd, unless I let
the clutch out slightly.
I've always found my car to be difficult to shift, and have "ground" shifts into 2nd and
occasionally 3rd, thinking it was just my inexperience.
Beginning to sound like I need to bring it in to the dealership.
eckerj is offline   Reply With Quote
Old 02-05-2011, 10:15 AM   #94
Rick@RKT56
Rick@RKT56's Avatar
Drives: Corvette
The V6 and V8 transmissions are fully synchronized.
Rick@RKT56 is offline   Reply With Quote
Old 02-05-2011, 02:45 PM   #95
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
These transmissions will be stubborn like this especially when they're cold. Make note of the trans temp if you have the gauge pack. After 20 minutes of driving or so I don't have the issue.
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 02-05-2011, 04:39 PM   #96
eckerj
This happens at all times for me even after coming home from a long
commute...
Old 02-05-2011, 04:43 PM   #97
ckaram
ckaram's Avatar
commute...
Dealer then.
Old 02-09-2011, 01:54 PM   #98
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Any updates on that bulletin? My car is in for this and I'm getting the bs that everyone else has gotten....
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
