Old 11-20-2010, 09:39 PM   #1
1 bad azz ls3
1 bad azz ls3's Avatar
Drives: 2010 camaro ss
anybody have a roll bar and who makes it
I'm trying to find interior roll bar kit. anybody know of any weld in or bolt in kits. and does anybody have pix of theirs..
1 bad azz ls3 is offline   Reply With Quote
Old 11-20-2010, 10:26 PM   #2
SC2150
Most well known shops will have a local fab shop that can hook you up....ask Jannetty or Maryland Speed, they are in the NE.
For any in FL we do full chassis fab in mild or CM.
Old 11-20-2010, 10:47 PM   #3
LAYN2LOW
Drives: 2010 CAMARO 1SS M6
http://www.fastlaneturbo.com/bolt-in...11camaros.aspx
LAYN2LOW is offline   Reply With Quote
Old 11-20-2010, 10:59 PM   #4
Supercharged SS
Drives: 2010 Camaro
Here is the only place to go in the North East! The only problem is that he usually has a few months wait. He did mine last year. It's going back this winter to become a certified 10 pt. This is right when I got the car back last winter so the cage still needed to be wiped down. It looks factory. http://jwracing-fab.com/
Old 11-21-2010, 01:03 AM   #5
SC2150
VERY nice bar!
Old 11-21-2010, 07:28 AM   #6
1 bad azz ls3
that looks real nice. thanks
Old 11-21-2010, 08:23 AM   #7
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Really like it...shame it is so slow and not mass produced and available.....Hmmmmmm..And I said I would be happy staying over 11.5 seconds and not use a roll bar...You guys are killing me....
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 12-13-2010, 04:32 PM   #8
1 bad azz ls3
bump
Old 12-13-2010, 04:44 PM   #9
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
I have a question... does the door bar need to be so high? That looks like it would take up to much arm space. Looks killer though!
Bad70supreme is offline   Reply With Quote
Old 12-13-2010, 04:46 PM   #10
Supercharged SS
Drives: 2010 Camaro
The door bars, or swingouts, come out if the car in 10 seconds. You don't have to drive around with them in. But when I have, they haven't been uncomfortable.
