Old 11-22-2010, 03:04 PM   #1
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
Question TVS2300 set-up question(s)
After dismissing my plans on going with a n/a setup, I eventually figured out what to do (almost): FI!
The set-up is gonna look like below, target is 550-600rwhp on a 2010 LS3
- TVS2300 (SLP575 Stage1 Package)
- 3.6 Pulley
- MSD Fuel Booster (#2351)
- Kooks 1 7/8 LTs w/ cats
- Volant CAI (already installed)
- SLP LMII Axle-Back (already installed)
- Noweeds (already installed)
- Custome Tune on the above
- LPE ZR1 Twin Disc Clutch (if the stocker calls it a day...)
At a later stage I'm leaning into getting a blower cam and maybe ported heads, but that's the future...
The thing I'm completely uncertain about is the Fuel System in general, or more precisely the Injectors.
Would new injectors be required for such a set-up, as I don't want to end up screwing the engine running to lean?
Together with the MSD, what injectors should I be looking for?
Trying to stay on the "reasonable" side of budgeting, so 800$ max should be the ballpark for the MSD and some adequate injectors...
Anything else I might have forgotten on the above set-up?
Any help out there?
Thanks guys!
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 11-22-2010, 03:26 PM   #2
jrpxxii
jrpxxii's Avatar
If u go with tvs2300 the kit comes with new larger injectors, so yes injectors need to be upgraded with any FI setup. Eventually u will also need an upgraded fuel pump as well once u do cam and heads.
Old 11-22-2010, 04:17 PM   #3
LOUDMIKE
Drives: 2010 2ss, 1967 ss427, 1968 327
We have done a couple of similar builds here but without the camshaft I think you will be in the range of 500 horsepower to the tires. As far as injectors etc goes. Your build setup should be fine for now.
LOUDMIKE is offline   Reply With Quote
Old 11-22-2010, 04:25 PM   #4
TinyToasta
TinyToasta's Avatar
Thanks so far!
Right, let's ignore the cam option for now, as this will be taken care of somewhate later
Does anyone know the specs of the injectors that come along with the SLP Stage1 package?
As far as the 3.6 pulley option is concerned, would it be necessary to upgrade the injectors? The MSD Booster will be installed right away...
500rwhp sound pretty low to me, given the pulley and LTs... do I need to be worried?
Old 11-22-2010, 04:49 PM   #5
carcamaro1
Drives: Camaro SS
I have
TVS2300
3.6 pulley
Long tube kooks 1-7/8
Rotofab CAi
Noweeds diverters
60# inj
501rwhp on an auto. Some other shops say their dyno would only show 450-475rwhp so if that is the case the manual would range 475-525rwhp on the above setup. As for cam I say 600rwhp will be easily acheivalbe but you are probably going to want an in tank fuel supply and larger injecters at that point.
carcamaro1 is offline   Reply With Quote
Old 11-22-2010, 05:43 PM   #6
Jessika
Drives: Anything Blown
Our TVS2300 system comes with ZR1/LS9 injectors which are 52lb/hour @ 58psi 4BAR. These can obviously handle 630+ crank HP...
Jessika is offline   Reply With Quote
Old 11-22-2010, 06:02 PM   #7
TinyToasta
TinyToasta's Avatar
Thanks Jessika for chiming in
Would those 52lb/h injectors be sufficient in combination with a 3.6 pulley/MSD Fuel boost/LTs set-up or would recommend upgrading?
Old 11-22-2010, 06:56 PM   #8
Supercharged SS
Drives: 2010 Camaro
- 3.6 Pulley
Any help out there?
Thanks guys!
On the LS3 you'll be damn close to 550 rwhp. The Airraid may hold back a few. I've seen that exact same setup, put the ADM in place of the Airraid, make 560 rwhp time and time again by Jannetty Racing. Check some of his post about them from last Sept/Oct 09. That set-up will get 500 rwhp on an auto and prob 550 rwhp on the M6. Gd luck!!
Old 11-22-2010, 06:59 PM   #9
Jessika
My guess is that they would be just fine, but in all reality, your tuner will have to answer that one.
Since the ZR1 runs 630+ crank HP, I am sure that these injectors will support you just fine.
Old 11-22-2010, 07:22 PM   #10
Brent_$$
Warp drive in development
Drives: 2010 Camaro 2SS (Becca Bumble Bee)
Send a message via Yahoo to Brent_$$
I have the slp 575 tvs 2300 with rotofab cai, kooks 1 7/8 long tubes high flow cats and comp cat back muffler delete. East coast supercharging prof tune and I am at 550 rwhp and 525 ft lbs torque. This car driven as an every day car for my wife solid and dependable. Mpg 18-21 city/ hwy on 93 octaine. Solid setup and extreamly fun to install.
Brent_$$ is offline   Reply With Quote
Old 11-23-2010, 01:49 PM   #11
TinyToasta
TinyToasta's Avatar
Looks like I'm gonna stick with those injectors for now and upgrade as soon as the cam is on the agenda. Thanks for for the support!!
What engine oil and spark plugs would you guys suggest to put in?
As far as plugs are concerned I thought about getting some NGK4177, but I'n not sure about the oil
Old 11-23-2010, 01:52 PM   #12
Jessika
Our recommendation is with a stock engine & stock pulley -- keep the stock plugs and use the recommended oil weight that GM suggests.
There is a lot of talk of dropping one degree on the plugs, but we do not have a recommendation on that.
That being said, I have dropped my pulley from a 3.3 (stock) to a 3.1 and am still running my stock plugs & 'stock' 5w30 mobil1
Old 11-23-2010, 02:04 PM   #13
TinyToasta
TinyToasta's Avatar
Great support here, thx!
Your recommendations would be applicable for the TVS2300 as well I'd guess, as your's is a 1900 build, right?
Old 11-23-2010, 02:36 PM   #14
Jessika
Thanks!!
and Yup. A 1lb boost gain is still a 1lb boost gain
Used TVS2300 opinions and thoughts... JProberts Forced Induction - V8 1 09-17-2010 12:21 AM
A few questions about cams, headers and exhaust. Oxtar41 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 09-15-2010 08:11 PM
Do you have 2010 Camaro Mod Newbie Questions? Step inside MoranoRacing 5th Gen Camaro SS LS LT General Discussions 32 06-02-2010 12:22 PM
Set of 4 Midnight Silver Stock Rims for Sale MinnesotaDream Wheels / Tires 2 05-29-2010 09:18 PM
Alignments and Chassis set up JANNETTYRACING Wheels and Tires Talk Sponsored by The Tire Rack 0 08-30-2009 12:16 PM
