R1 Concepts
Old 11-20-2010, 09:45 PM   #1
Nachos!!
Whos new car? NACHOS! HA
Drives: CGM 2SS/RS M6
Put on JBA mids and got a light within 10 miles
Well I got my JBA mids with high flow cats on and got a check engine light in about 10 miles of running. Called onstar and got 3 different codes. What do these mean.
P0050
P0154
P0155
Nachos!! is offline   Reply With Quote
Old 11-20-2010, 10:19 PM   #2
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Those are all O2 sensor codes.
Either the cats in the midpipes are bad or you installed something wrong. I ran my JBA mids CEL free for as long as I had them on the car. I never threw any codes.
Disconnect the battery overnight, hook it back up in the morning and see if the codes come up again.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 11-20-2010, 10:24 PM   #3
spyderbuddy
spyderbuddy's Avatar
just don't lock the trunk
Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 11-20-2010, 10:26 PM   #4
Hicompression
Rumbly Bumble Bee
Yeah, leave the trunklid open or you'll be crawling through the back seat to unlock it in the morning.
-OBX Longtubes FTW!
Old 11-20-2010, 10:42 PM   #5
Nachos!!
They lady from onstar said that one had to do with the transmission and the other had to do with the fuel system. I dunno. As far as something being installed wrong, its pretty strait forward so Im all good in that department. Ill disconnect the battery and see what that does.
Old 11-21-2010, 06:00 AM   #6
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
All three of the codes have to do with the same sensor , Bank 2 sensor 1. Sensor 1 is a pre cat one that you really need working. It's got to be unplugged, if you took care when handling them during the install.
IndeedSS1 is offline   Reply With Quote
Old 11-21-2010, 06:50 AM   #7
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I'd say check that everything is tight. No leaks and plugs connected. Once everything's buttoned up try the battery disconnect and see how she drives.
9/26/09 Took delivery!
Old 11-21-2010, 07:36 AM   #8
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Possible gasket leak issue? I have read about others having this problem also. I have the Solo's. Been on for months with no issues.
Fishdadddy is offline   Reply With Quote
Old 11-21-2010, 09:12 AM   #9
Nachos!!
Went back through everything and its all good. Everything is plugged in and no gasket leaks. I was very careful with the sensors when I was taking everything out. None of them got banged around or anything. I disconnected the battery last night so Ill hook it back up and see what ive got.
Old 11-21-2010, 11:35 AM   #10
IndeedSS1
IndeedSS1's Avatar
Good luck! Hope that takes care of it.
Old 11-21-2010, 12:10 PM   #11
Nachos!!
Well I hooked it all back up and so far so good. Just drove it to church and back home and its not on yet. Hopefully it wont come back on.
Old 11-21-2010, 05:24 PM   #12
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
JBA's always will have a chance of throwing a code. It seems to depend more on the car than anything.
www.marylandspeed.com * 443-730-9428 * The Modern Muscle Specialists!
MarylandSpeed is offline   Reply With Quote
