Flowmaster Exhaust
Old 11-17-2010, 12:34 AM   #1
GrinderSS
Drives: IOM 2SS/RS
Richmond 4.10's Update
I noticed on a new/recent set of Richmond 4.10's a friend bought for his Camaro they included a special setup instruction sheet. They recommend a "deep" tooth pattern (i.e., shallower pinion depth) to improve durability.
After helping him setup his I pulled mine and reset them, this also solve a very slight whine I was hearing at 45 MPH. They're perfectly quiet now.
Anyway, for those of you with Richmond 4.10's you may want to contact them for a copy of that setup sheet and have your gears checked/reconfigured.
GrinderSS is offline   Reply With Quote
Old 11-17-2010, 12:37 AM   #2
I want 4.10's
Old 11-17-2010, 07:56 AM   #3
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
I busted up my old ones...... richmond sent me a new set for free (but i still have to pay for a new installation kit). I might try this out.....
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 11-17-2010, 08:08 AM   #4
SC2150
Good info!
Old 11-17-2010, 03:31 PM   #5
danhr
BAMF SS
danhr's Avatar
I just got my replacement 4.10 set from richmond, and my set also says "This gear set has been developed with a special tooth contact pattern to help this set take more load"....
This rubs me the wrong way.....
People have sent their broken 4.10 ring and pinion in to richmond for warranty purposes, and from those broken gear sets, they have figured that "it needs to be set with a special pattern"
It's nice to know that Richmond used it's customers as part of their R & D for their gears. Sure they replaced my gears, but what about the hidden costs?
They didn't replace the installation kit, that I'm going to have to buy again.
They didn't reimburse any installation fees. seeing how I have to get the gears installed TWICE because of richmond
They didn't want to reimburse any of the parts that broke as a result from their improper installation instructions (if this new pattern even works)
Fortunately for me, my camaro is not my daily driver, but if it was, I highly doubt they would reimburse any sort of rental car fee, as it's because of their defective product/improper installation instructions that my ring and pinion broke in the first place.
In case anyone is wondering, I have the back of one finger towards South Carolina right now.
/rant
Old 11-17-2010, 03:51 PM   #6
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
so how much did you change the pinion depth to get this deeper pattern? what was your factory pinion shim and what did you end up with?
can you scan those new instructions and post them up for everyone. do they give a pic of their approved deeper pattern.
Old 11-17-2010, 05:58 PM   #7
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
maybe Richmond is on this site and chime in on the update or a vendor can help?
chopss is offline   Reply With Quote
Old 11-17-2010, 06:00 PM   #8
danhr
BAMF SS
danhr's Avatar
the instructions come with tw pictures of their "ideal" pattern.... one of the coast side and one of the load side
I will scan it tomorrow at work.... the only thing I could do with it right now, is take a picture of it with my phone, and that won't do much of anything.
Old 11-17-2010, 06:36 PM   #9
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
PLEASE
is it possible that these instructions would only apply to the newer gear sets?
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 11-18-2010, 07:33 AM   #10
danhr
BAMF SS
danhr's Avatar
and I'm thinking no. My first set of 4.10's, all the ring gear teeth broke on the outside of the ring gear (and I'm assuming that everyone else's gears broke in the same fashion) , so I'm assuming Richmond saw this problem, and figured with with a deeper tooth pattern, that it won't put such a load on the outside of the ring gear.
The new set of 4.10's that I recieved look just like the first set I got
Old 11-18-2010, 07:46 AM   #11
Never Satisfied
220/221 whatever it takes
Never Satisfied's Avatar
Drives: See sig....
Thanks for posting. I'm very interested to see how your's hold up with the deeper pattern.
Brent
2018 JL Wrangler Rubicon 2-door (on order)
2017 Scat Pack Shaker A8
2016 Challenger Hellcat A8
Never Satisfied is offline   Reply With Quote
Old 11-18-2010, 07:50 AM   #12
danhr
BAMF SS
danhr's Avatar
yyyeeeaaaahhhhh...... ummmmm i'm still kinda skeptical. Right now I dont know if I want to risk running them again, and just sell them.
I'm going to be calling them later today, and ask them what kind of warranty will this new "pattern" hold. If they tell me if the gears break again, then I have to go through all of this again, you will be seeing a set of richmond 4.10 gears for sale in the classifieds section...... I'll just cut my losses, run stock gears :(, and pray that I win the lottery, so I can afford to do a 9" conversion
Old 11-20-2010, 11:17 PM   #13
GrinderSS
Drives: IOM 2SS/RS
Sorry for the delayed response. My pinion was marked for a depth of 2.742" an I ended up at 2.7405". The back lash setting was recommended to be 0.008". I actually took a chance and set it a bit tighter at slightly over 0.007". I have 130 miles on them, so far so good.
Old 01-22-2011, 07:32 AM   #14
ProudLS
ProudLS's Avatar
Drives: Camaro SS
I just ordered mine from Livernois and I am kinda worried :(
2010 Black/Black SS RS M6, ARH headers, Hi-flow cats w/x-pipe, Fastlane CAI, Livernois Camshaft 2C, SLP 160 Stat, SLP underdrive pulley, Hurst, Eibach lower spring, BMR lower control arms, BMR toe rods, Razzi body kit and Borla axle back. Tuned by me HPT.
ProudLS is offline   Reply With Quote
PDIM Software Update codeman71 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1189 07-12-2017 08:41 PM
Richmond 4.33 Rear End Gears Available At Apex Motorsports!!! Apex Motorsports Transmission / Driveline 84 05-13-2011 03:26 PM
Richmond 4.10's Incinerated! Wacker Transmission / Driveline 57 09-21-2010 11:50 PM
Just "tested" my Richmond 4.10's GrinderSS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 07-15-2010 09:36 PM
4.10/3.73 Richmond Gears and Install Kits Now available at New Era!!! SMGSS Transmission / Driveline 6 07-08-2010 12:34 PM
