JDP Motorsports
Old 11-15-2010, 09:10 AM   #1
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Help on zex window switch PLEASE
Can someone post a pic or some info on where to splice in to get a signal on the LLT? We checked every wire in the bundle and nothing.
ROD1 is offline   Reply With Quote
Old 11-15-2010, 11:36 AM   #2
HDRS
Fastest V6
HDRS's Avatar
Drives: 2010 CGM 2LT/RS 06 G6 GTP conv.
I think rod needs to know were to tie in for the tach signal.
1/4 Mile 11.841 at 113.98mph
SEPA5 /TEAM LLT
HDRS is offline   Reply With Quote
Old 11-15-2010, 11:44 AM   #3
HDRS
Fastest V6
HDRS's Avatar
Rod looking at the WIKI it says use the white wire on any of the fuel injectors
SEPA5 /TEAM LLT
Old 11-15-2010, 03:12 PM   #4
ROD1
Retired
Ahh never thought to look there! Thanks man!
Old 11-15-2010, 03:43 PM   #5
ROD1
Retired
I looked but.. Where did you find it in wiki?
Old 11-15-2010, 04:27 PM   #6
HDRS
Fastest V6
HDRS's Avatar
SEPA5 /TEAM LLT
Old 11-15-2010, 04:31 PM   #7
ROD1
Retired
Ahh, Thanks. Ok so the solid color wire. Good to go!
Old 11-15-2010, 04:54 PM   #8
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Yeah, that's where they connect when I dyno mine.
BTW, just noticed the avatar change, very funny
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 11-16-2010, 02:10 AM   #9
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
Hey Rod, FYI, I had to remove the intake manifold when I tapped into then fuel injector line to pulse my meth pump. It was hard to figure the correct wire without seeing the injectors. Sorry, I didn't take pictures when I did mine. Just giving you a heads up if you are looking for a signal from the injectors as I'm not familiar with the N20 set-up.
Z Madness is offline   Reply With Quote
Old 11-17-2010, 04:23 PM   #10
ROD1
Retired
Im hopin there is an option to pulling the Intake ..... We tried of the plug wire but no avail.
Old 11-17-2010, 04:41 PM   #11
GretchenGotGrowl
I know we got a good signal using the solid wire from one of the coils when we dynoed mine. I'll look at that agin next time i dyno and take a picture.
By the way ROD1, I probably won't get the fuel pressure readings this weekend. Bell is late with the IC so my car will still be disabled this weekend.
Old 11-17-2010, 06:50 PM   #12
ROD1
Retired
Maybe Ill stop down to the auto parts store and do the loan program on one tomorrow. The jets Im getting good AFR with indicate that the pressure is 90. Peeps say its 45 though. There again, this DI thing is a new animal and there may be more going on.
DIY-Wired DRLs with switch to have full control over DRLs IROCanSS Cosmetics and Lighting Modification Discussions 33 04-13-2015 10:27 PM
How To Wire Dual Halos On Single Switch kismyss Camaro DIY & HOW-TO instructions & discussions 54 05-06-2014 12:18 PM
Question for someone with zex window switch. ROD1 Forced Induction - V8 0 11-14-2010 11:44 AM
Need a duplicate Camaro window sticker (for 1977-2010 models)? Tran 5th Gen Camaro SS LS LT General Discussions 13 10-08-2009 01:32 PM
WIndow scratches Tantalizer43 5th Gen Camaro SS LS LT General Discussions 0 08-29-2009 12:09 PM
