Solo Performance
Old 01-12-2009, 01:39 PM   #1
TheMadHatter99
Kept the Faith
TheMadHatter99's Avatar
Drives: '10 Camaro 2SS/RS CGM
Differential Question
I'm working on a project for my Physics of Motorsports class (coolest class EVAR) where I will calculate the theoretical/ideal 0-60 and 1/4 mile times for the Camaro. I've got practically all of the other numbers I need, but does anyone know the gear ratio for the rear differential?
Thanks in advance, and once I have my results I'll be sure to post it all up here.
TheMadHatter99 is offline   Reply With Quote
Old 01-12-2009, 01:41 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2013 Sonic Hatch
3.27 for all models, except: 3.45 for Manual SS.
Let us know how it all turns out, it ought to be cool!
Old 01-12-2009, 01:43 PM   #3
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
if you wanna make it look better, we're supposed to get a 3.73 option in 2011.
Old 01-12-2009, 01:44 PM   #4
TheMadHatter99
Kept the Faith
Isn't 3.45 the transmission ratio? The differential should have its own, or are they the same?
Old 01-12-2009, 01:58 PM   #5
Mr. Wyndham
The transmission has 6 different ratios...I'm not sure what you mean about that...
The numbers I provided are for just the differentials, and the number zebra provided was a future differential option.
Old 01-12-2009, 02:08 PM   #6
Mr Twisty
Mr Twisty's Avatar
Dragon gave you good numbers. How accurate do you need to be? weight? trans gearing? tire patch & size/diameter/width? HP/torque? Need these numbers also.
Mr Twisty is online now   Reply With Quote
Old 01-12-2009, 02:12 PM   #7
TheMadHatter99
Kept the Faith
Yeah, we're using mass, tire radius, gear ratios (preferably the trans and rear diff ratios, to be most accurate) and then I'm going to use the G8 GXP HP/Torque curve chart since that's the closest we've got (same engine and same basic chassis).
I have everything but the rear diff ratio and don't really know where to find that, hence the thread.
Any suggestions?
Old 01-12-2009, 02:19 PM   #8
Mr. Wyndham
This is everything you should ever need in terms of gear ratios.
PAGE 3:
http://www.chevrolet.com/camaro/pdf/...ifications.pdf
Old 01-12-2009, 02:45 PM   #9
zebra
zebra's Avatar
^^ thanks! i never could remember where i saw that
Old 01-12-2009, 03:54 PM   #10
TheMadHatter99
Kept the Faith
Thanks a lot Dragon, I'll flip through it and see if I can find what my prof was talking about.
Old 01-13-2009, 12:08 PM   #11
69 rs/ss
69 rs/ss's Avatar
Drives: 1969 rs/ss & 2010 L99 #3747 4/28/09
Try this site...
http://home.att.net/~numericana/answ...mula.htm#0to60
69 rs/ss is offline   Reply With Quote
Old 01-13-2009, 03:41 PM   #12
trm0002
VIN #2G1FT1EW6A9100074
trm0002's Avatar
Drives: 2010 CAMARO 2SS/RS RJT VIN 00074
Send a message via AIM to trm0002
I got bored today at work; see if this helps at all...
**edit-> as noted below this is with 17" tires (someone was asking me about them). See a few posts down for the 20" spreadsheet.
trm0002 is offline   Reply With Quote
Old 01-13-2009, 04:08 PM   #13
99b4c
Drives: 89 RS/99 GTP/1SS soon
Anyone know what the diameter of the ring gear will be?
99b4c is offline   Reply With Quote
Old 01-14-2009, 06:20 AM   #14
SScattergunSS
~ Love or Lust ~
SScattergunSS's Avatar
Drives: R6P 1SS/RS BLK/L99
I think it's cool you took the time, but I think the rear wheel / tire diameter is 28.66" not 25.66".
~ Then conquer we must, when our cause it is just, And this be our motto, "In God is our trust." And the Star Spangled Banner in triumph shall wave O'er the land of the free and the home of the brave ~ Francis Scott Key ~
SScattergunSS is offline   Reply With Quote
question about camaro affordability ChevyCowboy Canada 8 01-08-2009 06:02 AM
Exhaust question ElManny Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 01-02-2009 09:41 PM
2SS exhaust, 2 part question. HELP!! 2SS is mine!! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 11-16-2008 06:51 PM
IRS question 454lsxss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2008 09:06 PM
Noob Camaro Question goose7919 5th Gen Camaro SS LS LT General Discussions 13 09-23-2007 08:26 PM
