Old 11-15-2010, 09:47 AM   #1
2ss black
2ss black's Avatar
Drives: black2ss
how many made
how many made modifications to the stock air box and what did u do to it i have a k&n filter and new era intake pipe and yes i can feel a different in power. i do not care what anyone say also i do not want to pay $300 to 500 dollars for a cai when the stock air box is just as good thank
2ss black is offline   Reply With Quote
Old 11-15-2010, 10:30 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
No offense but if the stock airbox is just as good as the rest, why are you looking for mods for it?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-15-2010, 11:20 AM   #3
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Then, you will never Reap the Benefits of a Cold Air Kit.
There is a lot more to it than meets the eye.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
JANNETTYRACING is online now   Reply With Quote
Old 11-15-2010, 12:53 PM   #4
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
i put mine in my spare bedroom and installed a c.a.i. brand cai in the car.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 11-15-2010, 01:02 PM   #5
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
from an untrained eye, I noticed these differences in CAIs vs the stock airbox.
1) high flow filter
2) intake tube with no resonance chambers
3) most have a larger opening behind the headlamp than the stock intake which only has a smaller diameter tube to pull air in from.
1) allows more air to get in, but also allows a tiny bit more debris
2) increases engine noise (most people like this) and may also change the airflow harmonics (hopefully for the better)
3) Not really sure if this is better or not to be honest, there must be a reason GM decided not to leave a large hole in the side of the airbox like most CAIs have... But from my perspective, it would appear that a bigger hole means air is more easily sucked into the filter versus the stock setup.
So from what I can really tell regarding a CAI, the air is pulled from the same place as the stock intake. The high flow filter allows more air in with less force.
But I cannot understand for the life of me why some CAIs such as the CAI inc intake do not have a much of a temperature rise at high RPMs as the stock intake. I know the CAI inc intake has a coated intake tube. I am not sure if this makes all the difference. But it's interesting.
cab2g is offline   Reply With Quote
Old 11-15-2010, 06:12 PM   #6
axis
Search Ninja
axis's Avatar
Just using my common sense thought process, the stock intake draws ALL it's air via the little scoop in to the funnel from the box. That scoop draws it's air right off the edge of the radiator. I don't know how much this affects the temps, with the OEM setup, but i'm sure it doesn't help. The others can access the air from the bottom and all around the headlight which will help in increasing the amount of air available, in addition to NOT coming off the hot radiator.
Halltech CF 102 fed
Something To Think About!! 3whiterag General Automotive + Other Cars Discussion 15 06-06-2012 06:44 PM
4 Gauge Pack on made ;o) Blacky Cosmetics and Lighting Modification Discussions 8 12-30-2009 05:53 PM
a couple of redubeds that made me lol so hard 305pride Off-topic Discussions 11 12-07-2009 02:03 PM
Made in Canada Camaro23 5th Gen Camaro SS LS LT General Discussions 104 07-17-2009 09:05 AM
Going Green, Means going Made In China One Mean Chevy Off-topic Discussions 0 04-26-2009 01:04 AM
