Caryle Racing
Old 11-22-2010, 01:11 PM   #1
Sean@Phastek
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
Thumbs up Clean Cut Creations heritage grille install in Super Chevy Magazine
From our friends over at Clean Cut Creations and Super Chevy Magazine:
I wanted to share our newest Super Chevy magazine article in the December issue. It shows the detailed install of one of our Pre-painted heritage grilles. Pick up the issue on the newstands to get a copy of your own, or follow along as the pics below show you how to do it yourself at home.
Here are the products offered by Clean Cut Creations. The Heritage Grille is a GM piece and can be sourced from multiple suppliers, but unlike the others Clean Cut will paint it to match any factory color offered on the new Camaro. Also shown are a couple of the emblem options to choose from. We are partial to the Retro SS emblem because it compliments the retro look the grille provides.
Before any color can be sprayed, Grant Burch is going to prep the grille. All the areas that will receive color are scuffed up with a dark grey Scotch-Brite hand pad, which is equivalent to about 600-grit paper.
After the area has been scuffed, the center section where we don't want paint is masked off, both front and rear.
Next, John mixes up some Valspar De Beer Inferno Orange Metallic, dumps it into his spray gun, and works his magic. Again, John can spray the grille in any of the factory Camaro colors. After the base coat is dry, John tops it with a few coats of clear
When it's dry, the part is de-masked to reveal what now looks like a separate grille assembly.
The grille assembly installs from the backside so the front fascia will need to be removed. There are two 10mm bolts at each end of the fascia and 6 scrivets (GM's fancy word for a reusable plastic rivet) that need to be removed from the engine compartment area. The scrivets can be detached with a panel/clip removal tool like the one shown in the photo. You'll want to use the tool to pop out the center of the scrivets, which will release their hold so you can pull the entire scrivet out. There are also two more 10mm bolts under the car that need to be removed.
There are 10 more bolts to remove, five on each side at the front edge of the fender that are hiding behind the wheel well liner. Removing the five Phillips screws and five scrivets allows the liner to come out of the car.
Four of the previously hidden bolts will need a 10mm socket and one will need a 7mm.
That will free the fascia, but you'll still need to unplug the wiring harness that is on the passenger side of the vehicle.
John Meyer and Richard Kuehl carefully remove the fascia from the car and place it on a padded stand. No, the license plate is not installed wrong. This car has an Altec retractable front license plate holder that allows the plate to be slipped under the car for clean looks and popped out when driving to keep Johnny Law happy.
The grille has a bunch of tabs that snap into the fascia. Some even have retaining clips on them that will need to be removed before the tabs can be released.
John uses a panel tool to help him release the tab's grip on the fascia.
After fighting a bunch of tabs, John got it. The egg crate-style grille is placed in the swap meet pile.
Since the new unit going in is freshly painted, John takes his time and slowly installs the grille into the fascia.
Again, since the Heritage grille is a GM piece it has all the proper tabs in all the right places.
Even the factory retaining clips fit into place.
The Retro SS emblem is held on with two screws and a simple backing plate that is not visible from the front.
Finally, the newly upgraded front fascia is reinstalled on the car just like it came off, except in reverse order. As you can see, the painted Heritage grille and Retro SS emblem look more at home than the factory egg crate unit. You are looking at about two hours to swap in the Heritage grille at home with the tools mentioned in the story. The upgrade shown will set you back $467 with shipping. Not too shabby for a new grille that is painted to match and makes such a visual improvement.
A very nice writeup!
Sean@Phastek is offline   Reply With Quote
Old 11-22-2010, 01:26 PM   #2
montej23
montej23's Avatar
Drives: 2011 VR Camaro
nice
montej23 is offline   Reply With Quote
Old 11-23-2010, 01:25 AM   #3
khabboub
Tampa Gulf Coast Family
khabboub's Avatar
Drives: 2010 Black Camaro 2LT M6
i took my bumber off like 2 weeks ago without removing the wheels. i recommend removing them, makes everything just that much easier.
khabboub is offline   Reply With Quote
Old 11-27-2010, 10:38 AM   #4
cerberus
cerberus's Avatar
Drives: 2010 CGM
Nice write up...I have had Clean Cut Creations make many mods to my and all have come out perfect! Nice Job.
2 SS CGM RS, IOM interior, Customized by Clean Cut Creations St. Louis, MO
cerberus is offline   Reply With Quote
Old 12-08-2010, 12:32 PM   #5
CleanCutCreations
CleanCutCreations's Avatar
Drives: 2010 camaro
Thanks!
CleanCutCreations is offline   Reply With Quote
Old 12-08-2010, 12:35 PM   #6
awesome
Old 12-08-2010, 12:35 PM   #7
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
Very nice write up
SlowSS is offline   Reply With Quote
Old 12-16-2010, 11:31 AM   #8
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2010 Summit White Camaro SS/RS
Where di you get the "SS" from? I have seen a bunch of sites that sell different kinds,but not like that. TIA
gl2filmerguy is offline   Reply With Quote
Old 12-25-2010, 06:58 PM   #9
CleanCutCreations
Drives: 2010 camaro
Phastek sells the retro SS emblems for the heritage grille.
Old 12-25-2010, 08:17 PM   #10
Coop
Drives: 2010 Camaro 1SS
So are you guys selling prepainted grilles then?
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
Old 01-07-2011, 05:15 PM   #11
CleanCutCreations
Drives: 2010 camaro
I believe Phastek is. Here is a link:
http://www.phastekperformance.com/GM...age-grille.htm
2010 Camaro SS ProCharger Install Featured in Jan. 2010 Super Chevy! tbyrne Forced Induction - V8 2 07-03-2015 01:56 PM
Camaro Ad Assault Coming! Chevy Returning to Super Bowl. Tran 5th Gen Camaro SS LS LT General Discussions 37 08-18-2010 10:06 PM
Check out my painted stripes article in this months Super Chevy Magazine cerberus Cosmetics and Lighting Modification Discussions 68 03-12-2010 09:08 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
Super Chevy at Maple Grove KBearZ28 USA - NY / NJ / PA 4 07-17-2009 01:10 AM
