Old 11-20-2010, 05:49 PM   #1
Gbusy06
Tap Out
Drives: 2011 Camaro SS A6 SGM
Best Tune?
I need your recommendations for the best tune based on your personal experience and gains with your 2010/11 Camaro SS. I recently installed Kooks LTs w/catts and a Vararam CAI. I am now ready for a tune. I will add 160 stat. Thanks for any input you may have.
Gbusy06 is offline   Reply With Quote
Old 11-20-2010, 06:29 PM   #2
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
The best tune will be done by a local professional with a lot of skill tuning LSX powered vehicles. He will put your car on the dyno (base line it and tune it) and then run it on the street (fine tune it). You should have some talented tuners in your area.
Thunderracing in in Lousiana. I'm sure there are some more good shops.
http://www.thunderracing.com/shop-by...uning_577.html
Old 11-20-2010, 06:44 PM   #3
Gbusy06
Tap Out
Not sure if they are tuning at present. However, I will check with them as I did a few weeks ago. I prefer a tune in which I could go back stock if I had to bring car in for service. Thanks for the response.
Old 11-20-2010, 07:07 PM   #4
Supercharged SS
Drives: 2010 Camaro
Call Jannetty Racing and get and SCT from him. The tune will be great and it will allow you to go back to stock as you want.
Old 11-21-2010, 06:04 PM   #5
Gbusy06
Tap Out
Thanks, I will call Jannetty Racing tomorrow. Damn SS, your ride is fast!!!
Old 11-21-2010, 06:43 PM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
just to let you know... when i got my custom dyno tune, the guy there saved my stock tune in the computer database, and said i could always come back and they would put in back to stock for free, with no problems
Old 11-21-2010, 06:53 PM   #7
cpssr
Drives: 2010 2SS/RS
Not sure where you are in Lousiana but give Jason a call at Lucky's Speed (903-720-3695). He can hook you up with a SCT tune or Dyno/Street tune.
Chris
cpssr is offline   Reply With Quote
Old 11-21-2010, 07:19 PM   #8
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
Wherever I go, I hope they'll give/send me the stock file and the tune file.
xxlbeerz is offline   Reply With Quote
Old 03-31-2012, 03:25 AM   #9
Dennis SS
Always Lookin
Dennis SS's Avatar
Drives: 10 SS/RS 6M Blk/Blk Silver Stripes
I had a HP Tuner tune from National Speed and the results was pretty impressive! Night and day difference at every level.
-Custom grind Crane Cam with 3 bolt conversion, Lunati springs, harden push rods, SLP oil pump, LS2 tensioner
- Kooks Custom Headers. X-pipe, mufflers, high flow cats,
-Tuned by National Speed in Wilmington N. Carolina, HP Tuner 490rwhp and 483rwtq
-Skip shift eliminator
-RX Catch Can
-CAI intake
-Hurst Shifter, with custom Speed Dawg
Dennis SS is offline   Reply With Quote
Old 03-31-2012, 09:25 AM   #10
InfernoSS454
InfernoSS454's Avatar
Drives: 2010 camaro ss
Give lethal racing a call their in lafayette.
InfernoSS454 is offline   Reply With Quote
Old 03-31-2012, 09:58 AM   #11
Sebastian
Sebastian's Avatar
Drives: Camaro 2011, 6.2L 2SS
go for Ted @ Jannetty!
My Fat-Lady: Stainless Work Turbo-S Tube Catback, K&N Intake, Dynatech Dynamaxx 1 7/8 Headers with Cats, Tune from Janetty Racing + SCT Tuner, Granatelli Motorsport 0hms Red Ignition Wires (high Temp)
to be continued sooner!!!
Sebastian is offline   Reply With Quote
Old 03-31-2012, 09:59 AM   #12
jcollins91106
jcollins91106's Avatar
Drives: 2010 2ss m6
jannety racing, I have their tune. I have never heard or seen anything less than great come from them. Ted will work with you and get your car exactly where you want
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
jcollins91106 is offline   Reply With Quote
Old 03-31-2012, 10:25 AM   #13
caverman
caverman's Avatar
Drives: '69 SS Convertible
I vote for Jannetty tune in the case as well.
Just realize that you can put your stock tune back but if you have any warranty issues that GM will be able to tell it's been re-tuned by a non-GM tune and will probably deny the work to be covered under warranty.
It's not like the good old days when you could do that. GM got wise to that little trick and make it so that they record every tune. So there is now a log of what went on.
Oh...and buying a whole new ECM isn't supposed to work anymore either because of the way the VIN is tied to it. I'm not sure the details on that one but that's what I've heard through the rumor mill.
If you tune your car you need to be able to accept the fact that you'll probably loose your drivetrain warranty.
Build Journal
Old 03-31-2012, 11:36 AM   #14
jcollins91106
Drives: 2010 2ss m6
+1 once shes tuned shes tuned, you can go back to stock parameters, but its the end of gm touching it under warranty.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 05-18-2013 11:01 PM
Dyno tune comparisons? vernal Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2010 11:43 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
Lets play a game 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 56 09-26-2009 10:08 AM
