HeadlightArmor
Old 11-17-2010, 04:28 PM   #1
FRANK121
FRANK121's Avatar
Drives: 2011 Camaro SS
Differential Change Step By Step
Does anyone have the step by step instructions to change out the differential fluid?
Thanks!
2011 Victory Red 2SS/RS
630hp. and 550ft. lbs.
Black Rally Stripes
6 Speed Automatic
Whipple 2.9L
LS3 Conversion
ARH LT Headers and X-Pipe
GMMP Axle Backs
Yank 2800 Stall
RotoFab CAI
RX Performance Catch Can
VMAX Ported Throttle Body
Built by C.B.I. Streetcars
Tuned By DSX Tuning
GM Quarter Flares
Camaro Floor Mats
FRANK121 is offline   Reply With Quote
Old 11-17-2010, 05:19 PM   #2
camaro guy
camaro guy's Avatar
Drives: 2010 camaro LS
http://www.camaro5.com/forums/showth...l+fluid+change
this should get you there
camaro guy is offline   Reply With Quote
Old 11-17-2010, 05:42 PM   #3
camaro guy
camaro guy's Avatar
locate the fill plug and drain plug its on the driver side i believe. drain plug is lower. fill plug higher. make sure you loosen the fill plug first(higher plug)...you dont want to drain the fluid and find out you cant get the fill plug off. its messy, it smells, its a pain in the butt to get the fluid in. buy 2 quarts because you will spill some. i jacked up the driver side rear only. loosened both plugs and lowered to level. after fully drained...jacked back up, tightened drain plug and pumped the fluid in with a pump from autozone. pump till it flows out. you cant overfill cuz it will just pour back out..once its full i lowered back down to level and then back up. this allowed the fluid to level out and then i tightened the fill plug and done. wear clothes your willing to toss in the trash cuz the fluid doesnt wash out. i did this in a PT uniform shirt like a moron and had to throw away. good luck its easy. sorry i dont have pics.
oh and make sure the car has been cooled down for a few hours. you will be maneuvering over exhaust pipes and they stay hot for awhile!
Old 11-22-2010, 08:35 PM   #4
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Don't forget to do the tight figure 8's when you're done - this is required to work the fluid into the clutch packs and prevent whining and possible damage...
Old 11-22-2010, 08:40 PM   #5
FRANK121
FRANK121's Avatar
Figure 8's
I got to do a couple rounds of figure 8's in the parking lot before people started wondering ... What the hell is that idiot doing?
So far everything is smooth and quiet
Black Rally Stripes
6 Speed Automatic
Whipple 2.9L
LS3 Conversion
GMMP Axle Backs
Yank 2800 Stall
RotoFab CAI
Tuned By DSX Tuning
GM Quarter Flares
Camaro Floor Mats
Old 11-23-2010, 11:38 PM   #6
camaro guy
camaro guy's Avatar
i never did that and mine is great!
What song are you listening to right now Muscle Master Off-topic Discussions 6400 Yesterday 08:20 PM
TAKE A LOOK WHAT I FOUND WHEN I CAME OUT OF THE STORE billmiller8 Camaro Photos | Spyshots | Video | Media Gallery 98 05-08-2010 06:38 PM
The proof that i'm changing. Tactical Z Off-topic Discussions 64 02-10-2009 11:38 PM
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over bigralph Off-topic Discussions 15 02-06-2009 08:07 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
