JDP Motorsports
Old 11-21-2010, 06:34 PM   #1
metallicide
metallicide's Avatar
Drives: 2010 Camaro 2SS
header install
Gettin ready to get a set of headers...lookin like kooks or ARH. Any special tools needed for install or any tips to make it go easier? Only using jack stands, no lift but thats all I have.
metallicide is offline   Reply With Quote
Old 11-21-2010, 06:41 PM   #2
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
Just normal hand tools. The last time I installed headers I bought some 8-stage bolts so I did not have to worry about the bolts coming loose.
Good luck.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 11-21-2010, 06:42 PM   #3
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
There are some install threads on here, getting ready to do mine as well.
Best write-up I've seen:
http://www.planetlsx.com/tech/How_To...0_Camaro_SS/98
Sounds like the main thing you need is a helping hand for the oil dipstick and headers. Also, you're jackstands should be heavy duty type to get the car a couple feet off the ground. The jack and stands I have don't go this high though.
I have quotes to have them installed, but considering DIY so I can use the install money to get more tools.
xxlbeerz is offline   Reply With Quote
Old 11-21-2010, 06:44 PM   #4
Silver Ice Man
Silver Ice Man's Avatar
Drives: 2014 2SS/RS Spring limited edition
The hardest part I found was getting the O2 sensors to release behind the top of the engine, once I finally got those darn things delt with the rest went really good.
Take your time, and enjoy getting to know your car.
2014 2SS/RS, Spring Limited Edition...
Ask yourself.....when you turn on your car..... Does it return the favor.....
MODS: CIA cold air intake, Oil catch can, Dynatech LT Headers, Dynatech Power cats, Dynatech Cat back exhaust, Janetty racing tune, Vitesse throttle controller, Headlight and marker tint, more to follow....
Silver Ice Man is offline   Reply With Quote
Old 11-21-2010, 06:49 PM   #5
steeleshark2
steeleshark2's Avatar
For my headers, one bolt for the dipstick (make sure you locate where it goes before you pull it out. That hole is a bear to find), 6 bolts on each manifold, and 4 bolts for the catback connections. I highly recommend getting an o2 sensor socket and some penetrating oil for the o2 sensors. They are a bear to get off and if you break one its another 50+ dollars (total of 4). If the headers do not come with 2 O2 extender wires for the front 2 o2 sensors, you will need those also. I also hear ARH headers you may have to disconnect the steering knuckle but with Kooks and OBX, didnt have too. Took me 3 hours with a friend really taking our time. 2nd set of hands will be real helpful.
For the wires if not included with the headers:
http://www.racetronix.biz/itemdesc.a...4T-24T&eq=&Tp=
Ceramic coating ? GreyLS3SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 11-20-2010 05:36 PM
MTI Racing Header Shifter Install MTI Racing Kevin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 05-20-2010 04:02 PM
Maggie install (automatic L99) Easy racer778 Forced Induction - V8 27 04-26-2010 05:04 PM
Header install in Central Florida found great place. Ltdodge USA - Southeast 0 02-25-2010 01:32 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
