Caryle Racing
Old 01-12-2009, 06:24 PM   #1
bigrich2021
Drives: Impala
buying a 4th gen camaro I have some quuestions
well I have a 05 impala and I want a car I can have fun in but I don't need a new care just something I can work on. I was wondering if I got a v6 manual can I do burn outs with both wheels spinning because I seen some that only have one tire spinning. And how much do I look to spend for it It just has to be running
bigrich2021 is offline   Reply With Quote
Old 01-12-2009, 06:34 PM   #2
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
get an '01 or '02 3.8L V6 car with manual transmission... its about as good as you're going to get for fun with the V6... I believe some of the V6s had the limited slip diff, but replacing the open diff with a posi unit isn't too hard to do... taking it to a local drivetrain shop would probably cost you in the area of $600 to get the parts and do the swap.
honestly, though, there are LS1 cars to be had now for anywhere from $4000-$6000 with high mileage... I'd just get one of those, enjoy the V8 while it lasts, then put an LS3 or modded LS1 in when that engines finally goes south.
just a thought.
got tequila?
SilverTurtle is offline   Reply With Quote
Old 01-12-2009, 07:01 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
but you have to keep in mind that there's more to the swap than just the motor. the trans, suspension, electronics, fuel system, etc all has to be changed when putting a v-8 into the v-6 f-bods.
if you get a v-6 4th gen, try to find one post '95 so that it has the 3.8L v-6 as it is a little more robust than the 3.4L.
however, as mentioned above, you can find v-8 4th gens for great prices. sure they might have some miles or some peeling paint or a busted center console, but thats minor cosmetic stuff.
as far as a v-6 doing a dual wheel burnout, check the rpo codes for a G80 for a limited slip rear end.
I piss excellence
and fart awesomeness
Old 01-12-2009, 07:03 PM   #4
Boomer Sooner
Banned
Drives: my girlfriend nuts
Don't be afraid of high mileage ls1's as long as they've been taken care of. I just turned over 180xxx on my 99 z28 and it still pulls like crazy and runs strong(I will admit I do tend to get on it/hot rod it more than I should considering the mileage, but it hasnt given me any major problems since I've had it). I got mine 4 years ago and it was bone stock, down to the paper filter.
I've added a few little things but nothing big. Take care of it and it will take care of you. Keep fluids changed/checked regularly and your basic vehicle maintnence up to date and you should be fine.
I wouldn't get a v6, I'd hold off until you can find a LS1 you can afford.(<--From experience) I still have my 99 3.8l that I drove for about a year before I found my z28. After driving my z for so long, whenever I decide(which is very, very rare) to drive my 3.8l it seems so freakin slow and sluggish.
Good luck with your purchase, regardless of your decision.
Boomer Sooner is offline   Reply With Quote
Old 01-12-2009, 11:50 PM   #5
bigrich2021
Drives: Impala
Thanks for everybodys help I think a z28 would be the best bet I guess I just didn't want to spend to much so I might just wait for the right deal .
Old 01-13-2009, 12:59 AM   #6
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
quick reminder, 2001, 02 LS1's come with the LS6 intake manifold
TFord is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 12:04 PM
2010 Camaro V6 vs. 4th gen Camaro Z28 thejbyrd Chevy Camaro vs... 25 06-11-2012 08:40 AM
UPCOMING CAMARO IMPORTANT DATES CamaroScotty 5th Gen Camaro SS LS LT General Discussions 125 01-11-2009 12:31 AM
Consumer Guide's Impressions of the 2010 Chevrolet Camaro camaro5 5th Gen Camaro SS LS LT General Discussions 30 04-29-2008 10:20 PM
